Anyone adapt a Room Alert check for use with the Room Alert 3E?
https://mathias-kettner.com/check_mk-exchange-file.php?&file=avtech3e_sensor_temp-1.0.mkp
I have been using for some years now the following plugins and they work fine
On Wed, May 8, 2019 at 12:57 AM Matthew.Stier@us.fujitsu.com Matthew.Stier@us.fujitsu.com wrote:
checkmk-en mailing list
https://lists.mathias-kettner.de/cgi-bin/mailman/listinfo/checkmk-en
Sorry message left without links,
https://exchange.nagios.org/directory/Plugins/Hardware/Environmental/Check-AVTECH-Room-alert/details
I have modified the OID for each sensor I need and created separate scripts for each one, you could do it simpler by adding as parameters if you know perl.
Thank you and best of luck!
Gregoris
