CMK version: 2.3.0p41
OS version: Ubuntu 24.04.3 LTS
Redfish Package: 2.3.77
Error message: redfish check plugin seems to override same drive ids on more than one storage controller
<!--- cmk --debug -vvn hostname-redfish.int
value store: synchronizing
Trying to acquire lock on /omd/sites/cmksz/tmp/check_mk/counters/hostname-redfish.int
Got lock on /omd/sites/cmksz/tmp/check_mk/counters/hostname-redfish.int
Releasing lock on /omd/sites/cmksz/tmp/check_mk/counters/hostname-redfish.int
Released lock on /omd/sites/cmksz/tmp/check_mk/counters/hostname-redfish.int
Checkmk version 2.3.0p41
* FETCHING DATA
Source: SourceInfo(hostname=‘hostname-redfish.int’, ipaddress=‘xxx.xx.xx.xx’, ident=‘special_redfish’, fetcher_type=<FetcherType.SPECIAL_AGENT: 6>, source_type=<SourceType.HOST: 1>)
\[cpu_tracking\] Start \[79ab2b3818b0\]
Read from cache: AgentFileCache(hostname-redfish.int, path_template=/omd/sites/cmksz/tmp/check_mk/data_source_cache/special_redfish/{hostname}, max_age=MaxAge(checking=0, discovery=90.0, inventory=90.0), simulation=False, use_only_cache=False, file_cache_mode=6)
Not using cache (Too old. Age is 10628 sec, allowed is 0 sec)
Calling: /omd/sites/cmksz/local/lib/python3/cmk_addons/plugins/redfish/libexec/agent_redfish -u cmksz --password-id uuid6a8bec4d-ddbe-4e1f-827e-735a394dd6ad:/omd/sites/cmksz/var/check_mk/passwords_merged -P https xxx.xx.xx.xx
Get data from program
Write data to cache file /omd/sites/cmksz/tmp/check_mk/data_source_cache/special_redfish/hostname-redfish.int
Trying to acquire lock on /omd/sites/cmksz/tmp/check_mk/data_source_cache/special_redfish/hostname-redfish.int
Got lock on /omd/sites/cmksz/tmp/check_mk/data_source_cache/special_redfish/hostname-redfish.int
Releasing lock on /omd/sites/cmksz/tmp/check_mk/data_source_cache/special_redfish/hostname-redfish.int
Released lock on /omd/sites/cmksz/tmp/check_mk/data_source_cache/special_redfish/hostname-redfish.int
\[cpu_tracking\] Stop \[79ab2b3818b0 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.31, children_system=0.03, elapsed=11.419999999925494))\]
\[cpu_tracking\] Start \[79ab2ba809b0\]
* PARSE FETCHER RESULTS
<<<check_mk:sep(32)>>> / Transition NOOPParser → HostSectionParser
<<<redfish_manager:sep(0)>>> / Transition HostSectionParser → HostSectionParser
<<<redfish_system:sep(0)>>> / Transition HostSectionParser → HostSectionParser
<<<redfish_chassis:sep(0)>>> / Transition HostSectionParser → HostSectionParser
<<<redfish_firmwareinventory:sep(0)>>> / Transition HostSectionParser → HostSectionParser
<<<redfish_networkinterfaces:sep(0)>>> / Transition HostSectionParser → HostSectionParser
<<<redfish_ethernetinterfaces:sep(0)>>> / Transition HostSectionParser → HostSectionParser
<<<redfish_memory:sep(0)>>> / Transition HostSectionParser → HostSectionParser
<<<redfish_processors:sep(0)>>> / Transition HostSectionParser → HostSectionParser
