These two questions are quite related for my case.
I wrote a local check for accessing a network drive and testing some files, (both systems are Windows servers) which failed. From what I understood, it must be copied in the local folder of the same server which hosts the files (LocalSystem account).
Is there any work around for local checks to access the network?
Alternatively, is it possible with plug-ins? I checked the documentation here:
which gives me the impression this is intended for linux systems only.
Is it possible to write plug-ins for Windows? If so where could I find the documentation?
If you write a plugin or a local check makes no difference. All agent scripts (plugins and local checks) are executed under the user context of your agent. This is normally “Local system” but you can change it to any other allowed user.
