Hi I’ve just upgraded to v2 raw, great work by the way! Aside the fact that the color in the warn and critical state do not differentiate making it difficult to discern, I have an issue with the check_mk-pse_poe check which for some HP 1920 switches (not the S variant) the percentage is on 1000% scale. I feel the issue is some conversion missing and the wattage is wrongfully reported. Is there a workaround or fix to make it work OK?
Actually there is no fix for it. An idea is to change the check but keeping in mind if you just divide the output by 1000 you may run in problems with other devices reporting the values in W instead of mW.
As @tosch said there is no general solution at the moment. I had a system last week with the same problem. All the switches there had the same output and i changed the check. But it would be preferred that this is configurable.
If you want to change it globally in your system, you can do the following
copy “~/share/check_mk/checks/pse_poe” to “~/local/share/check_mk/checks/…” and modify the lines
33 and 34 from
It would be good to have it as a parameter, it does not apply on my environment since I others that work fine. I’ll the values to check if a simple if loop at some point will solve the issue…
For anyone interested I have made a quick and dirty fix (I’m not a coder, be gentle!) attached[pse_poe.txt the modified file. It works flawlessly for my environment! pse_poe.txt (2.6 KB)
I changed your fix a little bit, it also recognize now if the max value is in milliwatt.
My change look for every of the two values if it is over 1k. pse_poe.txt (2.5 KB)
