Hello everyone. I’m facing the following problem. Can someone help? What else shall I troubleshoot?
CMK version:
Checkmk Raw Edition 2.2.0p9
OS version:
Ubuntu 22.04.2 LTS
Description of the problem:
I’m monitoring several Infoblox devices (VMs) out of an Infoblox Grid. Everything works fine except this error which I get on every single VM. The Infoblox firmware version is NIOS 9.0.1.
Parsing of section infoblox_temp failed - please submit a crash report! (Crash-ID: 345d646c-5a12-11ee-ab37-2fd85ca21da2)
(wow, this is a hard one, since the output displays my SNMPv3 keys in plaintext…)
OMD[weberlab]:~$ cmk --debug -vvn infoblox.weberlab.de
Checkmk version 2.2.0p9
+ FETCHING DATA
Source: SourceInfo(hostname='infoblox.weberlab.de', ipaddress='194.247.5.15', ident='snmp', fetcher_type=<FetcherType.SNMP: 7>, source_type=<SourceType.HOST: 1>)
[cpu_tracking] Start [7f6ba9e7a290]
Read from cache: SNMPFileCache(infoblox.weberlab.de, path_template=/omd/sites/weberlab/tmp/check_mk/data_source_cache/snmp/{mode}/{hostname}, max_age=MaxAge(checking=0, discovery=120, inventory=120), simulation=False, use_only_cache=False, file_cache_mode=6)
Not using cache (Too old. Age is 16 sec, allowed is 0 sec)
SNMP scan:
Getting OID .1.3.6.1.2.1.1.1.0: Running 'snmpget -v3 -l authPriv -a sha -u checkmk -A ThisWasTheKey -x AES -X ThisWasTheOtherKey -m "" -M "" -On -OQ -Oe -Ot 194.247.5.15 .1.3.6.1.2.1.1.1.0'
SNMP answer: ==> ["Spielwiese"]
b'Spielwiese'
Getting OID .1.3.6.1.2.1.1.2.0: Running 'snmpget -v3 -l authPriv -a sha -u checkmk -A ThisWasTheKey -x AES -X ThisWasTheOtherKey -m "" -M "" -On -OQ -Oe -Ot 194.247.5.15 .1.3.6.1.2.1.1.2.0'
SNMP answer: ==> [.1.3.6.1.4.1.7779.1.1004]
b'.1.3.6.1.4.1.7779.1.1004'
Using cached OID .1.3.6.1.2.1.1.1.0: 'Spielwiese'
Using cached OID .1.3.6.1.2.1.1.2.0: '.1.3.6.1.4.1.7779.1.1004'
SNMP scan found hr_mem snmp_uptime
Trying to acquire lock on /omd/sites/weberlab/tmp/check_mk/snmp_scan_cache/infoblox.weberlab.de.194.247.5.15
Got lock on /omd/sites/weberlab/tmp/check_mk/snmp_scan_cache/infoblox.weberlab.de.194.247.5.15
Releasing lock on /omd/sites/weberlab/tmp/check_mk/snmp_scan_cache/infoblox.weberlab.de.194.247.5.15
Released lock on /omd/sites/weberlab/tmp/check_mk/snmp_scan_cache/infoblox.weberlab.de.194.247.5.15
hr_cpu: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u checkmk -A ThisWasTheKey -x AES -X ThisWasTheOtherKey -m "" -M "" -Cc -OQ -OU -On -Ot 194.247.5.15 .1.3.6.1.2.1.25.3.3.1.2'
hr_fs: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u checkmk -A ThisWasTheKey -x AES -X ThisWasTheOtherKey -m "" -M "" -Cc -OQ -OU -On -Ot 194.247.5.15 .1.3.6.1.2.1.25.2.3.1.2'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u checkmk -A ThisWasTheKey -x AES -X ThisWasTheOtherKey -m "" -M "" -Cc -OQ -OU -On -Ot 194.247.5.15 .1.3.6.1.2.1.25.2.3.1.3'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u checkmk -A ThisWasTheKey -x AES -X ThisWasTheOtherKey -m "" -M "" -Cc -OQ -OU -On -Ot 194.247.5.15 .1.3.6.1.2.1.25.2.3.1.4'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u checkmk -A ThisWasTheKey -x AES -X ThisWasTheOtherKey -m "" -M "" -Cc -OQ -OU -On -Ot 194.247.5.15 .1.3.6.1.2.1.25.2.3.1.5'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u checkmk -A ThisWasTheKey -x AES -X ThisWasTheOtherKey -m "" -M "" -Cc -OQ -OU -On -Ot 194.247.5.15 .1.3.6.1.2.1.25.2.3.1.6'
