Here is my pool
# zpool status
pool: Vol-10TB-6x2-RAIDZ1-1
state: DEGRADED
status: One or more devices are faulted in response to persistent errors.
Sufficient replicas exist for the pool to continue functioning in a
degraded state.
action: Replace the faulted device, or use 'zpool clear' to mark the device
repaired.
scan: scrub repaired 0B in 1 days 12:52:35 with 0 errors on Mon Feb 17 12:52:37 2025
config:
NAME STATE READ WRITE CKSUM
Vol-10TB-6x2-RAIDZ1-1 DEGRADED 0 0 0
raidz1-0 DEGRADED 0 0 0
gptid/9d640fd2-8483-11ef-a549-1402ec8c19c5 ONLINE 0 0 0
gptid/5d82c98a-e1d8-11e8-baf0-6cb3113b92f4 FAULTED 7 84 0 too many errors
gptid/5e0e19e0-e1d8-11e8-baf0-6cb3113b92f4 ONLINE 0 0 0
gptid/5e981951-e1d8-11e8-baf0-6cb3113b92f4 ONLINE 0 0 0
gptid/5f263ddb-e1d8-11e8-baf0-6cb3113b92f4 ONLINE 0 0 0
gptid/5fb1d0d2-e1d8-11e8-baf0-6cb3113b92f4 ONLINE 0 0 0
raidz1-1 ONLINE 0 0 0
gptid/606e2af3-e1d8-11e8-baf0-6cb3113b92f4 ONLINE 0 0 0
gptid/25d99864-35be-11e9-93f8-6cb3113b92f4 ONLINE 0 0 0
gptid/622c7b9d-e1d8-11e8-baf0-6cb3113b92f4 ONLINE 0 0 0
gptid/6365795a-e1d8-11e8-baf0-6cb3113b92f4 ONLINE 0 0 0
gptid/64b345aa-e1d8-11e8-baf0-6cb3113b92f4 ONLINE 0 0 0
gptid/65dbb6ba-e1d8-11e8-baf0-6cb3113b92f4 ONLINE 0 0 0
errors: No known data errors
Here is CheckMK (raw 2.3.0p26)
debug:
$ cmk --debug -nv --checks=zpool_status SERVER
WARNING: '--checks' is deprecated in favour of option 'detect-plugins'
+ FETCHING DATA
File "/omd/sites/companysite/bin/cmk", line 124, in <module>
exit_status = modes.call("--check", None, opts, args)
File "/omd/sites/companysite/lib/python3/cmk/base/modes/__init__.py", line 70, in call
return handler(*handler_args)
File "/omd/sites/companysite/lib/python3/cmk/base/modes/check_mk.py", line 2163, in mode_check
with (
File "/omd/sites/companysite/lib/python3/cmk/base/errorhandling/_handler.py", line 66, in __exit__
*_handle_failure(
File "/omd/sites/companysite/lib/python3/cmk/base/errorhandling/_handler.py", line 103, in _handle_failure
raise exc
File "/omd/sites/companysite/lib/python3/cmk/base/modes/check_mk.py", line 2179, in mode_check
checks_result = execute_checkmk_checks(
File "/omd/sites/companysite/lib/python3/cmk/checkengine/checking/_checking.py", line 87, in execute_checkmk_checks
service_results = list(
File "/omd/sites/companysite/lib/python3/cmk/checkengine/checking/_checking.py", line 224, in check_host_services
yield plugin.function(host_name, service, providers=providers)
File "/omd/sites/companysite/lib/python3/cmk/base/checkers.py", line 443, in check_function
return get_aggregated_result(
File "/omd/sites/companysite/lib/python3/cmk/base/checkers.py", line 708, in get_aggregated_result
section_kws, error_result = _get_monitoring_data_kwargs(
File "/omd/sites/companysite/lib/python3/cmk/base/checkers.py", line 629, in _get_monitoring_data_kwargs
get_section_kwargs(
File "/omd/sites/companysite/lib/python3/cmk/checkengine/sectionparserutils.py", line 42, in get_section_kwargs
if (resolved := resolver.resolve(name)) is not None
File "/omd/sites/companysite/lib/python3/cmk/checkengine/sectionparser.py", line 185, in resolve
parsing_result := self._parser.parse(producer_name, producer.parse_function)
File "/omd/sites/companysite/lib/python3/cmk/checkengine/sectionparser.py", line 94, in parse
if (parsed := self._parse_raw_data(section_name, parse_function)) is None
File "/omd/sites/companysite/lib/python3/cmk/checkengine/sectionparser.py", line 117, in _parse_raw_data
return parse_function(list(raw_data))
File "/omd/sites/companysite/lib/python3/cmk/base/plugins/agent_based/zpool_status.py", line 91, in parse_zpool_status
if line[1] != "ONLINE":
IndexError: list index out of range
