from the cmk -h host4
<<<check_mk>>>
Version: 1.6.0p16
AgentOS: linux
Hostname: host4
AgentDirectory: /etc/check_mk
DataDirectory: /var/lib/check_mk_agent
SpoolDirectory: /var/lib/check_mk_agent/spool
PluginsDirectory: /usr/lib/check_mk_agent/plugins
LocalDirectory: /usr/lib/check_mk_agent/local
<<<docker_node_info:sep(124)>>>
@docker_version_info|{}
{“Critical”: “Error: mk_docker requires the docker library. Please install it on the monitored system (pip install docker).”}
<<<docker_container_status>>>
{“Status”:“exited”,“Running”:false,“Paused”:false,“Restarting”:false,“OOMKilled”:false,“Dead”:false,“Pid”:0,“ExitCode”:100,“Error”:"",“StartedAt”:“2020-07-21T21:01:18.318045916Z”,“FinishedAt”:“2020-07-21T21:01:21.933180076Z”}
<<<docker_container_node_name>>>
host4
<<<docker_container_labels>>>
<<<docker_container_network>>>
{“Bridge”:"",“SandboxID”:“4579c70945248736753d91337a8121e0eb142a06223cb79a4e363bd1e14d93f5”,“HairpinMode”:false,“LinkLocalIPv6Address”:"",“LinkLocalIPv6PrefixLen”:0,“Ports”:{},“SandboxKey”:"/var/run/docker/netns/4579c7094524",“SecondaryIPAddresses”:null,“SecondaryIPv6Addresses”:null,“EndpointID”:"",“Gateway”:"",“GlobalIPv6Address”:"",“GlobalIPv6PrefixLen”:0,“IPAddress”:"",“IPPrefixLen”:0,“IPv6Gateway”:"",“MacAddress”:"",“Networks”:{“bridge”:{“IPAMConfig”:null,“Links”:null,“Aliases”:null,“NetworkID”:“1d4bb1458a654b1344d4b9216db065aae73a463743fba38a721deead216bed7f”,“EndpointID”:"",“Gateway”:"",“IPAddress”:"",“IPPrefixLen”:0,“IPv6Gateway”:"",“GlobalIPv6Address”:"",“GlobalIPv6PrefixLen”:0,“MacAddress”:"",“DriverOpts”:null}}}
<<<<367ec1ac0625>>>>
{“Status”:“exited”,“Running”:false,“Paused”:false,“Restarting”:false,“OOMKilled”:false,“Dead”:false,“Pid”:0,“ExitCode”:100,“Error”:"",“StartedAt”:“2020-07-21T20:55:53.035956717Z”,“FinishedAt”:“2020-07-21T20:55:56.94505554Z”}
host4
{“Bridge”:"",“SandboxID”:“8d7611224ff0510c9a6ae04fc7cc73d472fab51e891110748d68696e3119aa4d”,“HairpinMode”:false,“LinkLocalIPv6Address”:"",“LinkLocalIPv6PrefixLen”:0,“Ports”:{},“SandboxKey”:"/var/run/docker/netns/8d7611224ff0",“SecondaryIPAddresses”:null,“SecondaryIPv6Addresses”:null,“EndpointID”:"",“Gateway”:"",“GlobalIPv6Address”:"",“GlobalIPv6PrefixLen”:0,“IPAddress”:"",“IPPrefixLen”:0,“IPv6Gateway”:"",“MacAddress”:"",“Networks”:{“bridge”:{“IPAMConfig”:null,“Links”:null,“Aliases”:null,“NetworkID”:“1d4bb1458a654b1344d4b9216db065aae73a463743fba38a721deead216bed7f”,“EndpointID”:"",“Gateway”:"",“IPAddress”:"",“IPPrefixLen”:0,“IPv6Gateway”:"",“GlobalIPv6Address”:"",“GlobalIPv6PrefixLen”:0,“MacAddress”:"",“DriverOpts”:null}}}
