Version 2.0.0p17.cre
Ubuntu 20.04.3 LTS
Docker 20.10.7
I have a instance of Check_MK raw running and I want to migrate it to a container.
I have performed a backup of my current site.
I have spun up a docker container of the same version.
When I try the restore on the website I get this:
2022-01-18 23:34:26 --- Starting restore (bkup) ---
2022-01-18 23:34:37 Error while sending data to restore process: [Errno 32] Broken pipe
2022-01-18 23:34:37 Traceback (most recent call last):
File "/omd/sites/cmk/bin/omd", line 60, in <module>
omdlib.main.main()
File "/omd/versions/2.0.0p17.cre/lib/python3/omdlib/main.py", line 4009, in main
command.handler(version_info, site, global_opts, args, command_options)
File "/omd/versions/2.0.0p17.cre/lib/python3/omdlib/main.py", line 2814, in main_restore
prepare_restore_as_site_user(site, global_opts, options)
File "/omd/versions/2.0.0p17.cre/lib/python3/omdlib/main.py", line 2911, in prepare_restore_as_site_user
shutil.rmtree(path)
File "/omd/versions/2.0.0p17.cre/lib/python3.8/shutil.py", line 722, in rmtree
onerror(os.rmdir, path, sys.exc_info())
File "/omd/versions/2.0.0p17.cre/lib/python3.8/shutil.py", line 720, in rmtree
os.rmdir(path)
OSError: [Errno 16] Device or resource busy: '/omd/sites/cmk/tmp'
Site restore failed
When I log in to the container and try the restore with the OMD site user it also fails.
OMD[cmk]:/home/bkup$ omd restore site-cmk.tar.gz
Restoring site from site-cmk.tar.gz...
Stopping site processes...
Removing Crontab...no crontab for cmk
Stopping redis...Not running.
Stopping apache...(not running)...OK
Stopping nagios...not running...OK
npcd was not running... could not stop
Stopping rrdcached...not running.
Stopping mkeventd...Not running.
OK
Saving temporary filesystem contents...OK
Cleaning up tmp directory...OK
Deleting existing site data...Traceback (most recent call last):
omdlib.main.main()
shutil.rmtree(path)
os.rmdir(path)
I have used the same docker run command that is in the documentation.
I tried this with setting the tmpfs setting on and off in the omd config. No change.
What am I missing?
Thanks,
C
