Hello!
i’m looking for a way to create custom active check like the one that are available here
i was this here, it’s quite straight forward to create the web part, but how do i create my own check and map it to this one?
Hello!
An active check is a program executed from your check_mk server that will execute code as you designed it and will evaluate health based on execution code. Pretty much like a local check.
I believe that if you download some examples from exchange.checkmk.com will guide you through what you need.
Resuming :
You’ll need an wato plugin to “draw” the GUI part;
You’ll need a check file to process what you set on that GUI part (argument parse);
The active check it-self;
Optionally, you might want to set metrics plugins for graph purposes.
Download this example (i found it to be very simple to understand (pathing, files, etc)) :
https://exchange.checkmk.com/p/dnsx
Cheers,
Hello!,
Thanks for the suggestion, this will work on all Cmk versions ? 1.2 1.6 and 2.0 ? because we have multiple versions installed on multiple sites!
Best Regards
I truly believe so
Hello Ricardo,
Sorry for the hassle, i’m fixed the WATO file, i did the following:
#!/usr/bin/python
group = “activechecks”
register_rule(group,
“active_checks:esim_profile”,
Tuple(
title=(“Check Esim Profile Download”),
help=(“Check the Esim profile download steps, Internet, WAF and APP”),
elements=[
TextAscii(
title=(“Link(URL):”),
allow_empty=False,
help=(‘The URL for the operator.’)),
TextAscii(
title=(“Domain Name:”),
allow_empty=False,
help=(‘The Domain Name you want to Query.’)),
match=‘all’
when the GUI appeared when i add a check and click apply i get the following error:
Internal automation error: Error running automation call restart (exit code 1), error:
An error occurred: Error creating configuration: 'NoneType' object has no attribute 'replace'
File "/omd/sites/montyuk/lib/python3/cmk/gui/wato/pages/automation.py", line 168, in _execute_automation_command
html.write(repr(automation.execute(automation.get_request())))
File "/omd/sites/montyuk/lib/python3/cmk/gui/wato/pages/activate_changes.py", line 666, in execute
return cmk.gui.watolib.activate_changes.execute_activate_changes(request.domains)
File "/omd/sites/montyuk/lib/python3/cmk/gui/watolib/activate_changes.py", line 1781, in execute_activate_changes
warnings = domain_class().activate()
File "/omd/sites/montyuk/lib/python3/cmk/gui/watolib/config_domains.py", line 60, in activate
return check_mk_local_automation(config.wato_activation_method)
File "/omd/sites/montyuk/lib/python3/cmk/gui/watolib/automations.py", line 143, in check_mk_local_automation
raise _local_automation_failure(command=command,
cmk.utils.exceptions.MKGeneralException: Error running automation call restart (exit code 1), error:
any hint?
Thanks!
@moritz @joerg.herbel
would one of you care to take a look?
You could look at the output of “cmk --debug -U” to see what’s going on. But this looks very old, a modern WATO plugin should look like this:
#!/usr/bin/env python3
# -*- coding: utf-8 -*-
# Copyright (C) 2019 tribe29 GmbH - License: GNU General Public License v2
# This file is part of Checkmk (https://checkmk.com). It is subject to the terms and
# conditions defined in the file COPYING, which is part of this source code package.
"""WATO ruleset for special agent exchange
This file is part of the tribe29 development training.
This file goes into ~MySITE/local/share/check_mk/web/plugins/wato.
from cmk.gui.i18n import _
from cmk.gui.plugins.wato import HostRulespec, rulespec_registry
from cmk.gui.plugins.wato.active_checks import RulespecGroupActiveChecks
from cmk.gui.valuespec import (
Dictionary,
Integer,
Tuple,
def _valuespec_check_exchange():
return Dictionary(
rulespec_registry.register(
HostRulespec(
group=RulespecGroupActiveChecks,
name="active_checks:exchange",
valuespec=_valuespec_check_exchange,
Dear @moritz,
it would be great if there is an example somewhere i can have hints on, i tried the following:
Dictionary,
Integer,
Tuple,
def _valuespec_check_esim_profile():
return Dictionary(
title=_("Check Esim Profile Download"),
help=_("Check the Esim profile download steps, Internet, WAF and APP"),
elements=[
TextAscii(
title=_("Link(URL):"),
allow_empty=False,
help=_('The URL for the operator.')),
TextAscii(
title=_("Domain Name:"),
allow_empty=False,
help=_('The Domain Name you want to Query.')),
HostRulespec(
name="active_checks:esim_profile",
valuespec=_valuespec_check_esim_profile,
i’m getting the following error:
File "/omd/sites/montyholding/lib/python3/cmk/gui/wsgi/applications/checkmk.py", line 165, in _process_request
response = page_handler()
File "/omd/sites/montyholding/lib/python3/cmk/gui/wsgi/applications/utils.py", line 59, in _call_auth
func()
File "/omd/sites/montyholding/lib/python3/cmk/gui/pages.py", line 186, in <lambda>
return (lambda hc: lambda: hc().handle_page())(handle_class)
File "/omd/sites/montyholding/lib/python3/cmk/gui/pages.py", line 48, in handle_page
self.page()
File "/omd/sites/montyholding/lib/python3/cmk/gui/pages.py", line 158, in <lambda>
"page": lambda self: self._wrapped_callable[0]()
File "/omd/sites/montyholding/lib/python3/cmk/gui/wato/page_handler.py", line 93, in page_handler
