I just pull’ed the docker image and started it up for the first time.
But its not loading in the browser witht he given url.
When i look at the logs, nagios fails to start, and the startup process is restarted and fails agian.
### CREATING SITE 'cmk'
Adding /opt/omd/sites/cmk/tmp to /etc/fstab.
Going to set TMPFS to off.
Temporary filesystem already mounted
Updating core configuration...
Generating configuration for core (type nagios)...Precompiling host checks...OK
OK
Created new site cmk with version 2.0.0p6.cre.
The site can be started with omd start cmk.
The default web UI is available at http://73cf19ce0994/cmk/
The admin user for the web applications is cmkadmin with password: QsSJNer4
For command line administration of the site, log in with 'omd su cmk'.
After logging in, you can change the password for cmkadmin with 'htpasswd etc/htpasswd cmkadmin'.
### STARTING XINETD
[....] Starting internet superserver: xinetde7[ ok e8.
### STARTING SITE
Starting mkeventd...OK
Starting rrdcached...OK
Starting npcd...OK
Starting nagios.............ERROR
Starting apache...OK
Starting redis...OK
Initializing Crontab...OK
Any way do debug further?
Other images works fine
CheckMK Version: 2.0.0p6
Edition: RAW
Host: Macbook
I accessed the cli and ran ‘omd status’ and the apache + nagios was not running.
Not able to view the logs as the docker restarts, with the last lines on the run command
