Since the upgrade to 2.1.0p17 I’m having the same issue.
I agree, that this new? check belongs to the mentioned post.
But it doesn’t help with fixing the problem - it only says that there are new checks toi get more information.
Someone have an idea, what to do to fix? Or what this data means for the performance of CheckMK graphing?
There is a possibility that Send metrics to InfluxDB in batch would have fixed this. I would suggest check it after the update to the newer patch version.
