Anyone can give me a hint what is here the problem?
Is it possible to configure checkmk so that if these two checks are on an error, the icon in NagVis is green?
please check you configuration of the host inside wato. You need to disable to check the agent too, beside of snmp.
to be a bit more informative:
At the service Check_MK inside the brackets [] you can see the data source programs used to monitor the host. You are monitoring your host via agent and SNMP, but your host only supports SNMP. You can tell checkmk not to try to ask the agent (where the connection refused come from)
Just run the check again. Default value is every 4 hours I guess. If you run the check again it will turn green.
Side information: the inventory service will scan your hosts for unmonitored or vanished services but do this only several hours because your data source program output is run though all checks, which produce some load.
