Some lines have been removed/omitted for simplicity, but before line <<<netapp_api_snapvault:sep(9)>>>, values are being displayed for all others
/omd/sites/monitor/share/check_mk/agents/special/agent_netapp netapp-4 USER PASS --debug --no_counters
<<<netapp_api_vs_status:sep(9)>>>
Unused
Unused1
Unused2
<<<netapp_api_vs_traffic:sep(9)>>>
0 cifs_latency 13989430 cifs_latency_base 13 cifs_latency_hist 2,3,0,0,0,0,0,0,1,1,0,1,0,0,0,0,0,0,0,0,1,0,1,0,1,0,0,0,0,0,0,1,0,1,0,0,0,0,0,0 cifs_op_count 0,0,0,0,0,0,0,13 cifs_op_pct 0,0,0,0,0,0,0,13 cifs_ops 13 cifs_read_latency 0 cifs_read_latency_hist 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0 cifs_read_ops 0 cifs_read_size_histo 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0 cifs_write_latency 0 cifs_write_latency_hist 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0 cifs_write_ops 0 cifs_write_size_histo 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0 commands_outstanding 0 component_cache 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0 conn_closed_internally_unexpected 0 conn_could_not_close_without_waiting 0 conn_hung_cnt 0 connected_shares 0 connection_idle_close 0 connections 0 continuously_available_connections 0 copyoffload_directcopy_read_request 0 cred_avg_size_bytes 0 cred_avg_total_groups 0 cred_avg_unix_groups 0 cred_avg_win_groups 0 cred_build_req 0 cred_max_device_claims 0 cred_max_device_groups 0 cred_max_size_bytes 0 cred_max_total_groups 0 cred_max_unix_groups 0 cred_max_user_claims 0 cred_max_win_groups 0 duplicate_session_disconnected 0 durable_opens 0 encrypted_sessions 0 encrypted_share_connections 0 established_sessions 0 export_policy_request 0 extended_dfs_referral_reqs 0 file_handle_cache_entries 0 file_handle_cache_hit_latency 0 file_handle_cache_hit_latency_histogram 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0 file_handle_cache_hits 0 file_handle_cache_latency 0 file_handle_cache_max_entries 0 file_handle_cache_miss_latency 0 file_handle_cache_miss_latency_histogram 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0 file_handle_cache_misses 0 file_handle_cache_requests 0 flexgroup_lookup_multiple_redrive 0 flexgroup_lookup_redrive 0 flexgroup_msid_cache_hit 0 flexgroup_msid_cache_max_depth 0 flexgroup_msid_cache_max_entries 0 flexgroup_open_multiple_redrive 0 flexgroup_open_redrive 0 flow_control_back_to_back 0 flow_control_connections 0 flow_control_latency_hist 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0 flow_control_max_queue_depth 0 guest_user_session 0 handle_lease_ignored 0 homedir_share_request 0 instance_name XXXXX instance_uuid 14 ioctl_fsctl_set_zero_data_unaligned_request 0 lock_reconstruction 0 max_active_searches 0 max_change_notifications_outstanding 0 max_commands_outstanding 2 max_connected_shares 0 max_connections 1 max_directory_depth 0 max_established_sessions 1 max_junction_depth 0 max_open_files 0 max_open_files_per_share 0 max_opens_same_file_per_tree 0 max_outstanding_auth_requests 1 max_same_tree_connect_per_session 0 max_same_user_session_per_conn 0 max_searches_per_session 0 max_sessions_per_connection 1 max_shares_per_session 0 max_watches_set_per_tree 0 nameserver_query_request_matches 0 nameserver_query_requests 0 nameserver_registration_request_matches 0 nameserver_registration_requests 0 nbt_session_keepalives 0 nbt_session_requests 0 no_version_negotiated 0 node_referral_issued 0 node_referral_local 0 node_referral_not_possible 0 node_referral_remote 0 non_unicode_client_rejected 0 null_user_session 0 open_files 0 open_reject_too_many 0 