{“Status”:“running”,“Running”:true,“Paused”:false,“Restarting”:false,“OOMKilled”:false,“Dead”:false,“Pid”:29519,“ExitCode”:0,“Error”:"",“StartedAt”:“2020-04-29T12:07:42.953994418Z”,“FinishedAt”:“0001-01-01T00:00:00Z”}
host4
{“com.docker.compose.config-hash”:“3b6821a7ca74520e5b578b26f44ca8cc93ae136e74d8b003f6aa23c420d6e6f5”,“com.docker.compose.container-number”:“1”,“com.docker.compose.oneoff”:“False”,“com.docker.compose.project”:“infrastructure”,“com.docker.compose.service”:“cron”,“com.docker.compose.version”:“1.24.0”}
{“Bridge”:"",“SandboxID”:“375109dd8e44d76db2ef86cc1d3942483fec268f627f7f21ca68ab01a8e6543c”,“HairpinMode”:false,“LinkLocalIPv6Address”:"",“LinkLocalIPv6PrefixLen”:0,“Ports”:{},“SandboxKey”:"/var/run/docker/netns/375109dd8e44",“SecondaryIPAddresses”:null,“SecondaryIPv6Addresses”:null,“EndpointID”:“8e176dacf0dbe5fb12d3d51e9a60c6201cb2bb7fd5870634f71349f616a120e2”,“Gateway”:“172.17.0.1”,“GlobalIPv6Address”:"",“GlobalIPv6PrefixLen”:0,“IPAddress”:“172.17.0.7”,“IPPrefixLen”:16,“IPv6Gateway”:"",“MacAddress”:“02:42:ac:11:00:07”,“Networks”:{“bridge”:{“IPAMConfig”:null,“Links”:null,“Aliases”:null,“NetworkID”:“1d4bb1458a654b1344d4b9216db065aae73a463743fba38a721deead216bed7f”,“EndpointID”:“8e176dacf0dbe5fb12d3d51e9a60c6201cb2bb7fd5870634f71349f616a120e2”,“Gateway”:“172.17.0.1”,“IPAddress”:“172.17.0.7”,“IPPrefixLen”:16,“IPv6Gateway”:"",“GlobalIPv6Address”:"",“GlobalIPv6PrefixLen”:0,“MacAddress”:“02:42:ac:12:00:04”,“DriverOpts”:null}}}
<<<<2d501225438d>>>>
{“Status”:“running”,“Running”:true,“Paused”:false,“Restarting”:false,“OOMKilled”:false,“Dead”:false,“Pid”:15877,“ExitCode”:0,“Error”:"",“StartedAt”:“2020-04-09T11:39:40.61448215Z”,“FinishedAt”:“0001-01-01T00:00:00Z”}
host4
{“com.docker.compose.config-hash”:“067dab4b74c3bf2047a3262a1aa1773ea31314d24ba7baa9c43f996f23c90aff”,“com.docker.compose.container-number”:“1”,“com.docker.compose.oneoff”:“False”,“com.docker.compose.project”:“infrastructure”,“com.docker.compose.service”:“php”,“com.docker.compose.version”:“1.24.0”}
{“Bridge”:"",“SandboxID”:“ce07f5b2cb99d63175d9aa94e4a937867de4580b27b5338e32843ed1a4c80b26”,“HairpinMode”:false,“LinkLocalIPv6Address”:"",“LinkLocalIPv6PrefixLen”:0,“Ports”:{“9000/tcp”:[{“HostIp”:“0.0.0.0”,“HostPort”:“9000”}]},“SandboxKey”:"/var/run/docker/netns/ce07f5b2cb99",“SecondaryIPAddresses”:null,“SecondaryIPv6Addresses”:null,“EndpointID”:“40fe8bdd244544c535310ee9b6a2eae7f6eefba70709712379aae35a210b72b5”,“Gateway”:“172.17.0.1”,“GlobalIPv6Address”:"",“GlobalIPv6PrefixLen”:0,“IPAddress”:“172.17.0.5”,“IPPrefixLen”:16,“IPv6Gateway”:"",“MacAddress”:“02:42:ac:11:00:05”,“Networks”:{“bridge”:{“IPAMConfig”:null,“Links”:null,“Aliases”:null,“NetworkID”:“1d4bb1458a654b1344d4b9216db065aae73a463743fba38a721deead216bed7f”,“EndpointID”:“40fe8bdd244544c535310ee9b6a2eae7f6eefba70709712379aae35a210b72b5”,“Gateway”:“172.17.0.1”,“IPAddress”:“172.17.0.5”,“IPPrefixLen”:16,“IPv6Gateway”:"",“GlobalIPv6Address”:"",“GlobalIPv6PrefixLen”:0,“MacAddress”:“02:42:ac:11:00:05”,“DriverOpts”:null}}}
