Sorry if this is already answered somewhere, I scanned the Check_MK page and didn’t locate it.
We are combining multiple Nagios servers into a single Check_MK Raw server. We plan to purchase Check_MK Enterprise once the funds are allocated, unfortunately that will be after the mandatory go live date
for the project so we are having to start with the free version.
My question, once we purchase the Check_MK enterprise version, can we upgrade our free raw system in place?
Thanks,
Mike
Mike Hanby
mhanby @ uab.edu
Systems Analyst II - Enterprise
Research Computing Services / IT Infrastructure Core
Hi Mike
If you are fairly sure you are getting the CEE version you can do what we did and get the CEE trial version right from the get go.
It's fully functional and worked well for us. We also went with the appliance version (VM) which also worked very well for us and allowed us to do fairly seamless HA between two instances.
No transition between trial and Live was needed whereas it looks like some work to go from CRE to CEE.
Just a thought.
Rgds
Paraic
-----Original Message-----
From: checkmk-en [mailto:checkmk-en-bounces@lists.mathias-kettner.de] On Behalf Of Schoch, Marcel
Sent: 08 June 2017 20:43
Subject: Re: [Check_mk (english)] Upgrading From Check_MK Raw to Enterprise
E-mail
disclaimer
This message, including any attachments, is confidential. If you
are not the named recipient, please contact the sender and delete the email from
your system.
This email, including any attachments, is confidential. If you are not the named recipient, please contact the sender and delete all copies of this email from your computer system(s).
Thanks to both. After looking through the demo version limitations 'about 5% of the check results randomly get the state "WARN".' will mean that it won't be feasible to use this version until funding is appropriated
Thanks for the link Marcel, it looks like that's what we'll have to do.
Hi Mike
E-mail
disclaimer
your system.
checkmk-en mailing list checkmk-en@lists.mathias-kettner.de http://lists.mathias-kettner.de/mailman/listinfo/checkmk-en