hr_mem: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Already fetched OID: .1.3.6.1.2.1.25.2.3.1.2
Already fetched OID: .1.3.6.1.2.1.25.2.3.1.3
Already fetched OID: .1.3.6.1.2.1.25.2.3.1.4
Already fetched OID: .1.3.6.1.2.1.25.2.3.1.5
Already fetched OID: .1.3.6.1.2.1.25.2.3.1.6
if64: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u checkmk -A ThisWasTheKey -x AES -X ThisWasTheOtherKey -m "" -M "" -Cc -OQ -OU -On -Ot 194.247.5.15 .1.3.6.1.2.1.2.2.1.1'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u checkmk -A ThisWasTheKey -x AES -X ThisWasTheOtherKey -m "" -M "" -Cc -OQ -OU -On -Ot 194.247.5.15 .1.3.6.1.2.1.2.2.1.2'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u checkmk -A ThisWasTheKey -x AES -X ThisWasTheOtherKey -m "" -M "" -Cc -OQ -OU -On -Ot 194.247.5.15 .1.3.6.1.2.1.2.2.1.3'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u checkmk -A ThisWasTheKey -x AES -X ThisWasTheOtherKey -m "" -M "" -Cc -OQ -OU -On -Ot 194.247.5.15 .1.3.6.1.2.1.2.2.1.5'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u checkmk -A ThisWasTheKey -x AES -X ThisWasTheOtherKey -m "" -M "" -Cc -OQ -OU -On -Ot 194.247.5.15 .1.3.6.1.2.1.2.2.1.8'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u checkmk -A ThisWasTheKey -x AES -X ThisWasTheOtherKey -m "" -M "" -Cc -OQ -OU -On -Ot 194.247.5.15 .1.3.6.1.2.1.31.1.1.1.6'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u checkmk -A ThisWasTheKey -x AES -X ThisWasTheOtherKey -m "" -M "" -Cc -OQ -OU -On -Ot 194.247.5.15 .1.3.6.1.2.1.31.1.1.1.7'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u checkmk -A ThisWasTheKey -x AES -X ThisWasTheOtherKey -m "" -M "" -Cc -OQ -OU -On -Ot 194.247.5.15 .1.3.6.1.2.1.31.1.1.1.8'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u checkmk -A ThisWasTheKey -x AES -X ThisWasTheOtherKey -m "" -M "" -Cc -OQ -OU -On -Ot 194.247.5.15 .1.3.6.1.2.1.31.1.1.1.9'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u checkmk -A ThisWasTheKey -x AES -X ThisWasTheOtherKey -m "" -M "" -Cc -OQ -OU -On -Ot 194.247.5.15 .1.3.6.1.2.1.2.2.1.13'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u checkmk -A ThisWasTheKey -x AES -X ThisWasTheOtherKey -m "" -M "" -Cc -OQ -OU -On -Ot 194.247.5.15 .1.3.6.1.2.1.2.2.1.14'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u checkmk -A ThisWasTheKey -x AES -X ThisWasTheOtherKey -m "" -M "" -Cc -OQ -OU -On -Ot 194.247.5.15 .1.3.6.1.2.1.31.1.1.1.10'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u checkmk -A ThisWasTheKey -x AES -X ThisWasTheOtherKey -m "" -M "" -Cc -OQ -OU -On -Ot 194.247.5.15 .1.3.6.1.2.1.31.1.1.1.11'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u checkmk -A ThisWasTheKey -x AES -X ThisWasTheOtherKey -m "" -M "" -Cc -OQ -OU -On -Ot 194.247.5.15 .1.3.6.1.2.1.31.1.1.1.12'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u checkmk -A ThisWasTheKey -x AES -X ThisWasTheOtherKey -m "" -M "" -Cc -OQ -OU -On -Ot 194.247.5.15 .1.3.6.1.2.1.31.1.1.1.13'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u checkmk -A ThisWasTheKey -x AES -X ThisWasTheOtherKey -m "" -M "" -Cc -OQ -OU -On -Ot 194.247.5.15 .1.3.6.1.2.1.2.2.1.19'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u checkmk -A ThisWasTheKey -x AES -X ThisWasTheOtherKey -m "" -M "" -Cc -OQ -OU -On -Ot 194.247.5.15 .1.3.6.1.2.1.2.2.1.20'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u checkmk -A ThisWasTheKey -x AES -X ThisWasTheOtherKey -m "" -M "" -Cc -OQ -OU -On -Ot 194.247.5.15 .1.3.6.1.2.1.2.2.1.21'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u checkmk -A ThisWasTheKey -x AES -X ThisWasTheOtherKey -m "" -M "" -Cc -OQ -OU -On -Ot 194.247.5.15 .1.3.6.1.2.1.31.1.1.1.18'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u checkmk -A ThisWasTheKey -x AES -X ThisWasTheOtherKey -m "" -M "" -Cc -OQ -OU -On -Ot 194.247.5.15 .1.3.6.1.2.1.2.2.1.6'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u checkmk -A ThisWasTheKey -x AES -X ThisWasTheOtherKey -m "" -M "" -Cc -OQ -OU -On -Ot 194.247.5.15 .1.3.6.1.2.1.31.1.1.1.15'
infoblox_dhcp_stats: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u checkmk -A ThisWasTheKey -x AES -X ThisWasTheOtherKey -m "" -M "" -Cc -OQ -OU -On -Ot 194.247.5.15 .1.3.6.1.4.1.7779.3.1.1.4.1.3.1'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u checkmk -A ThisWasTheKey -x AES -X ThisWasTheOtherKey -m "" -M "" -Cc -OQ -OU -On -Ot 194.247.5.15 .1.3.6.1.4.1.7779.3.1.1.4.1.3.2'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u checkmk -A ThisWasTheKey -x AES -X ThisWasTheOtherKey -m "" -M "" -Cc -OQ -OU -On -Ot 194.247.5.15 .1.3.6.1.4.1.7779.3.1.1.4.1.3.3'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u checkmk -A ThisWasTheKey -x AES -X ThisWasTheOtherKey -m "" -M "" -Cc -OQ -OU -On -Ot 194.247.5.15 .1.3.6.1.4.1.7779.3.1.1.4.1.3.4'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u checkmk -A ThisWasTheKey -x AES -X ThisWasTheOtherKey -m "" -M "" -Cc -OQ -OU -On -Ot 194.247.5.15 .1.3.6.1.4.1.7779.3.1.1.4.1.3.5'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u checkmk -A ThisWasTheKey -x AES -X ThisWasTheOtherKey -m "" -M "" -Cc -OQ -OU -On -Ot 194.247.5.15 .1.3.6.1.4.1.7779.3.1.1.4.1.3.6'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u checkmk -A ThisWasTheKey -x AES -X ThisWasTheOtherKey -m "" -M "" -Cc -OQ -OU -On -Ot 194.247.5.15 .1.3.6.1.4.1.7779.3.1.1.4.1.3.7'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u checkmk -A ThisWasTheKey -x AES -X ThisWasTheOtherKey -m "" -M "" -Cc -OQ -OU -On -Ot 194.247.5.15 .1.3.6.1.4.1.7779.3.1.1.4.1.3.8'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u checkmk -A ThisWasTheKey -x AES -X ThisWasTheOtherKey -m "" -M "" -Cc -OQ -OU -On -Ot 194.247.5.15 .1.3.6.1.4.1.7779.3.1.1.4.1.3.9'
infoblox_dns_stats: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u checkmk -A ThisWasTheKey -x AES -X ThisWasTheOtherKey -m "" -M "" -Cc -OQ -OU -On -Ot 194.247.5.15 .1.3.6.1.4.1.7779.3.1.1.3.1.1.1.2'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u checkmk -A ThisWasTheKey -x AES -X ThisWasTheOtherKey -m "" -M "" -Cc -OQ -OU -On -Ot 194.247.5.15 .1.3.6.1.4.1.7779.3.1.1.3.1.1.1.3'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u checkmk -A ThisWasTheKey -x AES -X ThisWasTheOtherKey -m "" -M "" -Cc -OQ -OU -On -Ot 194.247.5.15 .1.3.6.1.4.1.7779.3.1.1.3.1.1.1.4'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u checkmk -A ThisWasTheKey -x AES -X ThisWasTheOtherKey -m "" -M "" -Cc -OQ -OU -On -Ot 194.247.5.15 .1.3.6.1.4.1.7779.3.1.1.3.1.1.1.5'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u checkmk -A ThisWasTheKey -x AES -X ThisWasTheOtherKey -m "" -M "" -Cc -OQ -OU -On -Ot 194.247.5.15 .1.3.6.1.4.1.7779.3.1.1.3.1.1.1.6'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u checkmk -A ThisWasTheKey -x AES -X ThisWasTheOtherKey -m "" -M "" -Cc -OQ -OU -On -Ot 194.247.5.15 .1.3.6.1.4.1.7779.3.1.1.3.1.1.1.7'