<<<redfish_storage:sep(0)>>> / Transition HostSectionParser → HostSectionParser
<<<redfish_drives:sep(0)>>> / Transition HostSectionParser → HostSectionParser
<<<redfish_volumes:sep(0)>>> / Transition HostSectionParser → HostSectionParser
<<<redfish_networkadapters:sep(0)>>> / Transition HostSectionParser → HostSectionParser
<<<redfish_thermal:sep(0)>>> / Transition HostSectionParser → HostSectionParser
<<<redfish_power:sep(0)>>> / Transition HostSectionParser → HostSectionParser
HostKey(hostname=‘hostname-redfish.int’, source_type=<SourceType.HOST: 1>) → Add sections: \[‘check_mk’, ‘redfish_chassis’, ‘redfish_drives’, ‘redfish_ethernetinterfaces’, ‘redfish_firmwareinventory’, ‘redfish_manager’, ‘redfish_memory’, ‘redfish_networkadapters’, ‘redfish_networkinterfaces’, ‘redfish_power’, ‘redfish_processors’, ‘redfish_storage’, ‘redfish_system’, ‘redfish_thermal’, ‘redfish_volumes’\]
Received no piggyback data
CPU 0 Type: CPU, Model: INTEL(R) XEON(R) GOLD 5515+, Cores: 8, Threads: 16, Speed maximum 3200 MHz
CPU 1 Type: CPU, Model: INTEL(R) XEON(R) GOLD 5515+, Cores: 8, Threads: 16, Speed maximum 3200 MHz
Check_MK Agent Version: 2.3.0, OS: redfish
Drive 0-KIOXIA PM73T8401DN (0) Size: 3577GB, Speed None Gbs, Media Life Left: 100%
Drive 0-MICRON 5400 MTFDDAK480TGA (0) Size: 447GB, Speed 6.0 Gbs, Media Life Left: 100%
Drive 1-KIOXIA PM73T8401DN (1) Size: 3577GB, Speed None Gbs, Media Life Left: 100%
Drive 1-MICRON 5400 MTFDDAK480TGA (1) Size: 447GB, Speed 6.0 Gbs, Media Life Left: 100%
Drive 2-KIOXIA PM73T8401DN (2) Size: 3577GB, Speed None Gbs, Media Life Left: 100%
Drive 3-KIOXIA PM73T8401DN (3) Size: 3577GB, Speed None Gbs, Media Life Left: 100%
Drive 4-KIOXIA PM73T8401DN (4) Size: 3577GB, Speed None Gbs, Media Life Left: 100%
Drive 5-KIOXIA PM73T8401DN (5) Size: 3577GB, Speed None Gbs, Media Life Left: 100%
Drive 6-KIOXIA PM73T8401DN (6) Size: 3577GB, Speed None Gbs, Media Life Left: 100%
Fan FAN 1A Speed: 7650.0 rpm
Fan FAN 1B Speed: 6750.0 rpm
Fan FAN 2A Speed: 7650.0 rpm
Fan FAN 2B Speed: 6750.0 rpm
Fan FAN 3A Speed: 7650.0 rpm
Fan FAN 3B Speed: 6750.0 rpm
Fan FAN 4A Speed: 7650.0 rpm
Fan FAN 4B Speed: 6750.0 rpm
Fan FAN 5A Speed: 7650.0 rpm
Fan FAN 5B Speed: 6750.0 rpm
Fan FAN 6A Speed: 7650.0 rpm
Fan FAN 6B Speed: 6750.0 rpm
Fan FAN PSU1 Speed: 5460.0 rpm
Fan FAN PSU2 Speed: 5460.0 rpm
Firmware health All firmware in optimal state
Memory 0 Size: 64GB, Type: DDR5-4400 SingleBitECC
Memory 1 Size: 64GB, Type: DDR5-4400 SingleBitECC
Memory 10 Size: 64GB, Type: DDR5-4400 SingleBitECC
Memory 12 Size: 64GB, Type: DDR5-4400 SingleBitECC
Memory 13 Size: 64GB, Type: DDR5-4400 SingleBitECC
Memory 14 Size: 64GB, Type: DDR5-4400 SingleBitECC
Memory 16 Size: 64GB, Type: DDR5-4400 SingleBitECC
Memory 17 Size: 64GB, Type: DDR5-4400 SingleBitECC
Memory 18 Size: 64GB, Type: DDR5-4400 SingleBitECC
