what is the the hostname or the IP address to be given under CHECK STATE OF ELASTICSEARCH (text box Hostnames to query)
and also what is the “Explicit host to given” under condition
is there any special agent plugin to be written
would it just be copying /omd/sites/limon/share/check_mk/agents/special/agent_elasticsearch to /usr/lib/check_mk_agent/plugins/? Do I need to do anything in WATO or will it know to just look at what’s in the directory?
the Hostname to query is the Elasticsearch System where ES is running. The explicit Hosts is the Host where the result relatet to. In normal case the same.
Hello ChristianM,
For us 9200 port is not enabled . Is there any other work around for the same .
Once we enable the rule , other service under that host is getting affected and moving to critical state.
You ca try run the special agent locally on the ES host with the needed CLI options as normal plugin. I think you need a wrapper script to set the options.
Cheers,
Christian
so would it just be copying /omd/sites/limon/share/check_mk/agents/special/agent_elasticsearch to /usr/lib/check_mk_agent/plugins/
or any other script we need to write
The needed options you find when you run “agent_elasticsearch --help”.
Notice: This is not a normal plugin. If you run that as a plugin you need a wrapper script ike:
Actually i followed the step metioned in the below link by creating rule . But because of port 9200 issue the whole service of that host moved to critical.
then now planning to
but what nit sure what changes to be done in the script. can you please share me any examples. if port is not working then how to create a plugin for this without any rule to be create in checkmk
Hello ChristianM
while running “agent_elasticsearch -p 9200 localhost”
getting below error
“agent_elasticsearch: command not found”
our version is 7.19. So not working.
There is no other way to make this as plugin rather than enabling the port 9200. because the requirement is to make another way rather than enabling the port 9200
i am very new to this .Please help me with any other way other than this port enable .
what port is enabled for you? You can change the port in the datasource rule for elasticsearch.
You have to configure “Normal Checkmk agent, all configured special agents” for the host you use in “Explicit hosts” (Section “Data sources” - “Check_MK Agent”).
Hello rb,
Service discovery you mean full scan and automatic refresh (rasa) that Is done after changng the port in the check rule for elastic search .
After that host is showing ping issue .
If we are giving port as 9200 in check rule for elastic search and doing full scan and refresh and activate affected changes , all other service move to unknown and only shows ping service only below is the screenshot for the same.
It looks like your host is configured for “Normal Checkmk agent, or special agent if configured” you need to change this to “Normal Checkmk agent, all configured special agents”.
After you activated the Elasticsearch agent it gets no data anymore for the normal agent, that behavior is correct if the first option is selected for this host.
After this change you go to the command line as the site user and make a “cmk -D hostname”
The output has some lines like this
Type of agent:
TCP: 192.168.0.1:6556
There should also be a line for your Elasticsearch special agent. This line can be executed manually for troubleshooting. You can also extend the option with a “–debug” switch to get a little bit more output.
As @andreas-doehler said:
Check the output from the “cmk -D hostname” command.
Add a “–debug” switch for more details.
There should be both the output for the normal checkmk agent on port 6556 as well as the Elasticsearch special agent.
You can run this ES special agent command manually (again: as the site user!) to further debug it.
Getting below detail .“Nothing related to elastic search special agent”
:~$ cmk -D Hostname -debug
-debug
Addresses: 0.0.0.0
Tags:
Labels:
Host groups: check_mk
Contact groups: check-mk-notify
Agent mode: No agent
Type of agent:
Process piggyback data from /tmp/check_mk/piggyback/-debug
PING only
Services:
checktype item params description groups
Addresses:
Tags:
Labels:
Contact groups: all, check-mk-notify
Agent mode: Normal Checkmk agent, all configured special agents
Type of agent:
TCP: ip:portnumber
Program: /check_mk/agents/special/agent_elasticsearch ‘-P’ ‘https’ ‘-m’ ‘cluster_health nodes stats’ ‘-p’ port number ‘hostname’
/tmp/check_mk/piggyback/hostname
"Nothing I am getting related Elastic search special agent "
