Check_MK (MULTY SITES - ssl.c: 711: Handshake operation timed out)
I have a question about the encryption of the slaves, I already configured some slaves and encrypted without problems, but the next day the connection status (ONLINE) changes to:
** Cannot connect to ‘tcp: x.x.x.x: 6557’: (’_ssl.c: 711: Handshake operation timed out’,). The encryption settings are probably wrong. **
And in other slaves I can’t do the configuration, because I get this error:
** Cannot connect to ‘tcp: x.x.x.x: 6557’: [Errno 114] Operation already in progress **
I have other slaves with the same configuration working fine, I try to use persistent connections and it is not working, TLS is enabled in omd configuration for my slaves and also restarting OMD on slave but state does not change.
Can someone tell me what to do?
My CMK Version is 1.6.0p15
Perhaps a hint?
You can find one or two more article searching for ssl.c 711
Ralf
Hi @rprengel
Yes, actually I try to use the force connection in the configuration of my slaves but not is working, my slaves are flapping all day
