What is the difference between Auto Width and Max Width?
Hello everyone.
I’m creating some dashboards and I don’t understand the difference between using Auto Width and Max Width in a component. I see very similar behavior. Can someone explain it to me, please? Thanks.
Hi
The difference between max width and auto width in an anchored layout is as follows:
  • Max width: The widget automatically extends to fill the entire available width of the screen, starting from its anchor position. It doesn’t consider whether another widget occupies that space
  • Auto width: The widget automatically adjusts its width to fit its content to the space available
You can also find more details about the layout behavior in the Checkmk docs.
Best
Mathieu
Thanks Mathieu for your reply and for the link to the documentation. Very helpful, thank you.
