Hi, I am interested in remote git for checkmk configuration.
In general: repo in Azure DevOps, authorization via ssh, and post commit hook.
Issue passwords.mk file is committed too , and I don’t wan’t to keep that info in git.
Edited by hands .gitignore in folder is overwritten by mk and file committed again.
Question: how to permanently exclude password.mk from git?
You could try setting up the site users’ .gitignore file and prefix the line with a !
, that should instruct it to override the gitignore supplied by cmk, eventhough it’s on a deeper level.
Instead of a .gitignore
file (which usually is checked in) you could create/edit the local file .git/info/exclude
. The file has the same syntax as the .gitignore
files but is NOT checked in. It’s just local to the repository. I haven’t tried but I strongly doubt checkmk will overwrite this file.
Also, you wil have to untrack passwords.mk
git rm --cached path/to/passwords.mk
git commit -m "untrack passwords.mk"
mk just ignores it, devs hardcoded “git add --all”. Support tells that fixing this is a paid feature …
Hi, maybe you can use a pre-commit hook to remove the password file before the commit:
The
pre-commit
hook is run first, before you even type in a commit message. It’s used to inspect the snapshot that’s about to be committed, to see if you’ve forgotten something, to make sure tests run, or to examine whatever you need to inspect in the code. Exiting non-zero from this hook aborts the commit, although you can bypass it withgit commit --no-verify
. You can do things like check for code style (runlint
or something equivalent), check for trailing whitespace (the default hook does exactly this), or check for appropriate documentation on new methods.
