after update from CEE 1.5.0p16 to 1.5.0p24 I have noticed that the perf-o-meters for interface checks (like if64 or based on the same if_fortigate) do not consider assumed_speed.
For example:
a line form the output of the command
cmk -nvp --debug --checks if_fortigate Fortigate
Interface wan2 OK - [3] (up) MAC: XX:XX:XX:XX:XX:XX, 1 Gbit/s, in: 16.7 Kbit/s(0.0%/100 Mbit/s), out: 381.9 Kbit/s(0.4%/100 Mbit/s) (in=2092.03071;10000000;11250000;0;12500000 inucast=6.340279;;;; innucast=0;;;; indisc=0;;;; inerr=0;90;95;; out=47733.102037;10000000;11250000;0;12500000 outucast=74.829224;;;; outnucast=0;;;; outdisc=0;;;; outerr=0;90;95;; outqlen=0;;;0.0;)
But the perf-o-meter uses the logarithmic scale like on the screenshot, because it doesn’t recognize in_bw or out_bw like coded in share/check_mk/web/plugins/perfometer/check_mk.py:
def perfometer_bandwidth(in_traffic, out_traffic, in_bw, out_bw, unit = “B”):
traffic_multiplier = 1 if (unit == “B”) else 8
# if we do not have bandwith make logarithmic perf-o-meter
if in_bw <= 0.0 or out_bw <= 0.0:
def perfometer_check_mk_if(row, check_command, perf_data):
unit = “Bit” if “Bit/s” in row[“service_plugin_output”] else “B”
return perfometer_bandwidth(
in_traffic = savefloat(perf_data[0][1]),
out_traffic = savefloat(perf_data[5][1]),
in_bw = savefloat(perf_data[0][6]),
out_bw = savefloat(perf_data[5][6]),
unit = unit
And looks like both in_bw and out_bw are empty, because the performance data doesn’t have an element number 6.
Or am I wrong and it is something different?
Any suggestions and help are very appreciated!
Best regards
Hermann M.