Memory 2 Size: 64GB, Type: DDR5-4400 SingleBitECC
Memory 20 Size: 64GB, Type: DDR5-4400 SingleBitECC
Memory 21 Size: 64GB, Type: DDR5-4400 SingleBitECC
Memory 22 Size: 64GB, Type: DDR5-4400 SingleBitECC
Memory 24 Size: 64GB, Type: DDR5-4400 SingleBitECC
Memory 25 Size: 64GB, Type: DDR5-4400 SingleBitECC
Memory 26 Size: 64GB, Type: DDR5-4400 SingleBitECC
Memory 28 Size: 64GB, Type: DDR5-4400 SingleBitECC
Memory 29 Size: 64GB, Type: DDR5-4400 SingleBitECC
Memory 30 Size: 64GB, Type: DDR5-4400 SingleBitECC
Memory 4 Size: 64GB, Type: DDR5-4400 SingleBitECC
Memory 5 Size: 64GB, Type: DDR5-4400 SingleBitECC
Memory 6 Size: 64GB, Type: DDR5-4400 SingleBitECC
Memory 8 Size: 64GB, Type: DDR5-4400 SingleBitECC
Memory 9 Size: 64GB, Type: DDR5-4400 SingleBitECC
Memory Summary Capacity: 1536GB, with State: Component State: Normal, Rollup State: Normal, This resource is enabled.
Network adapter 0 Model: Onboard LAN, SeNr: None, PartNr: None
Network adapter 1 Model: PLAN EP E810-XXVDA4 4X 25G SFP28 OCPv3, SeNr: None, PartNr: None
Network adapter 2 Model: PLAN EP E810-XXVDA2 2X 25G SFP28 PCIe, SeNr: None, PartNr: None
Network adapter 3 Model: LAN PCI Card, SeNr: None, PartNr: None
Network adapter 4 Model: PFC EP QLE2692, SeNr: RFD2234A50042, PartNr: QLE2692
Network adapter 5 Model: PLAN EP E810-XXVDA2 2X 25G SFP28 PCIe, SeNr: None, PartNr: None
Physical port 0 Link: Unknown, Speed: 0Mbps, MAC: C4:7D:46:C4:1D:48
Physical port 131072 Link: LinkUp, Speed: 25000Mbps, MAC: 50:7C:6F:75:D7:E8
Physical port 131328 Link: LinkUp, Speed: 10000Mbps, MAC: 50:7C:6F:75:D7:E9
Physical port 196608 Link: Unknown, Speed: 0Mbps, MAC:
Physical port 196864 Link: Unknown, Speed: 0Mbps, MAC:
Physical port 327680 Link: LinkUp, Speed: 25000Mbps, MAC: 50:7C:6F:75:D7:F6
Physical port 327936 Link: LinkDown, Speed: 0Mbps, MAC: 50:7C:6F:75:D7:F7
Physical port 65536 Link: LinkUp, Speed: 25000Mbps, MAC: 40:A6:B7:8E:C3:E8
Physical port 65792 Link: LinkUp, Speed: 25000Mbps, MAC: 40:A6:B7:8E:C3:E9
Physical port 66048 Link: LinkDown, Speed: 0Mbps, MAC: 40:A6:B7:8E:C3:EA
Physical port 66304 Link: LinkDown, Speed: 0Mbps, MAC: 40:A6:B7:8E:C3:EB
Power supply 0-PSU1 0.0 Watts input, 0.0 Watts output, 0.0 V input, Capacity 900.0 Watts, Typ DPS-900AB-2 A
Power supply 1-PSU2 0.0 Watts input, 0.0 Watts output, 0.0 V input, Capacity 900.0 Watts, Typ DPS-900AB-2 A
Storage controller 0 Type: PRAID EP520i, RaidLevels: RAID0,RAID1,RAID5,RAID6,RAID10,RAID50,RAID60,RAID1E, DeviceProtocols: SAS
Storage controller 1 Type: PRAID EP520i, RaidLevels: RAID0,RAID1,RAID5,RAID6,RAID10,RAID50,RAID60,RAID1E, DeviceProtocols: SAS
Storage controller 2 Type: PRAID EP520i, RaidLevels: RAID0,RAID1,RAID5,RAID6,RAID10,RAID50,RAID60,RAID1E, DeviceProtocols: SAS
System state System with SerialNr: EWCE009959, has State: Component State: Normal, Rollup State: Normal, This resource is enabled.
