We are having some problems like UNKN status for some Interface checks which are working via SNMP from ESXi hosts. We have the summary message “Item not found in monitoring data”.
Yesterday we had 8 UNKN status for some network interfaces (some vethernet#### and vfc###) simultaneously – four interfaces at each host, at same time per host.
Today we got another 8 UNKN status checks for another two hosts appeared today, also at same time per hosts.
All services (including those vethernet and vfc) are active. The manual SNMP requests returned ifOperStatus for each of the interfaces are returned. SNMP ifTable also returned, nothing suspicious there.
I know that SNMP can be “hit or miss” (tends to timeout or not respond on hosts). While we’re just doing same for piggyback data from the DRAC (Dell hosts), the DRACs stop repsonding everyday, unfortunately, the nodes aren’t in sync. Maybe at some point, I’ll write specific “time” rules for each, but anytime a node goes into maint and reboot, the time will be different when the DRACs go on their “coffee break”.
With that said, we have other devices that have difficulty with SNMP, like printers and heavily stacked switches. In the switch case, I just disabled the notifications. In the printer case, I’m trying Status of the Check_MK services, rules… but we’ll see.
Beside the problem @cjcox already mentioned i would say
is a bad combination. If you query the ESX host with the special agent you should get the traffic of the hardware interfaces and this traffic should also be valid.
This is correct “vethernet##” and “vfc##” are virtual interfaces only existing temporally. If you move one virtual machine to another host some of the interfaces will vanish and if you create some virtal machine you get new ones.
I would prefer to switch of the SNMP on the ESX host and only monitor it with the vSphere API.
