Hello Community! ![]()
We are pleased to announce the stable release of Checkmk 2.4.
Following thorough internal and beta testing, the new version is now ready for general use.
Here are some highlights:
Notifications – easier than ever to set up
With Checkmk 2.4, configuring notifications becomes more intuitive. We’ve redesigned the entire notification system based on user feedback and experience.
Read more in the blog: Simply smarter notifications – With the new Checkmk Notification Hub | Checkmk
Watch Tanja’s talk on how this feature was developed: The power of community: A guide to community-driven UX - media.ccc.de
OpenTelemetry (OTel) and Prometheus – collect metrics from almost anywhere
We built an OpenTelemetry collector – also possible via Prometheus endpoint – to monitor a wider range of systems.
Please note: This feature is still experimental and has some limitations. You’re welcome to contribute to its development here:
https://forum.checkmk.com/t/help-shape-opentelemetry-in-checkmk/52810/1
Monitoring cloud environments? The new Quick Setup helps you get started faster
If you monitor resources in AWS, Azure, or GCP, there’s now a dedicated setup wizard to guide you.
Dynamic Host Management – better support for changing infrastructures
For environments with frequently changing hosts, such as Kubernetes pods or VMs, the improved dynamic host management helps detect and manage them more reliably and efficiently.
Synthetic Monitoring – managed robots and keyword monitoring
The new automation features streamline test environment setup: upload and configure test robots via the web UI, manage them centrally, and deploy across Linux and Windows systems using the Agent Bakery.
The new KPI monitoring feature lets you track key steps and keywords within tests and turn them into individual services or status indicators – all directly in the Checkmk interface.
Distributed piggyback – works across sites
Previously, piggyback data could only be used if all relevant hosts were on the same site. With Checkmk 2.4, piggyback hosts can be monitored across distributed setups.
These are just a few of the updates in Checkmk 2.4.
You can find the full list of improvements and changes on the release notes page.
Join us for the Checkmk Conference #11 in-person or online to learn more about the new features and ask any questions you have!