infoblox_grid_status: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u checkmk -A ThisWasTheKey -x AES -X ThisWasTheOtherKey -m "" -M "" -Cc -OQ -OU -On -Ot 194.247.5.15 .1.3.6.1.4.1.7779.3.1.1.2.1.15'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u checkmk -A ThisWasTheKey -x AES -X ThisWasTheOtherKey -m "" -M "" -Cc -OQ -OU -On -Ot 194.247.5.15 .1.3.6.1.4.1.7779.3.1.1.2.1.16'
infoblox_node_services: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u checkmk -A ThisWasTheKey -x AES -X ThisWasTheOtherKey -m "" -M "" -Cc -OQ -OU -On -Ot 194.247.5.15 .1.3.6.1.4.1.7779.3.1.1.2.1.10.1.1'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u checkmk -A ThisWasTheKey -x AES -X ThisWasTheOtherKey -m "" -M "" -Cc -OQ -OU -On -Ot 194.247.5.15 .1.3.6.1.4.1.7779.3.1.1.2.1.10.1.2'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u checkmk -A ThisWasTheKey -x AES -X ThisWasTheOtherKey -m "" -M "" -Cc -OQ -OU -On -Ot 194.247.5.15 .1.3.6.1.4.1.7779.3.1.1.2.1.10.1.3'
infoblox_replication_status: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u checkmk -A ThisWasTheKey -x AES -X ThisWasTheOtherKey -m "" -M "" -Cc -OQ -OU -On -Ot 194.247.5.15 .1.3.6.1.4.1.7779.3.1.1.2.1.2.1.1'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u checkmk -A ThisWasTheKey -x AES -X ThisWasTheOtherKey -m "" -M "" -Cc -OQ -OU -On -Ot 194.247.5.15 .1.3.6.1.4.1.7779.3.1.1.2.1.2.1.2'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u checkmk -A ThisWasTheKey -x AES -X ThisWasTheOtherKey -m "" -M "" -Cc -OQ -OU -On -Ot 194.247.5.15 .1.3.6.1.4.1.7779.3.1.1.2.1.2.1.3'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u checkmk -A ThisWasTheKey -x AES -X ThisWasTheOtherKey -m "" -M "" -Cc -OQ -OU -On -Ot 194.247.5.15 .1.3.6.1.4.1.7779.3.1.1.2.1.2.1.4'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u checkmk -A ThisWasTheKey -x AES -X ThisWasTheOtherKey -m "" -M "" -Cc -OQ -OU -On -Ot 194.247.5.15 .1.3.6.1.4.1.7779.3.1.1.2.1.2.1.5'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u checkmk -A ThisWasTheKey -x AES -X ThisWasTheOtherKey -m "" -M "" -Cc -OQ -OU -On -Ot 194.247.5.15 .1.3.6.1.4.1.7779.3.1.1.2.1.2.1.6'
infoblox_services: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u checkmk -A ThisWasTheKey -x AES -X ThisWasTheOtherKey -m "" -M "" -Cc -OQ -OU -On -Ot 194.247.5.15 .1.3.6.1.4.1.7779.3.1.1.2.1.9.1.1'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u checkmk -A ThisWasTheKey -x AES -X ThisWasTheOtherKey -m "" -M "" -Cc -OQ -OU -On -Ot 194.247.5.15 .1.3.6.1.4.1.7779.3.1.1.2.1.9.1.2'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u checkmk -A ThisWasTheKey -x AES -X ThisWasTheOtherKey -m "" -M "" -Cc -OQ -OU -On -Ot 194.247.5.15 .1.3.6.1.4.1.7779.3.1.1.2.1.9.1.3'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u checkmk -A ThisWasTheKey -x AES -X ThisWasTheOtherKey -m "" -M "" -Cc -OQ -OU -On -Ot 194.247.5.15 .1.3.6.1.2.1.1.1'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u checkmk -A ThisWasTheKey -x AES -X ThisWasTheOtherKey -m "" -M "" -Cc -OQ -OU -On -Ot 194.247.5.15 .1.3.6.1.2.1.1.2'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u checkmk -A ThisWasTheKey -x AES -X ThisWasTheOtherKey -m "" -M "" -Cc -OQ -OU -On -Ot 194.247.5.15 .1.3.6.1.2.1.1.4'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u checkmk -A ThisWasTheKey -x AES -X ThisWasTheOtherKey -m "" -M "" -Cc -OQ -OU -On -Ot 194.247.5.15 .1.3.6.1.2.1.1.5'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u checkmk -A ThisWasTheKey -x AES -X ThisWasTheOtherKey -m "" -M "" -Cc -OQ -OU -On -Ot 194.247.5.15 .1.3.6.1.2.1.1.6'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u checkmk -A ThisWasTheKey -x AES -X ThisWasTheOtherKey -m "" -M "" -Cc -OQ -OU -On -Ot 194.247.5.15 .1.3.6.1.2.1.1.3'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u checkmk -A ThisWasTheKey -x AES -X ThisWasTheOtherKey -m "" -M "" -Cc -OQ -OU -On -Ot 194.247.5.15 .1.3.6.1.2.1.25.1.1'
Write data to cache file /omd/sites/weberlab/tmp/check_mk/data_source_cache/snmp/checking/infoblox.weberlab.de
Trying to acquire lock on /omd/sites/weberlab/tmp/check_mk/data_source_cache/snmp/checking/infoblox.weberlab.de
Got lock on /omd/sites/weberlab/tmp/check_mk/data_source_cache/snmp/checking/infoblox.weberlab.de
Releasing lock on /omd/sites/weberlab/tmp/check_mk/data_source_cache/snmp/checking/infoblox.weberlab.de
Released lock on /omd/sites/weberlab/tmp/check_mk/data_source_cache/snmp/checking/infoblox.weberlab.de
[cpu_tracking] Stop [7f6ba9e7a290 - Snapshot(process=posix.times_result(user=0.06000000000000005, system=0.010000000000000009, children_user=2.56, children_system=0.2, elapsed=3.3099999986588955))]
Source: SourceInfo(hostname='infoblox.weberlab.de', ipaddress='194.247.5.15', ident='piggyback', fetcher_type=<FetcherType.PIGGYBACK: 4>, source_type=<SourceType.HOST: 1>)
[cpu_tracking] Start [7f6ba9caaed0]
Read from cache: NoCache(infoblox.weberlab.de, path_template=/dev/null, max_age=MaxAge(checking=0.0, discovery=0.0, inventory=0.0), simulation=False, use_only_cache=False, file_cache_mode=1)
Piggyback file '/omd/sites/weberlab/tmp/check_mk/piggyback/infoblox.weberlab.de/esxi2.weberlab.de': Successfully processed from source 'esxi2.weberlab.de'
No piggyback files for '194.247.5.15'. Skip processing.
[cpu_tracking] Stop [7f6ba9caaed0 - Snapshot(process=posix.times_result(user=0.009999999999999787, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
+ PARSE FETCHER RESULTS
<<<esx_vsphere_vm:cached(1695475330,90)>>> / Transition NOOPParser -> HostSectionParser
HostKey(hostname='infoblox.weberlab.de', source_type=<SourceType.HOST: 1>) -> Add sections: ['hr_cpu', 'hr_fs', 'hr_mem', 'if64', 'infoblox_dhcp_stats', 'infoblox_dns_stats', 'infoblox_grid_status', 'infoblox_node_services', 'infoblox_replication_status', 'infoblox_services', 'snmp_info', 'snmp_uptime']
HostKey(hostname='infoblox.weberlab.de', source_type=<SourceType.HOST: 1>) -> Add sections: ['esx_vsphere_vm', 'labels']
Received no piggyback data
[cpu_tracking] Start [7f6ba9cb3050]
value store: synchronizing
Trying to acquire lock on /omd/sites/weberlab/tmp/check_mk/counters/infoblox.weberlab.de
Got lock on /omd/sites/weberlab/tmp/check_mk/counters/infoblox.weberlab.de
Releasing lock on /omd/sites/weberlab/tmp/check_mk/counters/infoblox.weberlab.de
Released lock on /omd/sites/weberlab/tmp/check_mk/counters/infoblox.weberlab.de
CPU utilization Total CPU: 41.00%
