I would like to create a custom check, which measures the size of subfolders of a specific folder and shows them in a single graph (one line per folder). This is somehow similar to How to combine all same metrics of a series of hosts into a custom graph in one go but I would prefer not to have to create a custom graph. Instead all the metrics should be in the same graph by default (there are lots of subfolders…).
Additionally, the number of measured subfolders can change, when folders are deleted or new folders are created.
Is such a setup possible at all? I imagine, that others have had the same requirement in the past, but I was not able to find any suitable posts in the forum.
@MarcS sorry for the delay. that doesn’t sound easy to solve. Thanks anyway for the valuable pointers. I’ll see if I want to implement this in checkmk at all or it an other solution might come in handier
