I’m currently implementing a custom special agent and notices the following strage behaviour. I have been testing this on CRE 2.2.0p20 and CCE 2.2.0p20.
My first question here would be: Is there any documentation about writing special agents? I only found examples by radom people so far, but no real reference documentation about it. I have been reading Writing your own check plug-ins (checkmk.com) but there is not much about special agents there.
About my actual finding:
I’m developing with the free edition in a VM. I created a special agent executable and placed a “wrapper” in “local/share/check_mk/checks/”. This works, but shows the check as “deprecated” in “Analyze configuration”. So I tested if it would work to adjust the check according to what I found on the “Write you own check plug-ins” page. So I modified in and moved it to “local/lib/python3/cmk/base/plugins/agent_based”:
#!/usr/bin/env python3
# -*- coding: utf-8 -*-
from typing import Any, Mapping, Optional, Sequence
from cmk.base.check_api import passwordstore_get_cmdline
from cmk.base.config import special_agent_info
def agent_anypointplatform(
params: Mapping[str, Any], hostname: Optional[str], ipaddress: Optional[str]
) -> Sequence[object]:
args = [
"--url",
params["url"],
"--client_id",
params["client_id"],
"--client_secret",
passwordstore_get_cmdline("%s", params["client_secret"]),
return args
special_agent_info["anypointplatform"] = agent_anypointplatform
Files:
Agent based plugins (Checks, Inventory)
agent_anypointplatform.py
anypointplatform_runtimefabrics.py
Agents
special/agent_anypointplatform
GUI extensions
wato/rulespec_agent_anypointplatform.py
wato/anypointplatform_runtimefabrics_parameters.py
This way it works fine, in the CCE. I then installed the package in a CRE, and it looked good at first. Package can be installed, enabled, and the service discovery works:
But then activating the change fails, with the message:
Error precompiling checks for host anypoint: Cannot find check file agent_anypointplatform needed for check type agent_anypointplatform
So following status:
- Installing and enabling plugin works on CRE and CCE
- Service discovery works on CRE and CEE (so it is actually able to use the script)
- Enabling the change fails on CRE, but works fine on CCE.
So I moved “agent_anypointplatform.py” from “agent_based” to the legacy “checks” directory and removed the .py extension, and it’s working also on CRE now.
So I was wondering:
- Is this known, expected behavior?
- Where would I find the official documentation about this? I found a forum posting stating that the wrapper scripts of special agents always have to be placed in the legacy “checks” directory. I wonder if I missed that in the documentation.
Regards,
Sven
