Warning on network speed
I’m running check_mk-2b05 for some testing now. On some network interfaces I now get this warning:
WARN - [em1], (up), Speed: 1 GBit/s (expected: 0 Bit/s)WARN, In: 252 kB/s (0.20%), Out: 59.3 kB/s (0.05%)
Now, of course, the 1GBit/s is correct, so I’d like to update the service. On 1.6 I could do just a tabula refresh and that would fix everything. However, in 2b05 this option seems to be missing. So, how do I get CheckMK to update the speed of this interface to the correct value? I’ve tried moving it to disabled services and then back to enabled; using a full scan, but alas all to no prevail.
Regards,
Louis.
i think “actions - remove all and find new” at the top of the host page is what you are looking for :slight_smile:
Andre
Thanks, that was indeed what I was looking for.
Still getting used to the new interface.