{“Status”:“running”,“Running”:true,“Paused”:false,“Restarting”:false,“OOMKilled”:false,“Dead”:false,“Pid”:14553,“ExitCode”:0,“Error”:"",“StartedAt”:“2020-04-01T18:31:19.111802855Z”,“FinishedAt”:“0001-01-01T00:00:00Z”}
host4
{“com.docker.compose.config-hash”:“95396c828165f61db8df40a7a1961f5a1dc65c8f790435980421291f1da53c03”,“com.docker.compose.container-number”:“1”,“com.docker.compose.oneoff”:“False”,“com.docker.compose.project”:“infrastructure”,“com.docker.compose.service”:“phpmautic”,“com.docker.compose.version”:“1.24.0”}
{“Bridge”:"",“SandboxID”:“b926cf2899ad1c414fec59a00e722a5885c4f4595c72c60c6075b226b5351837”,“HairpinMode”:false,“LinkLocalIPv6Address”:"",“LinkLocalIPv6PrefixLen”:0,“Ports”:{“9000/tcp”:null},“SandboxKey”:"/var/run/docker/netns/b926cf2899ad",“SecondaryIPAddresses”:null,“SecondaryIPv6Addresses”:null,“EndpointID”:“bb524548dd131f63a40fa86d5ec511b09e83ad09c79fb1a413e74eb9a4b2b253”,“Gateway”:“172.17.0.1”,“GlobalIPv6Address”:"",“GlobalIPv6PrefixLen”:0,“IPAddress”:“172.17.0.4”,“IPPrefixLen”:16,“IPv6Gateway”:"",“MacAddress”:“02:42:ac:11:00:04”,“Networks”:{“bridge”:{“IPAMConfig”:null,“Links”:null,“Aliases”:null,“NetworkID”:“1d4bb1458a654b1344d4b9216db065aae73a463743fba38a721deead216bed7f”,“EndpointID”:“bb524548dd131f63a40fa86d5ec511b09e83ad09c79fb1a413e74eb9a4b2b253”,“Gateway”:“172.17.0.1”,“IPAddress”:“172.17.0.4”,“IPPrefixLen”:16,“IPv6Gateway”:"",“GlobalIPv6Address”:"",“GlobalIPv6PrefixLen”:0,“MacAddress”:“02:42:ac:11:00:09”,“DriverOpts”:null}}}
{“Status”:“running”,“Running”:true,“Paused”:false,“Restarting”:false,“OOMKilled”:false,“Dead”:false,“Pid”:14526,“ExitCode”:0,“Error”:"",“StartedAt”:“2020-04-01T18:31:19.297919915Z”,“FinishedAt”:“0001-01-01T00:00:00Z”}
host4
{“com.docker.compose.config-hash”:“83e8280eea53847f563df1540e8701824cda55ec8686551086d509a9642baf4f”,“com.docker.compose.container-number”:“1”,“com.docker.compose.oneoff”:“False”,“com.docker.compose.project”:“infrastructure”,“com.docker.compose.service”:“phptraderstocht”,“com.docker.compose.version”:“1.24.0”}
