CheckMK Version: CME 2.2.0p9
Hello everyone,
I am currently writing an SNMP check for a Zertificon appliance that monitors the status of the individual products. This is an enforced check because Zertificon does not have its own enterprise branch for SNMP.
The good thing is that the check works. I can search for and set it up via the setup, the service appears on the host and the status mapping also works.
But when I call up the page “Parameter for this Service” via the service, I get the following error message and the page does not load any further.
I cannot find the error here. I think it will be an error in the Wato file, something with the two dictionaries?!
Do you have any idea what the problem could be?
Following the check and the WATO plugin
Check:
#!/usr/bin/env python3usage_crit
from .agent_based_api.v1 import register, Result, Service, all_of, SNMPTree, State, exists, not_exists
def discover_product_status(section):
yield Service()
def check_product_status(params, section):
print("SECTION: ", section)
print("PARAMS: ", params)
# SECTION: {'CertServer': {'status': '0'}, 'SecureMail Gateway': {'status': '0'}, 'SecureMail Messenger': {'status': '1'}, 'SecureHub 2.x': {'status': '1'}}
# PARAMS: Parameters({'CertServer': {'status_error': 2, 'status_ok': 0},
# 'SecureHub 2.x': {'status_error': 2, 'status_ok': 0},
# 'SecureMail Gateway': {'status_error': 2, 'status_ok': 0},
# 'SecureMail Messenger': {'status_error': 2, 'status_ok': 0}})
certserver_status = int(section["CertServer"]["status"])
smgw_status = int(section["SecureMail Gateway"]["status"])
smmsg_status = int(section["SecureMail Messenger"]["status"])
sechub_status = int(section["SecureHub 2.x"]["status"])
if certserver_status == 1:
service_state=State(params['CertServer']['status_error'])
summary_text="CertServer has an ERROR!"
elif certserver_status == 0:
service_state=State(params['CertServer']['status_ok'])
summary_text="CertServer is OK"
else:
service_state=State.UNKNOWN
summary_text="CertServer has an unknown state"
yield Result(state=service_state, summary=f"{summary_text}")
if smgw_status == 1:
service_state=State(params['SecureMail Gateway']['status_error'])
summary_text="SecureMail Gateway has an ERROR!"
elif smgw_status == 0:
service_state=State(params['SecureMail Gateway']['status_ok'])
summary_text="SecureMail Gateway is OK"
else:
summary_text="SecureMail Gateway has an unknown state"
if smmsg_status == 1:
service_state=State(params['SecureMail Messenger']['status_error'])
summary_text="SecureMail Messenger has an ERROR!"
elif smmsg_status == 0:
service_state=State(params['SecureMail Messenger']['status_ok'])
summary_text="SecureMail Messenger is OK"
else:
summary_text="SecureMail Messenger has an unknown state"
if sechub_status == 1:
service_state=State(params['SecureHub 2.x']['status_error'])
summary_text="SecureHub 2.x has an ERROR!"
elif sechub_status == 0:
service_state=State(params['SecureHub 2.x']['status_ok'])
summary_text="SecureHub 2.x is OK"
else:
summary_text="SecureHub 2.x has an unknown state"
return
def parse_product_status(string_table):
print(string_table)
parsed = {}
parsed["CertServer"] = {"status": string_table[0][0]}
parsed["SecureMail Gateway"] = {"status": string_table[0][1]}
parsed["SecureMail Messenger"] = {"status": string_table[0][2]}
parsed["SecureHub 2.x"] = {"status": string_table[0][3]}
print(parsed)
return parsed
register.check_plugin(
name="zertificon_product_status",
service_name="Status",
discovery_function=discover_product_status,
check_function=check_product_status,
check_default_parameters={},
check_ruleset_name="zertificon_product_status",
register.snmp_section(
name = "zertificon_product_status",
parse_function = parse_product_status,
# This condition will never match, therefore, zertificon_product_status is only available as an
# enforced service. This is necessary because Zertificon appliances cannot be decisively
# identified based on their SNMP data. Hence, no sensible detection condition can be formulated.
detect=all_of(
exists(".1.3.6.1.2.1.1.1.0"),
not_exists(".1.3.6.1.2.1.1.1.0"),
fetch = SNMPTree(
base = '.1.3.6.1.4.1.2021.8.1.100',
oids = [
'1', # Z1 CertServer
'2', # Z1 SecureMail Gateway
'3', # Z1 SecureMail Messenger
'16', # Z1 SecureHub 2.x
Wato Rule:
from cmk.gui.i18n import _
from cmk.gui.plugins.wato.utils import (
ManualCheckParameterRulespec,
rulespec_registry,
RulespecGroupEnforcedServicesApplications,
from cmk.gui.valuespec import Dictionary, MonitoringState
def _parameter_valuespec_status():
return Dictionary(
title=_("Mapping Device States"),
elements=[
(product,
Dictionary(
title = _(f"Mapping for {product} status."),
elements=[
("status_ok", MonitoringState(title=_("State when device returns OK."), default_value=0)),
("status_error", MonitoringState(title=_("State when device returns ERROR."), default_value=2)),
optional_keys=False
for product in [
"CertServer",
"SecureMail Gateway",
"SecureMail Messenger",
"SecureHub 2.x",
optional_keys=False
rulespec_registry.register(
ManualCheckParameterRulespec(
check_group_name="zertificon_product_status",
group=RulespecGroupEnforcedServicesApplications,
match_type = "dict",
#item_spec = _item_valuespec_status,
parameter_valuespec=_parameter_valuespec_status,
title=lambda: _("Zertificon Product Status"),
If you need more information, feel free to ask.
Many thanks in advance!
Kind regards, Marc
