nach Upgrade bekomme ich bei einigen Ubuntus diese Message, Agent ist aktuell.
cmk --debug -vvI
1 kernel_performance
8 ucd_diskio
SUCCESS - Found 9 services, 2 host labels
Danke
Mit vielen Grüßen
Henri
File “/omd/sites/dssmonitor/bin/check_mk”, line 92, in
File “/omd/sites/dssmonitor/lib/python3/cmk/base/modes/init.py”, line 69, in call
return handler(*handler_args)
File “/omd/sites/dssmonitor/lib/python3/cmk/base/modes/check_mk.py”, line 1272, in mode_automation
sys.exit(automations.automations.execute(args[0], args[1:]))
File “/omd/sites/dssmonitor/lib/python3/cmk/base/automations/init.py”, line 72, in execute
out.output(python_printer.pformat(result))
File “/omd/sites/dssmonitor/lib/python3/cmk/utils/python_printer.py”, line 29, in pformat
return PythonPrinter().pformat(obj)
File “/omd/sites/dssmonitor/lib/python3/cmk/utils/python_printer.py”, line 45, in pformat
PythonPrinter(stream=sio)._format(obj)
File “/omd/sites/dssmonitor/lib/python3/cmk/utils/python_printer.py”, line 52, in _format
_dispatch.get(type(obj), _format_unhandled_type)(self, obj)
File “/omd/sites/dssmonitor/lib/python3/cmk/utils/python_printer.py”, line 115, in _format_dict
_format_sequence(printer, sorted(obj.items(), key=_safe_tuple), _format_dict_item, ‘{’, ‘}’)
File “/omd/sites/dssmonitor/lib/python3/cmk/utils/python_printer.py”, line 140, in _format_sequence
format_element(printer, obj)
File “/omd/sites/dssmonitor/lib/python3/cmk/utils/python_printer.py”, line 129, in _format_dict_item
printer._format(item[1])
File “/omd/sites/dssmonitor/lib/python3/cmk/utils/python_printer.py”, line 104, in _format_list
_format_sequence(printer, obj, _format_object, ‘[’, ‘]’)
File “/omd/sites/dssmonitor/lib/python3/cmk/utils/python_printer.py”, line 119, in _format_object
printer._format(obj)
File “/omd/sites/dssmonitor/lib/python3/cmk/utils/python_printer.py”, line 100, in _format_tuple
_format_sequence(printer, obj, _format_object, ‘(’, ‘)’)
File “/omd/sites/dssmonitor/lib/python3/cmk/utils/python_printer.py”, line 56, in _format_unhandled_type
raise ValueError(‘unhandled type %r’ % type(obj))
ValueError: unhandled type