DHCP statistics Received: 0 discovery messages, 0 requests, 0 releases, 0 declines, 0 informs, 0 other messages - Sent: 0 offers, 0 acks, 0 nacks
DNS statistics Since DNS process started: 50548 successful responses, 0 referrals, 0 queries received using recursion, 0 queries failed - Queries: 0 for non-existent records, 0 for non-existent domain
ESX CPU demand is 3.014 Ghz, 2 virtual CPUs
ESX Datastores Stored on LOCAL_R1 (924 GiB/19.4% free)
ESX Guest Tools VMware Tools are installed, but are not managed by VMware
ESX Heartbeat Heartbeat status is green
ESX Hostsystem Running on esxi2.weberlab.de
ESX Memory Host: 32.1 GiB, Guest: 2.56 GiB, Ballooned: 0 B, Shared: 0 B
ESX Mounted Devices HA functionality guaranteed
ESX Name Infoblox-Grid
ESX Snapshots Count: 0
Filesystem /config Used: 0.13% - 1.32 MiB of 976 MiB, trend per 1 day 0 hours: +0 B, trend per 1 day 0 hours: +0%
Filesystem /dev/shm Used: <0.01% - 8.00 KiB of 2.00 GiB, trend per 1 day 0 hours: +0 B, trend per 1 day 0 hours: +0%
Filesystem /etc/hostname Used: 16.83% - 16.7 GiB of 99.0 GiB, trend per 1 day 0 hours: +234 MiB, trend per 1 day 0 hours: +0.23%, Time left until disk full: 360 days 18 hours
Filesystem /etc/hosts Used: 16.83% - 16.7 GiB of 99.0 GiB, trend per 1 day 0 hours: +234 MiB, trend per 1 day 0 hours: +0.23%, Time left until disk full: 360 days 18 hours
Filesystem /etc/resolv.conf Used: 16.83% - 16.7 GiB of 99.0 GiB, trend per 1 day 0 hours: +234 MiB, trend per 1 day 0 hours: +0.23%, Time left until disk full: 360 days 18 hours
Filesystem /host/var/run/docker.sock Used: <0.01% - 528 KiB of 6.22 GiB, trend per 1 day 0 hours: +0 B, trend per 1 day 0 hours: +0%
Filesystem /infoblox/cntrs/netmri Used: 16.83% - 16.7 GiB of 99.0 GiB, trend per 1 day 0 hours: +234 MiB, trend per 1 day 0 hours: +0.23%, Time left until disk full: 360 days 18 hours
Filesystem /infoblox/cntrs/nios/rest Used: 16.83% - 16.7 GiB of 99.0 GiB, trend per 1 day 0 hours: +234 MiB, trend per 1 day 0 hours: +0.23%, Time left until disk full: 360 days 18 hours
Filesystem /infoblox/volumes/ni_netmri_data_backup Used: 16.83% - 16.7 GiB of 99.0 GiB, trend per 1 day 0 hours: +234 MiB, trend per 1 day 0 hours: +0.23%, Time left until disk full: 360 days 18 hours
Filesystem /infoblox/volumes/ni_reports Used: 16.83% - 16.7 GiB of 99.0 GiB, trend per 1 day 0 hours: +234 MiB, trend per 1 day 0 hours: +0.23%, Time left until disk full: 360 days 18 hours
Filesystem /reporting Used: 16.83% - 16.7 GiB of 99.0 GiB, trend per 1 day 0 hours: +234 MiB, trend per 1 day 0 hours: +0.23%, Time left until disk full: 360 days 18 hours
Filesystem /run Used: 1.35% - 888 KiB of 64.0 MiB, trend per 1 day 0 hours: +736 B, trend per 1 day 0 hours: +<0.01%, Time left until disk full: 246 years 135 days
Filesystem /run/lock Used: 0% - 0 B of 5.00 MiB, trend per 1 day 0 hours: +0 B, trend per 1 day 0 hours: +0%
Filesystem /storage Used: 16.83% - 16.7 GiB of 99.0 GiB, trend per 1 day 0 hours: +234 MiB, trend per 1 day 0 hours: +0.23%, Time left until disk full: 360 days 18 hours
Filesystem /storage/infoblox.var/reporting Used: 16.83% - 16.7 GiB of 99.0 GiB, trend per 1 day 0 hours: +234 MiB, trend per 1 day 0 hours: +0.23%, Time left until disk full: 360 days 18 hours
