which version of checkm (version and license) are you using?
And yes:
You can define rules but you should be sure that the reasons of the problems are ok.
Ralf
Thanks, it worked and appears to be a great improvement.
I have combined it with “Maximum number of check attempts for service” 1 → 3.
I don’t see dozens of stale services and hundreds of false positive emails:
OK → WARN, OK → CRIT
just to see
WARN → OK, CRIT → OK
a minute later.
It could be that CMK server would benefit from more CPU/Memory resources.
I couldn’t see any evidence of resource deprivation by running “htop” though.
Only one potential concern here: CRIT: The current livestatus usage is 99.04% (!!), 20 of 20 connections used (!!), You have a connection overflow rate of 0.00/s (!!)