optimized_smb2_open 0 optimized_smb2_opens 0 outstanding_auth_requests 0 path_based_ops 0 path_cache_entries 0 path_cache_hit_latency 0 path_cache_hit_latency_histogram 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0 path_cache_hits 0 path_cache_latency 0 path_cache_max_entries 0 path_cache_miss_latency 0 path_cache_miss_latency_histogram 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0 path_cache_misses 0 path_cache_requests 0 persistent_opens 0 privileged_lock_req 0 privileged_lock_test_req 0 read_data 0 reconnection_requests_failed 0 reconnection_requests_total 0 rejected_unencrypted_sessions 0 rejected_unencrypted_shares 0 sd_max_ace_count 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0 sd_max_ace_size 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0 server_side_close_conn 0 session_idle_close 0 session_reject_too_many 0 session_timed_out 0 signed_sessions 0 smb1_connections_count 0 smb2_1_connections_count 0 smb2_connections_count 0 smb3_1_connections_count 0 smb3_connections_count 0 total_data 0 total_smb1_connections_count 0 total_smb2_1_connections_count 0 total_smb2_connections_count 0 total_smb3_1_connections_count 3 total_smb3_connections_count 1 tree_connect_reject_too_many 0 watch_reject_too_many 0 widelink_request 0 write_data 0
<<<netapp_api_if:sep(9)>>>
interface TREE_nfs_lif1 address 10.202.8.4 address-family ipv4 administrative-status up comment - current-node netapp-4-1 current-port a0a-20 data-protocols.data-protocol nfs dns-domain-name none failover-group TREE failover-policy system_defined firewall-policy data home-node netapp-4-1 home-port a0a-20 ipspace IP-TREE is-auto-revert trueis-dns-update-enabled true is-home true is-vip false lif-uuid 598bca31-4172-11ec-a9c2-00a098be3d4c listen-for-dns-query false netmask 255.255.252.0 netmask-length 22 operational-status up role data service-names.lif-service-name backup_ndmp_control service-policy custom-data-32975 subnet-name NET-TREE use-failover-group unused vserver TREE instance_name TREE_nfs_lif1 recv_data 150146049816432 recv_errors 0 recv_packet 18104758553 send_data 149061421213912 send_errors 0 send_packet 22552207085 link-status up failover_ports netapp-4-2|a0a-20|up;netapp-4-1|a0a-20|up
<<<netapp_api_cpu:sep(9)>>>
cpu-info netapp-4-1 num_processors 36
cpu-info netapp-4-2 num_processors 36
cpu-info netapp-4-1 cpu_busy 15447534000000 nvram-battery-status battery_ok
cpu-info netapp-4-2 cpu_busy 13761997000000 nvram-battery-status battery_ok
<<<netapp_api_cm_cluster:sep(9)>>>
cluster netapp-4-1 backup-io-times.mailbox-io-times-info.normal 88 backup-io-times.mailbox-io-times-info.transition 0 backup-mailbox-status.mailbox-status-info.mailbox-status mbx_status_backup booting-received 0 control-partner-aggregates false current-mode ha current-time 1713415677 firmware-received -450906583 giveback-state nothing_to_gb ha-type none interconnect-links RDMA Interconnect is up (Link up) interconnect-type GOP (NV10 HSL) is-enabled true is-interconnect-up true kill-packets true local-firmware-progress 29613464 local-firmware-state SF_UP local-in-headswap false local-mailbox-disks.sf-disk-info.disk-cluster-name 1.0.2.P3 local-mailbox-disks.sf-disk-info.disk-uid 68CE38EE:200A98D4:500A0981:00000003:00000000:00000000:00000000:00000000:00000000:00000000local-mailbox-disks.sf-disk-info.name 0c.00.2P3 local-mailbox-disks.sf-disk-info.physical-location 1 logs-unsynced-count 0 max-resource-table-index 133 mode ha name netapp-4-1 new-partner-sysid 0 node-state connected nvram-id 537067048 partner netapp-4-2 partner-firmware-progress 29613656 