Hi list,
I'm working on a custom notification plugin which I want to be
configurable through WATO.
The script itself shouldn't be a problem, as I've written other
plugins before.
For this plugin, I need it to have some parameters configurable
through WATO, but instead of having fields that can be filled out,
the only thing that’s happened is that the textbox (where you can
otherwise enter parameters manually) has disappeared.
I checked
$OMD_ROOT/share/check_mk/web/plugins/wato/notifications.py to get
an example on how to set it up. Right now my plugin only lists a
single element which I’ve copied from the notification parameters
for the ‘mail’ plugin.
The only changes I made are the plugin name and the parameter
name (changed from ‘from’ to ‘mail_from’).
What am I missing here?
I’m on 1.2.6p16.cre.
Mail adressen content architects
Met vriendelijke groet / Best
regards,
Paul Bongers
Application Engineer
E-mail: paul.bongers@osudio.com
Web: http://www.osudio.com
Hey Paul,
you could take a look at: https://github.com/seppovic/check_mk-plugins/blob/master/notify-via-xmpp/web/plugins/wato/notify-via-xmpp.py
this is at least working for me. Don’t forget to restart the cmc after creating the wato file.^^
Mit freundlichen Grüßen,
Markus Weber
Bayerisches Landesamt für Steuern
IuK 37 - Rechenzentrum Nord
Dienststelle München
Infanteriestraße 5, 80797 München
Tel: 089 9991 - 4834
Fax: 089 9991 - 494834
E-Mail: Markus.Weber@lfst.bayern.de
From: checkmk-en-bounces@lists.mathias-kettner.de [mailto:checkmk-en-bounces@lists.mathias-kettner.de] On Behalf Of Paul Bongers
Sent: Monday, October 17, 2016 10:46 AM
To: Check_MK-EN
Subject: [Check_mk (english)] Custom notification script - WATO plugin
Hi list,
I’m working on a custom notification plugin which I want to be configurable through WATO.
The script itself shouldn’t be a problem, as I’ve written other plugins before.
For this plugin, I need it to have some parameters configurable through WATO, but instead of having fields that can be filled out, the only thing that’s happened is that the textbox (where you can otherwise enter parameters manually) has disappeared.
I checked $OMD_ROOT/share/check_mk/web/plugins/wato/notifications.py to get an example on how to set it up. Right now my plugin only lists a single element which I’ve copied from the notification parameters for the ‘mail’ plugin.
The only changes I made are the plugin name and the parameter name (changed from ‘from’ to ‘mail_from’).
Met vriendelijke groet / Best regards,
Paul Bongers
Can you show your code?
I also derived my plugin from the default mail script, and it IS working
https://github.com/morph027/check_mk-notification-textsecure/blob/master/textsecure-via-ssh
regards
Stefan
Am 17.10.2016 um 10:46 schrieb Paul Bongers:
Hi list,
The script itself shouldn't be a problem, as I've written other plugins
before.
thing that's happened is that the textbox (where you can otherwise enter
single element which I've copied from the notification parameters for
the 'mail' plugin.
(changed from 'from' to 'mail_from').
I'm on 1.2.6p16.cre.
Paul Bongers
E-mail: paul.bongers@osudio.com <mailto:paul.bongers@osudio.com>
Web: Home Page Germany | SQLI;
checkmk-en mailing list
Thank you Markus, I’ll check it out.
regards,
Paul Bongers
On 17/10/16 11:16,
Hey
Paul,
Mit
Markus
Weber
Bayerisches
E-Mail:
[] Paul Bongers
Check_MK-EN
Hi list,
I checked
Paul Bongers
Markus.Weber@lfst.bayern.decheckmk-en-bounces@lists.mathias-kettner.demailto:checkmk-en-bounces@lists.mathias-kettner.de** On
Behalf Of**
Sent:
To:
Subject:
After some attempts I just started to work.
I suppose I forgot to restart apache.
regards,
Paul Bongers
regards,
Paul Bongers
Application
Engineer
E-mail:
Hey
Paul,
Mit
Markus
Weber
Bayerisches
E-Mail:
Paul Bongers
Check_MK-EN
Hi list,
I checked
Paul Bongers
Markus.Weber@lfst.bayern.decheckmk-en-bounces@lists.mathias-kettner.demailto:checkmk-en-bounces@lists.mathias-kettner.deOn Behalf Of
Sent:
To:
Subject:
