CMK version: 2.2.0p27.cre
OS version: Debian 11
Error message: Plugin exception in MKDockerClient.init: Invalid response from docker daemon: key “ApiVersion” is missing.
Checkmk version 2.2.0p27
Updating IPv4 DNS cache for dehya: 172.16.0.66
Trying to acquire lock on /omd/sites/Home/var/check_mk/ipaddresses.cache
Got lock on /omd/sites/Home/var/check_mk/ipaddresses.cache
Releasing lock on /omd/sites/Home/var/check_mk/ipaddresses.cache
Released lock on /omd/sites/Home/var/check_mk/ipaddresses.cache
+ FETCHING DATA
Source: SourceInfo(hostname='dehya', ipaddress='172.16.0.66', ident='piggyback', fetcher_type=<FetcherType.PIGGYBACK: 4>, source_type=<SourceType.HOST: 1>)
[cpu_tracking] Start [7f183d4111d0]
Read from cache: NoCache(dehya, path_template=/dev/null, max_age=MaxAge(checking=0.0, discovery=0.0, inventory=0.0), simulation=False, use_only_cache=False, file_cache_mode=1)
No piggyback files for 'dehya'. Skip processing.
No piggyback files for '172.16.0.66'. Skip processing.
[cpu_tracking] Stop [7f183d4111d0 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
+ PARSE FETCHER RESULTS
HostKey(hostname='dehya', source_type=<SourceType.HOST: 1>) -> Add sections: []
Received no piggyback data
[cpu_tracking] Start [7f183c958590]
value store: synchronizing
Trying to acquire lock on /omd/sites/Home/tmp/check_mk/counters/dehya
Got lock on /omd/sites/Home/tmp/check_mk/counters/dehya
Releasing lock on /omd/sites/Home/tmp/check_mk/counters/dehya
Released lock on /omd/sites/Home/tmp/check_mk/counters/dehya
[cpu_tracking] Stop [7f183c958590 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
[piggyback] Success (but no data found for this host), execution time 0.0 sec | execution_time=0.000 user_time=0.000 system_time=0.000 children_user_time=0.000 children_system_time=0.000 cmk_time_agent=0.000
This started happening last Friday. It used to work fine until then. If I run curl -s --unix-socket /var/run/docker.sock http://localhost/version on the client I get this:
{"Platform":{"Name":""},"Components":[{"Name":"Engine","Version":"24.0.7-ce","Details":{"ApiVersion":"1.43","Arch":"amd64","BuildTime":"2024-03-08T12:00:00.000000000+00:00","Experimental":"false","GitCommit":"311b9ff0aa93","GoVersion":"go1.20.14","KernelVersion":"5.14.21-150500.55.65-default","MinAPIVersion":"1.12","Os":"linux"}},{"Name":"containerd","Version":"v1.7.10","Details":{"GitCommit":"4e1fe7492b9df85914c389d1f15a3ceedbb280ac"}},{"Name":"runc","Version":"1.1.12","Details":{"GitCommit":"v1.1.12-0-g51d5e94601ce"}},{"Name":"docker-init","Version":"0.2.0_catatonit","Details":{"GitCommit":""}}],"Version":"24.0.7-ce","ApiVersion":"1.43","MinAPIVersion":"1.12","GitCommit":"311b9ff0aa93","GoVersion":"go1.20.14","Os":"linux","Arch":"amd64","KernelVersion":"5.14.21-150500.55.65-default","BuildTime":"2024-03-08T12:00:00.000000000+00:00"}
This clearly shows that the ApiVersion is in there, so I have no idea why this is happening. If anyone has an idea how to fix this it would be great.