partner-firmware-state SF_UP partner-in-headswap false partner-mailbox-disks.sf-disk-info.disk-cluster-name 1.0.14.P3 partner-mailbox-disks.sf-disk-info.disk-uid 68CE38EE:200A8E58:500A0981:00000003:00000000:00000000:00000000:00000000:00000000:00000000 partner-mailbox-disks.sf-disk-info.name 0c.00.14P3 partner-mailbox-disks.sf-disk-info.physical-location 1 partner-name netapp-4-2 partner-nvram-id 537066757 primary-io-times.mailbox-io-times-info.normal 202 primary-io-times.mailbox-io-times-info.transition 0 resource-table.resource-table-info.fail ok resource-table.resource-table-info.name rsrctbl: fmrsrc_takeover resource-table.resource-table-info.state up resource-table.resource-table-info.time-delta 0 sf-options.sf-options-info.aggregate-migration-timeout 120 sf-options.sf-options-info.bypass-takeover-optimization false sf-options.sf-options-info.giveback-auto true sf-options.sf-options-info.hwassist-enable true sf-options.sf-options-info.hwassist-health-check-interval 180 sf-options.sf-options-info.hwassist-partner-ip 192.0.2.85 sf-options.sf-options-info.hwassist-partner-port 162 sf-options.sf-options-info.hwassist-retry-count 2 sf-options.sf-options-info.mode ha sf-options.sf-options-info.node-status-in-mailbox-disks true sf-options.sf-options-info.node-status-in-mailbox-disks-read-interval 5 sf-options.sf-options-info.node-status-in-mailbox-disks-write-interval 5 sf-options.sf-options-info.send-home-auto true sf-options.sf-options-info.send-home-auto-attempts 2 sf-options.sf-options-info.send-home-auto-attempts-minutes 60 sf-options.sf-options-info.send-home-auto-delay-seconds 600 sf-options.sf-options-info.send-home-check-partner-waiting true sf-options.sf-options-info.takeover-detection-time 15 sf-options.sf-options-info.takeover-on-failure true sf-options.sf-options-info.takeover-on-panic true sf-options.sf-options-info.takeover-on-reboot true sf-options.sf-options-info.takeover-on-short-uptime true state connected takeover-by-partner-possible true takeover-possible true takeover-state not_in_takeover timeouts.timeout-info.booting 300000 timeouts.timeout-info.connect 5000 timeouts.timeout-info.dumpcore 60000 timeouts.timeout-info.fast 1000 timeouts.timeout-info.firmware 15000 timeouts.timeout-info.mailbox 10000 timeouts.timeout-info.operator 600000 timeouts.timeout-info.reboot 1000 timeouts.timeout-info.slow 2500 timeouts.timeout-info.transit 600000 timeouts.timeout-info.transit-timer-enabled true transit-event-time 158940
cluster netapp-4-2 backup-io-times.mailbox-io-times-info.normal 169 backup-io-times.mailbox-io-times-info.transition 0 backup-mailbox-status.mailbox-status-info.mailbox-status mbx_status_backup booting-received 0 control-partner-aggregates false current-mode ha current-time 1713415677 firmware-received -449923784 giveback-state nothing_to_gb ha-type none interconnect-links RDMA Interconnect is up (Link up) interconnect-type GOP (NV10 HSL) is-enabled true is-interconnect-up true kill-packets true local-firmware-progress 29613656 local-firmware-state SF_UP local-in-headswap false local-mailbox-disks.sf-disk-info.disk-cluster-name 1.0.14.P3 local-mailbox-disks.sf-disk-info.disk-uid 68CE38EE:200A8E58:500A0981:00000003:00000000:00000000:00000000:00000000:00000000:00000000 local-mailbox-disks.sf-disk-info.name 0c.00.14P3 local-mailbox-disks.sf-disk-info.physical-location 1 logs-unsynced-count 0 max-resource-table-index 133 mode ha name netapp-4-2 new-partner-sysid 0 node-state connected nvram-id 537066757 partner netapp-4-1 partner-firmware-progress 29613464 partner-firmware-state SF_UP