Citrix Monitoring
I am trying to provide a Citrix environment with automatic agent updates.
Each Citrix Worker is more or less a clone of the Master Server. Is there a way to then provide them with automatic updates without error messages in the update summary because the individual workers cannot load updates?
Is the Citrix environment static, or are the workers redeployed from the master image in regular intervals?
they get redeployed every night.
Then make sure your master image always the most recent agent and forget about automatic agent updates. It would be possible to do them, but that involves quite some work and does not give you any advantage.
I get the idea, I was there too and depending on the people building the master image you cannot quickly change something, but that a problem you need to solve as a monitoring admin.
P.S.: You might find this helpful: Citrix XenApp Monitoring
