I’m trying to configure Ricoh printer with snmpv3 on CheckMK.
When i run test i got “Bad context specified”
When i run this command :
snmpbulkwalk -v 3 authPriv -a md5 -A ‘PASS’ -x AES -X ‘PASS’ -u ‘USER’ -n GWNCS IPADRESS
All work fine.
I’ve set rule in ‘SNMPv3 contexts to use in requests’
Section name : snmp_info
SNMP Context IDs : GWNCS
but i’ve always “Bad context specified” in Run test
Can you help me ?
Thanks
Checkmk Raw v 2.0.0p17
Nobody have this problem with snmpv3 ?
You are already using this rule ?
Hello @davidwayne
Yes i’ve set this rule like that :
jordani0
(Йордан Вълков)
December 15, 2022, 8:13am
6
Same issue here…
Have you found a solution?
MattiaSF
(Mattia)
January 4, 2023, 1:27pm
8
I also faced this problem in 2021 and at the end, as we have only one device affected, I decided to ignore it.
CheckMK 2.0.0p5 - SNMPv3 - Contexts to use in requests
Actually, I suspect could be a kind of bug because it doesn’t work no matter which “Section name” you chose. Snmpwalk instead works fine.
Last reply to this topic was 20 days ago so I would like to join it to see if someone can help us.
Mattia
system
(system)
Closed
January 4, 2024, 1:27pm
9
