Fortsetzung der Diskussion von (Docker) 2.0 Docker crashes, 1.5 stable:
CMK version: docker raw 2.1.0-latest
OS version: UNRAID 6.12.5
I just noticed that the CheckMK RAW Docker Container (tested 2.1.0-latest) works on UNRAID if I mount the docker data persistent folder directly via the /mnt/cache/appdata/...
Pool and thus avoiding FUSE Mount via /mnt/user/appdata
Docker Container Path Example: /omd/sites
→ /mnt/cache/appdata/checkmkraw
As others have reported, the container “hangs” and will not shut down if using the default /mnt/user/appdata
path using FUSE: (Docker) 2.0 Docker crashes, 1.5 stable
Maybe this will help UNRAID Users like me