partner-in-headswap false partner-mailbox-disks.sf-disk-info.disk-cluster-name 1.0.2.P3 partner-mailbox-disks.sf-disk-info.disk-uid 68CE38EE:200A98D4:500A0981:00000003:00000000:00000000:00000000:00000000:00000000:00000000 partner-mailbox-disks.sf-disk-info.name 0c.00.2P3 partner-mailbox-disks.sf-disk-info.physical-location 1 partner-name netapp-4-1 partner-nvram-id 537067048 primary-io-times.mailbox-io-times-info.normal 5000 primary-io-times.mailbox-io-times-info.transition 0 resource-table.resource-table-info.fail ok resource-table.resource-table-info.name rsrctbl: fmrsrc_takeover resource-table.resource-table-info.state up resource-table.resource-table-info.time-delta 0 sf-options.sf-options-info.aggregate-migration-timeout 120 sf-options.sf-options-info.bypass-takeover-optimization false sf-options.sf-options-info.giveback-auto true sf-options.sf-options-info.hwassist-enable true sf-options.sf-options-info.hwassist-health-check-interval 180 sf-options.sf-options-info.hwassist-partner-ip 192.0.2.84 sf-options.sf-options-info.hwassist-partner-port 162 sf-options.sf-options-info.hwassist-retry-count 2 sf-options.sf-options-info.mode ha sf-options.sf-options-info.node-status-in-mailbox-disks true sf-options.sf-options-info.node-status-in-mailbox-disks-read-interval 5 sf-options.sf-options-info.node-status-in-mailbox-disks-write-interval 5 sf-options.sf-options-info.send-home-auto true sf-options.sf-options-info.send-home-auto-attempts 2 sf-options.sf-options-info.send-home-auto-attempts-minutes 60 sf-options.sf-options-info.send-home-auto-delay-seconds 600 sf-options.sf-options-info.send-home-check-partner-waiting true sf-options.sf-options-info.takeover-detection-time 15 sf-options.sf-options-info.takeover-on-failure true sf-options.sf-options-info.takeover-on-panic true sf-options.sf-options-info.takeover-on-reboot true sf-options.sf-options-info.takeover-on-short-uptime true state connected takeover-by-partner-possible true takeover-possible true takeover-state not_in_takeover timeouts.timeout-info.booting 300000 timeouts.timeout-info.connect 5000 timeouts.timeout-info.dumpcore 60000 timeouts.timeout-info.fast 1000 timeouts.timeout-info.firmware 15000 timeouts.timeout-info.mailbox 10000 timeouts.timeout-info.operator 600000 timeouts.timeout-info.reboot 1000 timeouts.timeout-info.slow 2500 timeouts.timeout-info.transit 600000 timeouts.timeout-info.transit-timer-enabled true transit-event-time 1190597
<<<netapp_api_systemtime:sep(9)>>>
netapp-4-1 1713415677 1713415677
netapp-4-2 1713415677 1713415677
<<<netapp_api_disk:sep(9)>>>
disk 5002538A:07275510:00000000:00000000:00000000:00000000:00000000:00000000:00000000:00000000 serial-number XXXXXXXXXX bay 7 vendor-id NETAPP raid-state shared physical-space 3840755982336 raid-type shared used-space 3840493748224
disk 5002538B:00848C50:00000000:00000000:00000000:00000000:00000000:00000000:00000000:00000000 serial-number XXXXXXXXXX bay 2 vendor-id NETAPP raid-state aggregate physical-space 3840755982336 raid-type data used-space 3840493748224
disk 58CE38EE:200E2910:00000000:00000000:00000000:00000000:00000000:00000000:00000000:00000000 serial-number XXXXXXXXXX bay 11 vendor-id NETAPP raid-state shared physical-space 3840755982336 raid-type shared used-space 3840493748224
disk 58CE38EE:200E291C:00000000:00000000:00000000:00000000:00000000:00000000:00000000:00000000 serial-number XXXXXXXXXX bay 16 vendor-id NETAPP raid-state shared physical-space 3840755982336 raid-type shared used-space 3840493748224
<<<netapp_api_volumes:sep(9)>>>
