Best practice for SMTP notification setup on Docker
Hi
I was able to find some posts about this topic, however I still don’t know the best way to implement it.
I tried to use the internal Posftix and O365 direct send (can’t send emails to people outside your organization).
Using docker install parameters:
-e MAIL_RELAY_HOST=‘domain.mail.protection.outlook.com’’
Error, no solution found so far:
Status: PID file exists, but instance is not running!
If I interpreted this correctly it is not supported for docker?
Checkmk containers do not currently support configuring credentials for a smart host. You can bind a postfix configuration or a configuration folder from the Docker node if you need it.
so I really need to setup a dedicated Docker for the SMTP Relay?
Thanks for your help
Hi Nicola,
Were you able to find a solution to the problem?
I’m currently facing the same thing.
Just tested with the latest docker image. Postfix is starting just fine…
Have you tried adding " --cap-add=SYS_PTRACE" to your docker command?
Hi together
That was the support feedback I got:
In this case, you’re using a docker container, so you need to create a separate Docker container to send Emails.
Checkmk containers currently do not support the configuration of access data for a smart host as described here:
Since you are using the Checkmk Cloud Edition, you can try bypassing postfix completely so that Checkmk forwards notifications directly to a smarthost. This is done by the synchronous SMTP, which is described in detail in the article about notifications. Here an authentication over SMTP is also possible: Notifications - via Email, SMS, ticket system and more
(this workaround did not work for me)
I will try now the suggestion from @chauhan_sudhir
@a.kupenov solved after adding suggested parameter for docker installation (–cap-add=SYS_PTRACE) and changed from port 25 (with EXO relay connector) to 587 ( SMTP AUTH client submission) because docker blocked outgoing traffic with port 25:
How to set up a multifunction device or application to send emails using Microsoft 365 or Office 365 | Microsoft Learn
and 9.3. Synchronous delivery for HTML emails:
Notifications - via Email, SMS, ticket system and more (checkmk.com)
