What is that error for?
I’ve the below errors on 2 of my VMs and i don’t know what is the problem to solve it.
First Node Error:
Systemd Service summary
CRIT - 130 services in total, 1 static service failed (check_mk@560-10.151.158.71:6556-192.168.200.18:44600)CRIT, Service ‘check_mk@12771-10.151.158.71:6556-10.151.158.19:44136’ activating for: 0.00 s, 10 disabled services
Second Node Error:
CRIT - 116 services in total, 1 static service failed (check_mk@570-10.151.158.72:6556-192.168.200.18:55322)CRIT, 9 disabled services
Please Advice
Maybe Dirks Solution can help:
Yes it solved the problem but what is this error? What is wrong and what service is having issue?
On the target: sudo systemctl list-units --failed
UNIT LOAD ACTIVE SUB DESCRIPTION
● check_mk@560-10.151.158.71:6556-192.168.200.18:44600.service loaded failed failed Check_MK
LOAD = Reflects whether the unit definition was properly loaded.
ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
SUB = The low-level unit activation state, values depend on unit type.
1 loaded units listed. Pass --all to see loaded but inactive units, too.
To show all installed unit files use ‘systemctl list-unit-files’.
Just for some background information from a similar problem:
I would take a look with journalctl and in /var/log/syslog or /var/log/messages to see what happened to the systemd service and make sure, to use the latest checkmk server and corresponding agent version to not run into already fixed issues.
I think there where a lot improvements and changes for systemd and the agent.