Filesystem /storage/netmri_data_backup Used: 16.83% - 16.7 GiB of 99.0 GiB, trend per 1 day 0 hours: +234 MiB, trend per 1 day 0 hours: +0.23%, Time left until disk full: 360 days 18 hours
Filesystem /storage/tftpboot Used: 0.44% - 2.32 MiB of 525 MiB, trend per 1 day 0 hours: +0 B, trend per 1 day 0 hours: +0%
Filesystem /sys/fs/cgroup Used: 0% - 0 B of 15.6 GiB, trend per 1 day 0 hours: +0 B, trend per 1 day 0 hours: +0%
Filesystem /tmpfs Used: 3.12% - 320 KiB of 10.0 MiB, trend per 1 day 0 hours: -5.29 MiB, trend per 1 day 0 hours: -52.91%
Grid replication Status: online, Master virtual IP: 194.247.5.15
Interface 01 [lo], (up), Speed: 10 MBit/s, In: 35.6 kB/s (2.85%), Out: 27.5 kB/s (2.20%)
Interface 02 [docker0], (down), MAC: 02:42:A5:8B:E0:50, Speed: unknown
Interface 11 [VMware VMXNET3 Ethernet Controller], (down), MAC: 00:0C:29:1C:E9:32, Speed: 10 GBit/s
Interface 12 [VMware VMXNET3 Ethernet Controller], (up), MAC: 00:0C:29:1C:E9:3C, Speed: 10 GBit/s, In: 8.74 kB/s (<0.01%), Out: 18.9 kB/s (<0.01%)
Interface 13 [VMware VMXNET3 Ethernet Controller], (down), MAC: 00:0C:29:1C:E9:46, Speed: 10 GBit/s
Interface 14 [VMware VMXNET3 Ethernet Controller], (down), MAC: 00:0C:29:1C:E9:50, Speed: 10 GBit/s
Interface 15 [tun1], (up), Speed: unknown, In: 1.83 kB/s, Out: 688 B/s
Memory Total (RAM + Swap): 54.29% - 16.9 GiB of 31.1 GiB RAM, RAM: 54.29% - 16.9 GiB of 31.1 GiB, Swap: 0% - 0 B of 24.0 GiB
Node service bloxtools Status: working (17% - Primary drive usage is OK.)
Node service bloxtools-move Status: working (Running)
Node service discovery-consolidator Status: working (0% - Discovery capacity usage is OK.)
Node service dns-cache-acceleration Status: working (0% - System swap space usage is OK.)
Node service enet-mgmt Status: working (49% - System memory usage is OK.)
Node service lcd Status: working (Online)
Node service memory Status: working (0% - Database capacity usage is OK.)
Node service node-status Status: working (194.247.5.15)
Node service power-supply1 Status: working (The NTP service resumed synchronization.)
Node service subgrid-conn Status: working (Reporting Service is working)
Node service sys-temp Status: working (CPU Usage: 39%)
Replication 192.168.3.53 Status: offline, Queue from master: 0 (2023/09/22 13:19:52), Queue to master: 0 (2023/09/22 13:19:17)
Replication 192.168.3.87 Status: offline, Queue from master: 0 (2023/09/22 13:19:42), Queue to master: 0 (2023/09/22 12:37:49)
Replication 194.247.5.16 Status: online, Queue from master: 0 (2023/09/23 15:22:33), Queue to master: 0 (2023/09/23 14:53:39)
Replication 194.247.5.17 Status: online, Queue from master: 0 (2023/09/23 15:22:33), Queue to master: 0 (2023/09/23 15:22:33)
SNMP Info Spielwiese, Infoblox-Grid-Weberlab, Weberlabs, Johannes Weber
Service bloxtools-move Status: working (Running)
Service dns Status: working (DNS Service is working)
Service ntp Status: working (NTP Service is working)
Uptime Up since Sep 04 2023 10:07:03, Uptime: 19 days 5 hours
[cpu_tracking] Stop [7f6ba9cb3050 - Snapshot(process=posix.times_result(user=0.040000000000000036, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.03999999910593033))]
[snmp] Success, [piggyback] Successfully processed from source 'esxi2.weberlab.de', execution time 3.3 sec | execution_time=3.350 user_time=0.110 system_time=0.010 children_user_time=2.560 children_system_time=0.200 cmk_time_snmp=0.480 cmk_time_agent=0.000
