Discussions and feedback on the new Jira special agent that is part of the Feature Pack 1
UPDATE: Testing is now over, thanks to all who gave their feedback! To install plug-ins that are part of the Feature Pack, please refer to this entry on the manual.
when using the jira agent with wrong credentials a traceback is printed and the cmk host is broken
File "/omd/sites/cmk/local/share/check_mk/agents/special/agent_jira", line 312, in <module>
sys.exit(main())
File "/omd/sites/cmk/local/share/check_mk/agents/special/agent_jira", line 48, in main
jira = _handle_jira_connection(args)
File "/omd/sites/cmk/local/share/check_mk/agents/special/agent_jira", line 73, in _handle_jira_connection
max_retries=0,
File "/omd/sites/cmk/lib/python/jira/client.py", line 472, in __init__
si = self.server_info()
File "/omd/sites/cmk/lib/python/jira/client.py", line 2133, in server_info
j = self._get_json('serverInfo')
File "/omd/sites/cmk/lib/python/jira/client.py", line 2549, in _get_json
r = self._session.get(url, params=params)
File "/omd/sites/cmk/lib/python/jira/resilientsession.py", line 151, in get
return self.__verb('GET', url, **kwargs)
File "/omd/sites/cmk/lib/python/jira/resilientsession.py", line 147, in __verb
raise_on_error(response, verb=verb, **kwargs)
File "/omd/sites/cmk/lib/python/jira/resilientsession.py", line 57, in raise_on_error
r.status_code, error, r.url, request=request, response=r, **kwargs)
jira.exceptions.JIRAError: JiraError HTTP 401 url: https://jira.sixt.com/rest/api/2/serverInfo
