CMK version: Raw 2.1.0p25
OS version:Rocky 8
Error message:No error message that i know of
Checkmk version 2.1.0p25
Trying to acquire lock on /omd/sites/***/var/check_mk/license_usage/next_run
Got lock on /omd/sites/***/var/check_mk/license_usage/next_run
Trying to acquire lock on /omd/sites/***/var/check_mk/license_usage/history.json
Got lock on /omd/sites/***/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/***/var/check_mk/license_usage/history.json
Released lock on /omd/sites/***/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/***/var/check_mk/license_usage/next_run
Released lock on /omd/sites/***/var/check_mk/license_usage/next_run
+ FETCHING DATA
[cpu_tracking] Start [7ff92ca4e430]
[SNMPFetcher] Fetch with cache settings: SNMPFileCache(accsw04.***.is, base_path=/omd/sites/***/tmp/check_mk/data_source_cache/snmp, max_age=MaxAge(checking=0, discovery=120, inventory=120), disabled=False, use_outdated=False, simulation=False)
Not using cache (Too old. Age is 4 sec, allowed is 0 sec)
SNMP scan:
Getting OID .1.3.6.1.2.1.1.1.0: Running 'snmpget -v2c -c *** -m "" -M "" -t 15.00 -r 4 -On -OQ -Oe -Ot 10.10.15.244 .1.3.6.1.2.1.1.1.0'
SNMP answer: ==> ["Cisco IOS Software, C3560 Software (C3560-IPBASE-M), Version 12.2(25)SEB4, RELEASE SOFTWARE (fc1)]
b'Cisco IOS Software, C3560 Software (C3560-IPBASE-M), Version 12.2(25)SEB4, RELEASE SOFTWARE (fc1'
Getting OID .1.3.6.1.2.1.1.2.0: Running 'snmpget -v2c -c *** -m "" -M "" -t 15.00 -r 4 -On -OQ -Oe -Ot 10.10.15.244 .1.3.6.1.2.1.1.2.0'
SNMP answer: ==> [.1.3.6.1.4.1.9.1.616]
b'.1.3.6.1.4.1.9.1.616'
Using cached OID .1.3.6.1.2.1.1.2.0: '.1.3.6.1.4.1.9.1.616'
Getting OID .1.3.6.1.4.1.232.2.2.4.2.0: Running 'snmpget -v2c -c *** -m "" -M "" -t 15.00 -r 4 -On -OQ -Oe -Ot 10.10.15.244 .1.3.6.1.4.1.232.2.2.4.2.0'
SNMP answer: ==> [No Such Object available on this agent at this OID]
failed.
Using cached OID .1.3.6.1.4.1.232.2.2.4.2.0: None
Using cached OID .1.3.6.1.2.1.1.1.0: 'Cisco IOS Software, C3560 Software (C3560-IPBASE-M), Version 12.2(25)SEB4, RELEASE SOFTWARE (fc1'
Getting OID .1.3.6.1.2.1.2.2.1.*: Running 'snmpgetnext -Cf -v2c -c *** -m "" -M "" -t 15.00 -r 4 -On -OQ -Oe -Ot 10.10.15.244 .1.3.6.1.2.1.2.2.1'
SNMP answer: ==> [1]
b'1'
Getting OID .1.3.6.1.2.1.47.1.1.1.1.*: Running 'snmpgetnext -Cf -v2c -c *** -m "" -M "" -t 15.00 -r 4 -On -OQ -Oe -Ot 10.10.15.244 .1.3.6.1.2.1.47.1.1.1.1'
SNMP answer: ==> ["WS-C3560G-48PS"]
b'WS-C3560G-48PS'
Getting OID .1.3.6.1.4.1.674.*: Running 'snmpgetnext -Cf -v2c -c *** -m "" -M "" -t 15.00 -r 4 -On -OQ -Oe -Ot 10.10.15.244 .1.3.6.1.4.1.674'
SNMP answer: ==> [0]
failed.
