CMK version: Checkmk Raw Edition 2.1.0p11
OS version: Ubuntu 20.04.02 LTS
Error message: [snmp] Success, Missing monitoring data for plugins: hwg_tempWARN
File "/omd/sites/asv/lib/python3/cmk/base/config.py", line 2121, in _extract_agent_and_snmp_sections
create_snmp_section_plugin_from_legacy(
File "/omd/sites/asv/lib/python3/cmk/base/api/agent_based/register/section_plugins_legacy/__init__.py", line 246, in create_snmp_section_plugin_from_legacy
detect_spec = create_detect_spec(
File "/omd/sites/asv/lib/python3/cmk/base/api/agent_based/register/section_plugins_legacy/convert_scan_functions.py", line 416, in create_detect_spec
_compute_detect_spec(
File "/omd/sites/asv/lib/python3/cmk/base/api/agent_based/register/section_plugins_legacy/convert_scan_functions.py", line 384, in _compute_detect_spec
scan_func_ast = _get_scan_function_ast(section_name, scan_function, fallback_files)
File "/omd/sites/asv/lib/python3/cmk/base/api/agent_based/register/section_plugins_legacy/convert_scan_functions.py", line 111, in _get_scan_function_ast
assert source != "", "Files: %r" % ((read_files, src_file_name),)
AssertionError: Files: ([], None)
The above exception was the direct cause of the following exception:
File "/omd/sites/asv/bin/cmk", line 79, in <module>
errors = config.load_all_agent_based_plugins(check_api.get_check_api_context)
File "/omd/sites/asv/lib/python3/cmk/base/config.py", line 1529, in load_all_agent_based_plugins
errors.extend(load_checks(get_check_api_context, filelist))
File "/omd/sites/asv/lib/python3/cmk/base/config.py", line 1681, in load_checks
return _extract_agent_and_snmp_sections(
File "/omd/sites/asv/lib/python3/cmk/base/config.py", line 2142, in _extract_agent_and_snmp_sections
raise MKGeneralException(exc) from exc
cmk.utils.exceptions.MKGeneralException: Files: ([], None)
Hallo liebe Community,
ich habe gestern ein cmk Update von CRE 2.0.0p19 auf Raw Edition 2.1.0p11 durchgeführt. Seitdem zeigen mir unsere Temperatursensoren (HWg-STE: Ethernet thermometer) keine Temperaturwerte mehr an.
Laut offizieller Seite ist dieses Plugin “offizieller Teil von Check_MK”.
Ich habe dann erstmal die Firmware der Sensoren von 2.0.9 auf 2.2.2 geupdatet, doch das hat nichts geändert.
Dann habe ich mir auf dem Server die Ausgabe des Sensors angesehen mit cmk -D Sensor. Das Ergebnis:
Type of agent:
SNMP (Community: 'public', Bulk walk: no, Port: 161, Backend: Classic)
Process piggyback data from /omd/sites/asv/tmp/check_mk/piggyback/Sensor
Services:
checktype | item | params | description | groups
snmp_info | None | Timespecific parameters at 2022-09-08 09:08:13: None | SNMP Info |
hwg_temp | 1 | Timespecific parameters at 2022-09-08 09:08:13: {'levels': (30.0, 35.0)} | Temperature 1 |
uptime | None | Timespecific parameters at 2022-09-08 09:08:13: {} | Uptime |
Failed to auto-migrate legacy plugin to section: hwg_temp
Please refer to Werk 10601 for more information.
Failed to auto-migrate legacy plugin to section: hwg_humidity
Und genau dort stehe ich nun. Ich habe mir den Werk #10601: Auto migration of check plugins to new section definitions angesehen und komme nun nicht weiter. Außerdem steht dort bei Checkmk Version 2.0.0i1 - also eher die Version wo ich herkomme.
Kann mir jemand sagen, wo ich Informationen zu weiteren Schritten finde? Wie ich diesem Werk entnommen habe, könnte ein manuelles Eingreifen notwendig sein.