Temperature Ambient Temperature: 23.0 °C
Temperature CPU1 Temperature: 53.0 °C
Temperature CPU2 Temperature: 51.0 °C
Temperature DIMM ABCD Temperature: 36.0 °C
Temperature DIMM EFGH Temperature: 35.0 °C
Temperature DIMM JKLM Temperature: 38.0 °C
Temperature DIMM NPQR Temperature: 37.0 °C
Temperature MB LEFT Temperature: 38.0 °C
Temperature MB MIDDLE Temperature: 36.0 °C
Temperature MB RIGHT Temperature: 41.0 °C
Temperature MB outlet Temperature: 39.0 °C
Temperature NetCore Temperature: 74.0 °C
Temperature NetPort Temperature: 55.0 °C
Temperature OCP NetCore Temperature: 61.0 °C
Temperature OCP NetPort Temperature: 48.0 °C
Temperature PCH Temperature: 39.0 °C
Temperature PCIe2 NetCore Temperature: 67.0 °C
Temperature PCIe2 NetPort Temperature: 55.0 °C
Temperature PCIe6 NetCore Temperature: 55.0 °C
Temperature PCIe6 NetPort Temperature: 48.0 °C
Temperature PCIe7 NetCore Temperature: 74.0 °C
Temperature PSU1 Temperature: 40.0 °C
Temperature PSU1 Inlet Temperature: 34.0 °C
Temperature PSU2 Temperature: 38.0 °C
Temperature PSU2 Inlet Temperature: 31.0 °C
Temperature PVCCD1 Temperature: 46.0 °C
Temperature PVCCD2 Temperature: 45.0 °C
Temperature PVCCFA_EHV_CPU1 Temperature: 35.0 °C
Temperature PVCCFA_EHV_CPU2 Temperature: 35.0 °C
Temperature PVCCINFAON_CPU1 Temperature: 47.0 °C
Temperature PVCCINFAON_CPU2 Temperature: 48.0 °C
Temperature PVCCIN_VR_CPU1 Temperature: 48.0 °C
Temperature PVCCIN_VR_CPU2 Temperature: 49.0 °C
Temperature RAID Controller Temperature: 63.0 °C
Temperature SSD Temperature: 31.0 °C
Voltage BATT 3.0V Location: SystemBoard, SensorNr: 81, Value: 3.1 V
Voltage MAIN 12V Location: SystemBoard, SensorNr: 91, Value: 12.1 V
Voltage P1V05_PCH_AUX Location: SystemBoard, SensorNr: 85, Value: 1.1 V
Voltage P1V8_PCH_AUX Location: SystemBoard, SensorNr: 86, Value: 1.8 V
Voltage P3V3 Location: SystemBoard, SensorNr: 89, Value: 3.3 V
Voltage P5V Location: SystemBoard, SensorNr: 90, Value: 5.1 V
Voltage PVNN_PCH_AUX Location: SystemBoard, SensorNr: 84, Value: 0.9 V
Voltage STBY 12V Location: SystemBoard, SensorNr: 83, Value: 12.1 V
Volume 0 Raid Type: RAID5, Size: 17882.3GB
* EXECUTING INVENTORY PLUGINS
allnet_ip_sensoric: skipped (no data)
aruba_wlc_aps: skipped (no data)
check_mk: ok
check_mk: skipped (no data)
checkmk_agent_plugins: skipped (no data)
cisco_meraki_org_device_info: skipped (no data)
cisco_meraki_power_supplies: skipped (no data)
dell_hw_info: skipped (no data)
docker_node_info: skipped (no data)
esx_systeminfo: skipped (no data)
fireeye_sys_status: skipped (no data)
fritz: skipped (no data)
hp_proliant_da_phydrv: skipped (no data)
hp_proliant_mem: skipped (no data)
hp_proliant_systeminfo: skipped (no data)
ibm_mq_channels: skipped (no data)
ibm_mq_managers: skipped (no data)