{“Bridge”:"",“SandboxID”:“5263e9e3c2fb1159ab44ad1ea3e24ae544a4b74f61abf4b449c54bbff84f7125”,“HairpinMode”:false,“LinkLocalIPv6Address”:"",“LinkLocalIPv6PrefixLen”:0,“Ports”:{“9000/tcp”:null},“SandboxKey”:"/var/run/docker/netns/5263e9e3c2fb",“SecondaryIPAddresses”:null,“SecondaryIPv6Addresses”:null,“EndpointID”:“dfd4bef0c615f786af597ba4ba1644926d4062d8b16585fbf7939a8e0a84bcac”,“Gateway”:“172.17.0.1”,“GlobalIPv6Address”:"",“GlobalIPv6PrefixLen”:0,“IPAddress”:“172.17.0.2”,“IPPrefixLen”:16,“IPv6Gateway”:"",“MacAddress”:“02:42:ac:13:00:09”,“Networks”:{“bridge”:{“IPAMConfig”:null,“Links”:null,“Aliases”:null,“NetworkID”:“1d4bb1458a654b1344d4b9216db065aae73a463743fba38a721deead216bed7f”,“EndpointID”:“dfd4bef0c615f786af597ba4ba1644926d4062d8b16585fbf7939a8e0a84bcac”,“Gateway”:“172.17.0.1”,“IPAddress”:“172.17.0.2”,“IPPrefixLen”:16,“IPv6Gateway”:"",“GlobalIPv6Address”:"",“GlobalIPv6PrefixLen”:0,“MacAddress”:“02:42:ac:13:00:09”,“DriverOpts”:null}}}
{“Status”:“running”,“Running”:true,“Paused”:false,“Restarting”:false,“OOMKilled”:false,“Dead”:false,“Pid”:7356,“ExitCode”:0,“Error”:"",“StartedAt”:“2020-03-26T19:21:41.470192965Z”,“FinishedAt”:“0001-01-01T00:00:00Z”}
host4
{“com.docker.compose.config-hash”:“eab11decfc410380338cc9cb9cf62f77abd6fbe1ebc39d3cd7206f52a797fd45”,“com.docker.compose.container-number”:“1”,“com.docker.compose.oneoff”:“False”,“com.docker.compose.project”:“infrastructure”,“com.docker.compose.service”:“nginx”,“com.docker.compose.version”:“1.24.0”,“maintainer”:“NGINX Docker Maintainers docker-maint@nginx.com”}
{“Bridge”:"",“SandboxID”:“b6d230ac01f9d697abb7bffbf916a34ce7c6296114884a2e1ee00aecc28f493f”,“HairpinMode”:false,“LinkLocalIPv6Address”:"",“LinkLocalIPv6PrefixLen”:0,“Ports”:{“443/tcp”:[{“HostIp”:“0.0.0.0”,“HostPort”:“443”}],“80/tcp”:[{“HostIp”:“0.0.0.0”,“HostPort”:“80”}]},“SandboxKey”:"/var/run/docker/netns/b6d230ac01f9",“SecondaryIPAddresses”:null,“SecondaryIPv6Addresses”:null,“EndpointID”:“41bfbe343aa9ddd1d765b921c25b651f0566c95c6af0059a4d3a4d0a00ce4933”,“Gateway”:“172.17.0.1”,“GlobalIPv6Address”:"",“GlobalIPv6PrefixLen”:0,“IPAddress”:“172.17.0.8”,“IPPrefixLen”:16,“IPv6Gateway”:"",“MacAddress”:“02:42:ac:41:00:08”,“Networks”:{“bridge”:{“IPAMConfig”:null,“Links”:null,“Aliases”:null,“NetworkID”:“1d4bb1458a654b1344d4b9216db065aae73a463743fba38a721deead216bed7f”,“EndpointID”:“41bfbe343aa9ddd1d765b921c25b651f0566c95c6af0059a4d3a4d0a00ce4933”,“Gateway”:“172.17.0.1”,“IPAddress”:“172.17.0.8”,“IPPrefixLen”:16,“IPv6Gateway”:"",“GlobalIPv6Address”:"",“GlobalIPv6PrefixLen”:0,“MacAddress”:“02:42:ac:10:00:18”,“DriverOpts”:null}}}
<<<<74e8205281fb>>>>
{“Status”:“running”,“Running”:true,“Paused”:false,“Restarting”:false,“OOMKilled”:false,“Dead”:false,“Pid”:4148,“ExitCode”:0,“Error”:"",“StartedAt”:“2020-04-07T07:22:11.219960112Z”,“FinishedAt”:“2020-04-07T07:17:25.737920707Z”}
host4
