I plan to build a CheckMK Enterprise Instance.
My Goal is to have two CheckMK Servers which one is the Master and one is on Standby, if the Master goes down. CheckMK will be installed on two Linux VMs.
I have seen the Topic from two years ago, but wanted to ask, if this is still the case?
Is there no way to have high availlability if you install CheckMK on your own Linux VM, only on the CheckMK Appliance?
I have three Pacemaker/Corosync CMK clusters running. It is only the self made setup as i need there acitve-active clusters with separate sites on every node.
The Pacemaker/Corosync setup is based on the description from Simon Meggle
If i need only a HA setup i take also the appliance or virtual appliance of CMK.
