The installer assumes systemd is there, I actually installed it, but still the postinstall script fails. Maybe a way to pass in not to install system service or manually start would be good workaround.
New default version is 2.1.0p1.cfe.
Installing systemd service: omd.init
Disabling startup through SysV (/etc/init.d/*) scripts
Activating startup during system boot
System has not been booted with systemd as init system (PID 1). Can’t operate.
Failed to connect to bus: Host is down
dpkg: error processing package check-mk-free-2.1.0p1 (–configure):
installed check-mk-free-2.1.0p1 package post-installation script subprocess returned error exit status 1
Setting up samba-common-bin (2:4.15.5~dfsg-0ubuntu5) …
Checking smb.conf with testparm
Load smb config files from /etc/samba/smb.conf
Loaded services file OK.
Weak crypto is allowed
If you want to run the CMK inside WSL 2, i would recommend to use the Docker image.
For my dev system it looks like WSL 2 with running Ubuntu as distri and there inside the Docker CE.
As it is not possible to start these services with the system start as there is no systemd i use the “/etc/wsl.conf” with the following entry.
[boot]
command = service docker start
With this setting i can start my dev container with running CMK with an easy “code .” inside the dev container folder.
Shell from inside WSL 2
~> cd cmk_dev/checkmk_template/
~/c/checkmk_template (master)> code-insiders .
Updating VS Code Server to version acb156d6fb0dc451f427748d5f68774f17cc96fd
Removing previous installation...
Installing VS Code Server for x64 (acb156d6fb0dc451f427748d5f68774f17cc96fd)
Downloading: 100%
Unpacking: 100%
Unpacked 2377 files and folders to .../.vscode-server-insiders/bin/acb156d6fb0dc451f427748d5f68774f17cc96fd.
~/c/checkmk_template (master)> dpkg -l | grep ii | grep docker
ii docker-ce 5:20.10.16~3-0~ubuntu-focal amd64 Docker: the open-source application container engine
ii docker-ce-cli 5:20.10.16~3-0~ubuntu-focal amd64 Docker CLI: the open-source application container engine
ii docker-ce-rootless-extras 5:20.10.16~3-0~ubuntu-focal amd64 Rootless support for Docker.
ii docker-scan-plugin 0.17.0~ubuntu-focal amd64 Docker scan cli plugin.
~/c/checkmk_template (master)> docker ps -a
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
ec730d62e71f vsc-checkmk_template-e9f84f514c3090c733e7539b9ef74805-uid "/bin/sh -c 'echo Co…" 7 days ago Up 53 seconds (health: starting) 5000/tcp, 6557/tcp bold_ellis
ec02d9acc985 portainer/portainer-ce:latest "/portainer" 13 days ago Up About a minute 8000/tcp, 9443/tcp, 0.0.0.0:3040->9000/tcp, :::3040->9000/tcp portainer
The “bold_ellis” container is the CMK running after starting it with the start of the vscode environment.
You can also start such a container automatically after starting the WSL. But it will not autostart with the start of you Windows system without implementing some type of start script from Windows side.
