Monitoring Squid Proxy
I use the checkmk version 2.x. Is there a way to monitor a Squid proxy here? There used to be a plugin. Unfortunately, this no longer works with the current checkmk version. Does anyone know of alternatives?
Greetings
Karsten
have a look at
There you will find a rewrite of the squid plugin for CMK 2.
Thanks for the info. The website “https://thl-cmk.hopto.org/gitlab/checkmk/various/squid” is not there, what a pity.
@kacon the site should be back online.
I heard about a monitoring tool that can notify in case of unexpected downtime’s :joy: :stuck_out_tongue_winking_eye:
I know one too. Thanks, I was able to download it now and will test it tomorrow. Have a good evening
Karsten
Good Morning,
I have installed the plugin and created the rules, including the new agent. Unfortunately, I don’t see any new services on the Squid host. Have I forgotten something?
best Karsten
Is it perhaps because I am using checkmk version 2.2?
Hi @kacon,
just a quick question. Did you also enable it after installing it? :sweat_smile:
I think it is only 2.1 compatible.
Maybe @thl-cmk can say if it is 2.2 compatible? :slightly_smiling_face:
Regards
Norm
of course I have also enabled it
CMK 2.2 should be ok.
Set levels for Client Requests
Would I need to see these serivces in the host?
  • Set levels for Client Hits
  • Set levels for Server Requests
  • Set levels for Squid CPU usage
  • Set levels for DNS response time
just checked with 2.2.x. There seems to be an issue with the bakery, 2.2.x does not copy the squid plugin in the agent package :-(. On 2.1.x its ok. Not sure yet why…
As workaround, you can copy the squid agent plugin from
~/local/share/check_mk/agents/plugins to your squid server under /usr/lib/check_mk_agent/plugins.
@kacon the plugin should now work with CMK2.2x as well, at least on my system it does :wink: . After updating you need to bake the agent again.
Thank you, I will try it out.
Did anyone try and did it work?
For me (running CheckMK 2.2.0p12 RAW) it doesn´t.
I copied the “squid” file to /usr/lib/check_mk_agent/plugins and changed the rights - but nothing happend.
I am pretty new to this, so maybe I am doing something wrong ?
yes works here :wink:
you can try to run the script localy
sudo /usr/lib/check_mk_agent/plugins/squid
<<<squid:sep(0)>>>
Content-Type: text/plain;charset=utf-8
sample_start_time = 1698510032.974436 (Sat, 28 Oct 2023 16:20:32 GMT)
sample_end_time = 1698510332.983231 (Sat, 28 Oct 2023 16:25:32 GMT)
client_http.requests = 0.013333/sec
client_http.hits = 0.000000/sec
client_http.errors = 0.000000/sec
if this works, check on the cmk server as site user
OMD[build]:~$ cmk -d your-squid-host-name | grep -A10 "<<<squid:sep(0)>>>"
<<<squid:sep(0)>>>
sample_start_time = 1698510212.979360 (Sat, 28 Oct 2023 16:23:32 GMT)
sample_end_time = 1698510512.988730 (Sat, 28 Oct 2023 16:28:32 GMT)
client_http.requests = 0.010000/sec
client_http.kbytes_in = 0.000000/sec
client_http.kbytes_out = 0.029999/sec
client_http.all_median_svc_time = 0.000000 seconds
client_http.miss_median_svc_time = 0.000000 seconds
Btw. have you installed the squidclient package on the squid server?
Thank you for your reply!
From sudo /usr/lib/check_mk_agent/plugins/squid I get nothing. No output.
Check if squidclient is available, if not you need to install it. I.e
sudo apt install squidclient
Oh…
That did the trick…
At least for:
But still no output for:
OMD[mysite]: ~$ cmk -d my-squid-host-name | grep -A10 “<<squid:sep(0)>>”