ibm_mq_queues: skipped (no data)
infoblox_osinfo: skipped (no data)
infoblox_systeminfo: skipped (no data)
inv_cisco_vlans: skipped (no data)
inv_esx_vsphere_hostsystem: skipped (no data)
inv_if: skipped (no data)
aix_baselevel: skipped (no data)
aix_lparstat_inventory: skipped (no data)
aix_packages: skipped (no data)
aix_service_packs: skipped (no data)
azure_load_balancer: skipped (no data)
inventory_checkmk: skipped (no data)
checkpoint_vpn_tunnels: skipped (no data)
citrix_controller: skipped (no data)
citrix_state: skipped (no data)
couchbase_nodes_ports: skipped (no data)
dmidecode: skipped (no data)
docker_container_labels: skipped (no data)
docker_container_network: skipped (no data)
inventory_docker_container_node_name: skipped (no data)
docker_node_images: skipped (no data)
docker_node_network: skipped (no data)
enviromux_micro_information: skipped (no data)
inventory_esx_vsphere_clusters: skipped (no data)
inventory_esx_vsphere_virtual_machines: skipped (no data)
fortiauthenticator_system: skipped (no data)
fortigate_ha: skipped (no data)
fortimail_system: skipped (no data)
fortinet_firewall_network_interfaces: skipped (no data)
fortisandbox_software: skipped (no data)
fortisandbox_system: skipped (no data)
ipmi_firmware: skipped (no data)
kube_cluster: skipped (no data)
kube_cronjob: skipped (no data)
kube_daemonset: skipped (no data)
kube_deployment: skipped (no data)
kube_namespace: skipped (no data)
kube_node: skipped (no data)
kube_pod: skipped (no data)
kube_statefulset: skipped (no data)
kyocera_printer: skipped (no data)
lnx_block_devices: skipped (no data)
lnx_ip_r: skipped (no data)
lnx_packages: skipped (no data)
lnx_sysctl: skipped (no data)
lnx_video: skipped (no data)
mobileiron_inventory: skipped (no data)
mssql_clusters: skipped (no data)
oracle_systemparameter: skipped (no data)
primekey: skipped (no data)
snmp_extended_info: skipped (no data)
solaris_addresses: skipped (no data)
solaris_pkginfo: skipped (no data)
solaris_cpus: skipped (no data)
solaris_routes: skipped (no data)
win_bios: skipped (no data)
win_disks: skipped (no data)
win_exefiles: skipped (no data)
win_ip_r: skipped (no data)
win_networkadapter: skipped (no data)
win_reg_uninstall: skipped (no data)
win_video: skipped (no data)
win_wmi_software: skipped (no data)
win_wmi_updates: skipped (no data)
juniper_info: skipped (no data)
lnx_cpuinfo: skipped (no data)
lnx_distro: skipped (no data)
lnx_if: skipped (no data)
lnx_uname: skipped (no data)
lparstat_aix: skipped (no data)
mem_used: skipped (no data)
mssql_instance: skipped (no data)
netapp_api_disk: skipped (no data)
netapp_api_info: skipped (no data)
oracle_dataguard_stats: skipped (no data)
oracle_instance: skipped (no data)
