Hi all,
I have some hosts for which are by definition unavailable some, if not
most of the time, due to being either down or not connected to the local
network. (mobile devices, NAS for backups (WOL) etc.)
What is the preferred method to permanently keep their host down status
from cluttering up my "Host Problems (unhandled)" section without
impeding service checks for when these hosts are actually available.
Thanks,
Michael
Goto WATO → Monitoring Configuration → Host check command & make a rule for your hosts. In this rule, define the host check command as “Always assume the host to be up”
2016-05-09 5:14 GMT+02:00 Michael Ionescu mhi@ionescu.de:
Hi all,
from cluttering up my “Host Problems (unhandled)” section without
Thanks,
Michael
checkmk-en mailing list
Hi Tom,
Thanks for the pointer. I’m taking it literally and am getting the following error when I try to activate the ruleset:
Error: Host check command ‘Always assume the host to be up’ specified for host ‘xyz’ is not defined anywhere!
Is there some prerequisite in point of version or additional plug-ins that needs to be satisfied or did I misunderstand?
Thanks,
Michael
Hi all,
Thanks,
Michael
Hummmm
no it should run out of the box. I use 1.2.6p16 cre
Thomas Wittmann
Am 09.05.2016 um 15:29 schrieb Michael Ionescu mhi@ionescu.de:
Hi Tom,
Thanks,
Michael
On May 9, 2016 9:15:34 AM GMT+02:00, Thomas Wittmann tom.teel@gmail.com wrote:
Hi all,
Thanks,
Michael
Sent from my Android device with K-9 Mail. Please excuse my brevity.
I'm using omd 1.00 on wheezy, which encompasses check_mk 1.2.2p2 and
does not seem to incorporate this functionality.
I found [Nagios-users] How to disable check-host-alive | Nagios Core
and thought, I might let WATO create the nagios config and manually
removie the check_command line from that.
However, WATO does not write this to a nagios config file, but just to
its own rule-file:
/omd/sites/uvw/etc/check_mk/conf.d/wato/rules.mk: ( 'check_arbitrary',
, ['xyz', 'abc', 'def'] ),
As the check_command in this version of check_mk obviously requires a
valid value and does not accept 'Always assume the host to be up' I then
implemented the following work-around:
$ cat /opt/omd/sites/uvw/local/lib/nagios/plugins/check_always_ok
#!/bin/bash
echo "OK - assumingly ok"
$ cat opt/omd/sites/uvw/etc/nagios/conf.d/commands.cfg
# 'check_always_ok' command definition
define command{
command_name check_always_ok
command_line $USER2$/check_always_ok
That did the trick.
Thanks, Tom, for steering me in the right direction,
Michael
On 09.05.2016 19:01, Thomas Wittmann wrote:
Hummmm
Thomas Wittmann
Von meinem iPhone gesendet
Am 09.05.2016 um 15:29 schrieb Michael Ionescu <mhi@ionescu.de
<mailto:mhi@ionescu.de>>:
Hi Tom,
Thanks for the pointer. I'm taking it literally and am getting the
Error: Host check command 'Always assume the host to be up' specified
for host 'xyz' is not defined anywhere!
Thanks,
Michael
On May 9, 2016 9:15:34 AM GMT+02:00, Thomas Wittmann >> <tom.teel@gmail.com <mailto:tom.teel@gmail.com>> wrote:
Goto WATO -> Monitoring Configuration -> Host check command & make
as "Always assume the host to be up"
2016-05-09 5:14 GMT+02:00 Michael Ionescu <mhi@ionescu.de
Hi all,
some, if not
the local
down status
available.
Thanks,
Michael
<mailto:checkmk-en@lists.mathias-kettner.de>
