Using cre 2.2.0p23, I’ve recently been having some issues with local checks not logging rrd anymore. Everything looks fine in the interface… except the charts are not updated.
Full exemple of what is in the UI with emphasis:
The script output:
P os_ha_addons started=4|failed=0;1;1|stopped=0;1 All add-ons are running
I can say it does update if I remove the warn/crit levels in the above check. I also tried with the complete syntax (started=4;;;;|failed=0;1;1;;|stopped=0;1;;
), and with different metric names in case some names were reserved for whatever reason. No luck.
I can see the rrd files are not getting updated:
OMD[home]:~$ ls -l /opt/omd/sites/home/var/pnp4nagios/perfdata/vm-automation/os_ha_addons*
-rw-rw-r-- 1 home home 3117 Mar 8 23:05 /opt/omd/sites/home/var/pnp4nagios/perfdata/vm-automation/os_ha_addons.xml
-rw-r--r-- 1 home home 384952 Mar 8 23:05 /opt/omd/sites/home/var/pnp4nagios/perfdata/vm-automation/os_ha_addons_failed.rrd
-rw-r--r-- 1 home home 384952 Mar 8 23:05 /opt/omd/sites/home/var/pnp4nagios/perfdata/vm-automation/os_ha_addons_started.rrd
-rw-r--r-- 1 home home 384952 Mar 8 23:05 /opt/omd/sites/home/var/pnp4nagios/perfdata/vm-automation/os_ha_addons_stopped.rrd
It worked in the past, I’m unsure when it stopped working exactly and I honestly don’t see what is wrong exactly with the syntax (if anything). The warn/crit lines are correctly added to the charts, everything seems fine? Any help would be appreciated.
Here is the complete local script just in case:
#!/usr/bin/sh
json=$(ha addons --raw-json)
started_nb=$(echo "$json" | jq -r '[.data.addons[] | select(.state=="started")] | length')
stopped_nb=$(echo "$json" | jq -r '[.data.addons[] | select(.state=="stopped")] | length')
error_nb=$(echo "$json" | jq -r '[.data.addons[] | select(.state=="error")] | length')
stopped=$(echo "$json" | jq -r '.data.addons[] | select(.state=="stopped") | .name' | sed ':a;N;$!ba;s/\n/, /g')
error=$(echo "$json" | jq -r '.data.addons[] | select(.state=="error") | .name' | sed ':a;N;$!ba;s/\n/, /g')
echo -n "P os_ha_addons started=$started_nb|failed=$error_nb;1;1|stopped=$stopped_nb;1"
if [ $stopped_nb -gt 0 ] && [ $error_nb -gt 0 ]
then
if [ $stopped_nb -gt 1 ]
then
echo " $stopped are stopped,"
else
echo " $stopped is stopped,"
fi
if [ $error_nb -gt 1 ]
then
echo " $error are in error"
else
echo " $error is in error"
fi
elif [ $stopped_nb -gt 0 ]
then
then
echo " $stopped are stopped"
else
echo " $stopped is stopped"
fi
elif [ $error_nb -gt 0 ]
then
then
else
fi
else
echo " All add-ons are running"
fi
And finally the local section from the agent output, taken from the diagnostics page in WATO:
<<<local:sep(0)>>>
0 os_release - Home Assistant OS 12.0
0 os_kernel - 6.6.16-haos