volume 55185a8a-4172-11ec-bacc-00a098be3d24 msid 2160758718 name TREE_root node netapp-4-1 vserver_name TREE files-total 31122 files-used 103 is-space-enforcement-logical false logical-used 3309568 size-available 1016745984 size-total 1020055552 state online cifs_read_data 0 cifs_read_latency 0 cifs_read_ops 0 cifs_write_data 0 cifs_write_latency 0 cifs_write_ops 0 fcp_read_data 0 fcp_read_latency 0 fcp_read_ops 0 fcp_write_data 0 fcp_write_latency 0 fcp_write_ops 0 instance_name TREE_root iscsi_read_data 0 iscsi_read_latency 0 iscsi_read_ops 0 iscsi_write_data 0 iscsi_write_latency 0 iscsi_write_ops 0 nfs_read_data 0 nfs_read_latency 0 nfs_read_ops 0 nfs_write_data 0 nfs_write_latency 0 nfs_write_ops 0 read_data 308839424 read_latency 6520432 read_ops 603202 san_read_data 0 san_read_latency 0 san_read_ops 0 san_write_data 0 san_write_latency 0 san_write_ops 0 write_data 0 write_latency 0 write_ops 0
<<<netapp_api_aggr:sep(9)>>>
aggregation aggr0_1 size-available 51639083008 size-total 1065855225856
aggregation aggr0_2 size-available 51639095296 size-total 1065855225856
aggregation aggr_ssd_nm_1 size-available 14383095853056 size-total 29844900020224
<<<netapp_api_luns:sep(9)>>>
lun /vol/ssd_nm_1_data/ssd_nm_1_1 online true read-only false size 17557557870592 size-used 5310100803584 volume ssd_nm_1_data vserver -ssd-nm-1
lun /vol/ssd_nm_3_data/ssd_nm_3_1 online true read-only false size 17557557870592 size-used 6785496084480 volume ssd_nm_3_data vserver -ssd-nm-1
l<<<netapp_api_status>>>
status ok
<<<netapp_api_info:sep(9)>>>
build-timestamp 1680825770
is-clustered true
version NetApp Release 9.11.1P8: Fri Apr 07 00:02:50 UTC 2023
node netapp-4-1 backplane-part-number xx+A0 backplane-revision S4F backplane-serial-number xxx board-speed 2294 board-type System Board XXIII controller-address A cpu-firmware-release 12.12 cpu-microcode-version xx cpu-part-number xx cpu-processor-id 0x406f1 cpu-processor-type Intel(R) Xeon(R) CPU E5-2697 v4 @ 2.30GHz cpu-revision D0 cpu-serial-number xx memory-size 524288 number-of-processors 36 partner-system-id xxx partner-system-name netapp-4-2 prod-type FAS supports-raid-array true system-id xx system-machine-type AFF-A700s system-model AFF-A700s system-name netapp-4-1 system-revision D0 system-serial-number xx vendor-id NetApp
node netapp-4-2 backplane-part-number xx+A0 backplane-revision S1F backplane-serial-number xx board-speed 2294 board-type System Board XXIII controller-address B cpu-firmware-release 12.12 cpu-microcode-version xx cpu-part-number xx cpu-processor-id 0x406f1 cpu-processor-type Intel(R) Xeon(R) CPU E5-2697 v4 @ 2.30GHz cpu-revision D0 cpu-serial-number xx memory-size 524288 number-of-processors 36 partner-system-id xxx partner-system-name netapp-4-1 prod-type FAS supports-raid-array true system-id xx system-machine-type AFF-A700s system-model AFF-A700s system-name netapp-4-2 system-revision D0 system-serial-number xx vendor-id NetApp
<<<netapp_api_psu:sep(9)>>>
<<<netapp_api_connection>>>
Agent Exception (contact developer):
File "/omd/sites/monitor/share/check_mk/agents/special/agent_netapp", line 11, in <module>
sys.exit(main())
File "/omd/sites/monitor/lib/python3/cmk/special_agents/agent_netapp.py", line 1742, in main
process_mode_specific(netapp_mode, args, session, licenses)
File "/omd/sites/monitor/lib/python3/cmk/special_agents/agent_netapp.py", line 1518, in process_mode_specific
process_clustermode(args, server, licenses)
File "/omd/sites/monitor/lib/python3/cmk/special_agents/agent_netapp.py", line 1135, in process_clustermode
assert isinstance(node, NetAppNode)
AssertionError
