Hi, i am a put puzzled here - i have several sites in my Setup which all report normaly except one - giving no error inside the checkmk gui, but in the logs, you see the error shown above.
The Liveproxy Stae shows that everything is in order - except the Last Update of the Inventory, which never happened.
On the remote site everything is in order - HW/SW Inventory shows up and can be accessed
after updating all sites & master instances to 2.3.0p6 the issue is resolved - HW/SW Inventory is accesible from the master instance - not sure thou if it was the update, or the restart of all instances.