{“com.docker.compose.config-hash”:“a7341bf489ff31e3d5964b5e758c5b654245a060938c9391e32ee0381f8bf65e”,“com.docker.compose.container-number”:“1”,“com.docker.compose.oneoff”:“False”,“com.docker.compose.project”:“infrastructure”,“com.docker.compose.service”:“resque”,“com.docker.compose.version”:“1.24.0”}
{“Bridge”:"",“SandboxID”:“b943f600f8e7f3506d0cf13c7ba9c810084ba0c03e7dea6c819112c2c33527a1”,“HairpinMode”:false,“LinkLocalIPv6Address”:"",“LinkLocalIPv6PrefixLen”:0,“Ports”:{},“SandboxKey”:"/var/run/docker/netns/b943f600f8e7",“SecondaryIPAddresses”:null,“SecondaryIPv6Addresses”:null,“EndpointID”:“a6159f7663b9ff09b8a22d0b93f73fb6f9cd42ff23452c232941af2dd1e815d3”,“Gateway”:“172.17.0.1”,“GlobalIPv6Address”:"",“GlobalIPv6PrefixLen”:0,“IPAddress”:“172.17.0.6”,“IPPrefixLen”:16,“IPv6Gateway”:"",“MacAddress”:“02:42:ac:11:00:06”,“Networks”:{“bridge”:{“IPAMConfig”:null,“Links”:null,“Aliases”:null,“NetworkID”:“1d4bb1458a654b1344d4b9216db065aae73a463743fba38a721deead216bed7f”,“EndpointID”:“a6159f7663b9ff09b8a22d0b93f73fb6f9cd42ff23452c232941af2dd1e815d3”,“Gateway”:“172.17.0.1”,“IPAddress”:“172.17.0.6”,“IPPrefixLen”:16,“IPv6Gateway”:"",“GlobalIPv6Address”:"",“GlobalIPv6PrefixLen”:0,“MacAddress”:“02:42:ac:12:00:01”,“DriverOpts”:null}}}
{“Status”:“running”,“Running”:true,“Paused”:false,“Restarting”:false,“OOMKilled”:false,“Dead”:false,“Pid”:4081,“ExitCode”:0,“Error”:"",“StartedAt”:“2020-02-14T17:06:26.68357224Z”,“FinishedAt”:“0001-01-01T00:00:00Z”}
host4
{“com.docker.compose.config-hash”:“3801ea90dbf3677f7c4389e4bec5dec32e0f339a6b1621cc7490a93fb3561937”,“com.docker.compose.container-number”:“1”,“com.docker.compose.oneoff”:“False”,“com.docker.compose.project”:“infrastructure”,“com.docker.compose.service”:“redis”,“com.docker.compose.version”:“1.24.0”}
{“Bridge”:"",“SandboxID”:“dcef7f9e18bd54843aa576a1e2787f3fb226a9eccb8fca37c81902687df2955d”,“HairpinMode”:false,“LinkLocalIPv6Address”:"",“LinkLocalIPv6PrefixLen”:0,“Ports”:{“6379/tcp”:[{“HostIp”:“0.0.0.0”,“HostPort”:“6379”}]},“SandboxKey”:"/var/run/docker/netns/dcef7f9e18bd",“SecondaryIPAddresses”:null,“SecondaryIPv6Addresses”:null,“EndpointID”:“e220aaab9db4180a24498af8ca0837bc3597e275cdc491248554820124ea0a39”,“Gateway”:“172.17.0.1”,“GlobalIPv6Address”:"",“GlobalIPv6PrefixLen”:0,“IPAddress”:“172.17.0.3”,“IPPrefixLen”:16,“IPv6Gateway”:"",“MacAddress”:“02:42:ac:12:00:09”,“Networks”:{“bridge”:{“IPAMConfig”:null,“Links”:null,“Aliases”:null,“NetworkID”:“1d4bb1458a654b1344d4b9216db065aae73a463743fba38a721deead216bed7f”,“EndpointID”:“e220aaab9db4180a24498af8ca0837bc3597e275cdc491248554820124ea0a39”,“Gateway”:“172.17.0.1”,“IPAddress”:“172.17.0.3”,“IPPrefixLen”:16,“IPv6Gateway”:"",“GlobalIPv6Address”:"",“GlobalIPv6PrefixLen”:0,“MacAddress”:“02:42:ac:12:00:13”,“DriverOpts”:null}}}