oracle_performance: skipped (no data)
oracle_recovery_area: skipped (no data)
oracle_tablespaces: skipped (no data)
perle_chassis: skipped (no data)
perle_chassis_slots: skipped (no data)
perle_psmu: skipped (no data)
prtconf: skipped (no data)
snmp_quantum_storage_info: skipped (no data)
snmp_info: skipped (no data)
solaris_prtdiag: skipped (no data)
solaris_uname: skipped (no data)
suseconnect: skipped (no data)
win_computersystem: skipped (no data)
win_computersystemproduct: skipped (no data)
win_cpuinfo: skipped (no data)
win_os: skipped (no data)
win_system: skipped (no data)
winperf_if: skipped (no data)
netapp_ontap_info: skipped (no data)
netapp_ontap_disk: skipped (no data)
redfish_firmware: ok
redfish_firmware: skipped (no data)
\[cpu_tracking\] Stop \[79ab2ba809b0 - Snapshot(process=posix.times_result(user=0.040000000000000036, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0400000000372529))\]
\[special_redfish\] Success, execution time 11.5 sec | execution_time=11.460 user_time=0.040 system_time=0.000 children_user_time=0.310 children_system_time=0.030 cmk_time_ds=11.080
Hi @andreas-doehler,
we have two FSAS RX2540M7 Servers with three raidcontrollers onboard. 1 Controller is raid1 with 2 ssd’s (500GB) and the other two raidcontroller are holding a raid 5 with 7 drives (4TB) equally.
When i made a service discovery i am only getting drives from storage0 (drive0 and 1 500GB) and storage1 (drives0-7 4TB). From storage2 i do not see any drives. The drive IDs per storage are the same identically, so i think the check plugin runs through the drive ids and overrides same ids!? Only if the drives are from different manufacturers or have different size they will be listed and able to monitor.
If i test with curl to get an output from the redfish api i get listed three storage0 / 1 / 2 with separate drives …/storage/0/drives/0-1/, …/storage/1/drives/0-7/ and …/storage/2/drives/0-7/ .
curl -k -u user:pw https…xxx.xx.xx.xx/redfish/v1/Systems/0/Storage/2/Drives/1
> “@odata.id”:“/redfish/v1/Systems/0/Storage/2/Drives/1”,
> “@odata.type”:“#Drive.v1_7_2.Drive”,
> “Oem”:{
> “ts_fujitsu@odata.typ@odata.typ@odata.typ@odata.type:{
> “@odata.type”:“#FTSDrive.v1_9_0.FTSDrive”,
> “LegacyStatus”:“Operational”,
> “EnclosureNumber”:null,
> “SlotNumber”:1,
> “DeviceNumber”:1,
> “ForeignConfiguration”:false,
> “MiscErrorCount”:0,
> “MediaErrorCount”:0,
> “PowerStatus”:“Activated”,
> “TemperatureC”:27,
> “PowerOnHours”:7361,
> “BytesWritten”:6998226230272,
> “StatusDetails”:{
> “OperationRemainingTime”:null,
> “WriteCacheEnabled”:true,
> “ReportedBlockSizeBytes”:512,
> “PortNumber”:1,
> “TransferWidthBits”:1,
> “ConfigurableSizeBytes”:479559942144,
> “SMARTErrorCount”:0,
> “EstimatedLifeTime”:“2030-02-05”,
