We seem to be running into this issue as well. I was able to reproduce the issue when using our ldap users (they don’t have spaces but they do have an @) and using a local user with an ‘@’ in the username. Using
a local user without the @ in the username the graphs work as normal.
This message is intended for the sole use of the addressee, and may contain information that is privileged, confidential and exempt from
disclosure under applicable law. If you are not the addressee you are hereby notified that you may not use, copy, disclose, or distribute to anyone the message or any information contained in the message. If you have received this message in error, please
immediately advise the sender by reply email and delete this message.
We have recently updated our CheckMK systems running Oracle/Red Hat Linux 7.7 from 1.5.0p23 to 1.6.0p6 and
now find that our Active Directory and LDAP registered users are no longer able to access the pnp graphs for Hosts and Services.
Prior to this update they had no problem doing so.
Local User accounts are still able to access the graphs.
All other access and functionality is working normally for both A/D,LDAP and local users.
I’m not sure if it makes a difference to pnp4nagios but our A/D and LDAP users have spaces in their names.
Any suggestions on how to rectify this would be appreciated.
Regards
Scott McDonald
This email, and any attachments, may be confidential and also privileged. If you are not the intended recipient, please notify the sender and delete all copies of this transmission along with any attachments immediately. You should not copy or use it for any
purpose, nor disclose its contents to any other person.
This email has been scanned for spam and viruses. Click
here to report this email as spam.