_wato_page_handler(current_mode, mode_permissions, mode_class)
File "/omd/sites/montyholding/lib/python3/cmk/gui/wato/page_handler.py", line 174, in _wato_page_handler
mode.handle_page()
File "/omd/sites/montyholding/lib/python3/cmk/gui/plugins/wato/utils/base_modes.py", line 157, in handle_page
return self.page()
File "/omd/sites/montyholding/lib/python3/cmk/gui/wato/pages/rulesets.py", line 216, in page
rulesets = watolib.SearchedRulesets(rulesets, self._search_options)
File "/omd/sites/montyholding/lib/python3/cmk/gui/watolib/rulesets.py", line 416, in __init__
self._load_filtered()
File "/omd/sites/montyholding/lib/python3/cmk/gui/watolib/rulesets.py", line 425, in _load_filtered
if ruleset.matches_search_with_rules(self._search_options):
File "/omd/sites/montyholding/lib/python3/cmk/gui/watolib/rulesets.py", line 574, in matches_search_with_rules
if not self.matches_ruleset_search_options(search_options):
File "/omd/sites/montyholding/lib/python3/cmk/gui/watolib/rulesets.py", line 621, in matches_ruleset_search_options
if not _match_search_expression(search_options, "ruleset_title", self.title()):
File "/omd/sites/montyholding/lib/python3/cmk/gui/watolib/rulesets.py", line 699, in title
return self.rulespec.title
File "/omd/sites/montyholding/lib/python3/cmk/gui/watolib/rulespecs.py", line 436, in title
return self.valuespec.title()
Best Regards.
In your case i looks like a problem with the returned Dictionary.
A valuespec section from ssh active check looks like this.
def _valuespec_active_checks_ssh():
return Dictionary(
title=_("Check SSH service"),
help=_("This rulset allow you to configure a SSH check for a host"),
elements=[
("description", TextUnicode(title=_("Service Description"),)),
("port",
Integer(title=_("TCP port number"),
default_value=22,
("timeout",
Integer(title=_("Connect Timeout"),
help=_("Seconds before connection times out"),
default_value=10,
("remote_version",
TextAscii(
title=_("Version of Server"),
help=_("Warn if string doesn't match expected server version (ex: OpenSSH_3.9p1)"),
("remote_protocol",
TextAscii(
title=_("Protocol of Server"),
help=_("Warn if protocol doesn't match expected protocol version (ex: 2.0)"),
HostRulespec(
group=RulespecGroupIntegrateOtherServices,
match_type="all",
name="active_checks:ssh",
valuespec=_valuespec_active_checks_ssh,
Hello Guys! sorry for the hassle! but it’s either me or either me
… i did exactly what you provided in the example here the code below:
Dictionary,
Integer,
Tuple,
TextAscii,
return Dictionary(
elements=[
("link",
TextAscii(
allow_empty=False)),
("domain",
TextAscii(
HostRulespec(
match_type="all",
now i can see the ActiveCheck in the WATO
Got invalid data:
Now the problem lies i think at the wrapper code for your active check.
Every active check has a small code part inside the /share/check_mk/checks/ folder and is processed at the time of activating the changes. Your code needs to be inside the corresponding local folder.
Hello @andreas-doehler the check actualy is quite simple for now check it below and i placed it in local/share/check_mk/checks/
#!/usr/bin/python
def check_esim_profile_args(params):
description, settings = params
print(description, settings)
def check_esim_profile_desc(params):
print(params)
active_check_info['esim_profile'] = {
"command_line": '$USER2$/check_esim_profile $ARG1$',
"argument_function": check_esim_profile_args,
"service_description" : check_esim_profile_desc,
"has_perfdata" : True,
i added the argument_function and the command_line just trying to copy the check_dns but i don’t need any args i just want to pass the values from the WATO to the check file.
A-ha!
Those two Functions have to return something. You are not returning anything, which means python implicityly returns “None”. The Backend expects a string, tries to sanitize it (using “replace”), and crashes.
Try
#!/usr/bin/python
# assuming 'your_actvice_check --option an-option-value YourHOST' is how you call your active check
return ["--option", "an-option-value", host_name()]
return "This is my service description"
Ayeee this is it, sorry i forgot to tell that i was able to implement the active check successfully thanks you all!
another note i found this handy tutorial here too:
https://www.steinkogler.org/2016/08/21/check-mk-write-your-own-active-check/
but i have one more question, sorry i’m asking too much but i’m used to custom scripts, but not this active checks, okay the error is gone using your suggestion, but i have another problem, how do i debug this to check how to check is behaving and fix what is required, on normal checks i used cmk -nv --debug /check_esim_profile--detect-plugins={{check_name}} {{sitename}}' i tried to do the same here cmk -nv --debug --detect-plugins=esim_profile CheckMK_MontyHolding but i’m not getting any response from the print instructions.
That is because the active checks are not triggert by cmk HOST.
The above functions are run when the configuration is generated, which you can trigger by cmk -U.
You can then take a look at the final result of the commandline call in the details view of the service (“Service check command”).