> “VROCUsage”:null,
> “VROCArrayName”:null,
> “Socket”:null,
> “VMDControllerNumber”:null,
> “RootPortOffset”:null,
> “DeviceType”:null,
> “NVMeCapableSpeedGTs”:null,
> “NVMeNegotiatedSpeedGTs”:null
> “Id”:“1”,
> “Name”:“MICRON 5400 MTFDDAK480TGA (1)”,
> “StatusIndicator”:“OK”,
> “IndicatorLED”:“Off”,
> “IndicatorLED@Redfish.AllowableValues”:\[
> “Off”,
> “Blinking”
> “Model”:“5400 MTFDDAK480TGA”,
> “Revision”:“D4MU002”,
> “Status”:{
> “State”:“Enabled”,
> “Health”:“OK”,
> “Oem”:{
> “CapacityBytes”:480103104512,
> “FailurePredicted”:false,
> “Protocol”:“SATA”,
> “MediaType”:“SSD”,
> “Manufacturer”:“MICRON”,
> “SerialNumber”:“24384B2AA7E3”,
> “Identifiers”:\[
> “DurableNameFormat”:“NAA”,
> “DurableName”:“0x300605B012DDFF03”
> “Location”:\[
> “Info”:“\[ 0 : 2 : 1 \]”,
> “InfoFormat”:“\[ System_Id : Controller_Id : Slot_Id \]”
curl -k -u user:pw https…xxx.xx.xx.xx/redfish/v1/v1/Systems/0/Storage/0/Drives/3
> “@odata.id”:“/redfish/v1/Systems/0/Storage/0@odata.typ@odata.typ@odata.typ@odata.typeDrives/3”,
> “Oem”:{
> “ts_fuji@odata.typ@odata.typ@odata.typ@odata.typesu@odata.type:{
> “SlotNumber”:3,
> “DeviceNumber”:7,
> “MiscErrorCount”:0,
> “TemperatureC”:29,
> “PowerOnHours”:4536,
> “BytesWritten”:17708,
> “StatusDetails”:{
> “PortNumber”:5,
> “ConfigurableSizeBytes”:3840204079104,
> “EstimatedLifeTime”:“2030-06-02”,
> “VROCUsage”:null,
> “Socket”:null,
> “DeviceType”:null,
> “Id”:“3”,
> “Name”:“KIOXIA PM73T8401DN (3)”,
> “Off”,
> “Blinking”
> “Model”:“PM73T8401DN”,
> “Revision”:“5202”,
> “Status”:{
> “State”:“Enabled”,
> “Health”:“OK”,
> “Oem”:{
> “CapacityBytes”:3840755630080,
> “Protocol”:“SAS”,
> “MediaType”:“SSD”,
> “Manufacturer”:“KIOXIA”,
> “SerialNumber”:“74V0A01GTLHJ”,
> “Identifiers”:\[
> “DurableName”:“0x58CE38EE2336F2BE”
curl -k -u user:pw https…xxx.xx.xx.xx/redfish/v1/v1/Systems/0/Storage/1/Drives/3
> “@odata.id”:“/redfish/v1/System@odata.typ@odata.typ@odata.typ@odata.type/0/Storage/1/Drives/3”,
> “Oe@odata.typ@odata.typ@odata.typ@odata.type”:{
> “ts_fujitsu@odata.type:{
> “LegacyStatus”:“Failed”,
> “SlotNumber”:3,
> “DeviceNumber”:4,
> “MiscErrorCount”:0,
> “TemperatureC”:null,
> “PowerOnHours”:null,
> “BytesWritten”:null,
> “StatusDetails”:{
> “PortNumber”:4,
> “ConfigurableSizeBytes”:0,
> “EstimatedLifeTime”:null,
> “VROCUsage”:null,
> “Socket”:null,
> “DeviceType”:null,
> “Id”:“3”,
> “StatusIndicator”:“Fail”,
> “Off”,
> “Blinking”
> “Revision”:null,
> “Status”:{
> “State”:“Disabled”,
> “Health”:“Critical”,
> “Oem”:{
> “CapacityBytes”:0,
> “Protocol”:“SAS”,
> “MediaType”:“HDD”,
> “SerialNumber”:“9440A01YTLHJ”,
> “Identifiers”:\[
> “DurableName”:“0x58CE38EE233E81D6”
Are you able to fix this issue?
If you need further input please give an advice.
Regards Matthias.