Getting OID .1.3.6.1.4.1.2036.2.1.1.4.0: Running 'snmpget -v2c -c *** -m "" -M "" -t 15.00 -r 4 -On -OQ -Oe -Ot 10.10.15.244 .1.3.6.1.4.1.2036.2.1.1.4.0'
failed.
SNMP scan found hr_mem inv_cisco_vlans inv_if snmp_extended_info snmp_os snmp_uptime
Trying to acquire lock on /omd/sites/***/tmp/check_mk/snmp_scan_cache/accsw04.***.is.10.10.15.244
Got lock on /omd/sites/***/tmp/check_mk/snmp_scan_cache/accsw04.***.is.10.10.15.244
Releasing lock on /omd/sites/***/tmp/check_mk/snmp_scan_cache/accsw04.***.is.10.10.15.244
Released lock on /omd/sites/***/tmp/check_mk/snmp_scan_cache/accsw04.***.is.10.10.15.244
hr_mem: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Running 'snmpbulkwalk -Cr15 -v2c -c *** -m "" -M "" -t 15.00 -r 4 -Cc -OQ -OU -On -Ot 10.10.15.244 .1.3.6.1.2.1.25.2.3.1.2'
Running 'snmpbulkwalk -Cr15 -v2c -c *** -m "" -M "" -t 15.00 -r 4 -Cc -OQ -OU -On -Ot 10.10.15.244 .1.3.6.1.2.1.25.2.3.1.3'
Running 'snmpbulkwalk -Cr15 -v2c -c *** -m "" -M "" -t 15.00 -r 4 -Cc -OQ -OU -On -Ot 10.10.15.244 .1.3.6.1.2.1.25.2.3.1.4'
Running 'snmpbulkwalk -Cr15 -v2c -c *** -m "" -M "" -t 15.00 -r 4 -Cc -OQ -OU -On -Ot 10.10.15.244 .1.3.6.1.2.1.25.2.3.1.5'
Running 'snmpbulkwalk -Cr15 -v2c -c *** -m "" -M "" -t 15.00 -r 4 -Cc -OQ -OU -On -Ot 10.10.15.244 .1.3.6.1.2.1.25.2.3.1.6'
inv_cisco_vlans: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Running 'snmpbulkwalk -Cr15 -v2c -c *** -m "" -M "" -t 15.00 -r 4 -Cc -OQ -OU -On -Ot 10.10.15.244 .1.3.6.1.4.1.9.9.68.1.2.2.1.1'
Running 'snmpbulkwalk -Cr15 -v2c -c *** -m "" -M "" -t 15.00 -r 4 -Cc -OQ -OU -On -Ot 10.10.15.244 .1.3.6.1.4.1.9.9.68.1.2.2.1.2'
Running 'snmpbulkwalk -Cr15 -v2c -c *** -m "" -M "" -t 15.00 -r 4 -Cc -OQ -OU -On -Ot 10.10.15.244 .1.3.6.1.4.1.9.9.68.1.2.2.1.4'
inv_if: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Running 'snmpbulkwalk -Cr15 -v2c -c *** -m "" -M "" -t 15.00 -r 4 -Cc -OQ -OU -On -Ot 10.10.15.244 .1.3.6.1.2.1.2.2.1.1'
Running 'snmpbulkwalk -Cr15 -v2c -c *** -m "" -M "" -t 15.00 -r 4 -Cc -OQ -OU -On -Ot 10.10.15.244 .1.3.6.1.2.1.2.2.1.2'
Running 'snmpbulkwalk -Cr15 -v2c -c *** -m "" -M "" -t 15.00 -r 4 -Cc -OQ -OU -On -Ot 10.10.15.244 .1.3.6.1.2.1.31.1.1.1.18'
Running 'snmpbulkwalk -Cr15 -v2c -c *** -m "" -M "" -t 15.00 -r 4 -Cc -OQ -OU -On -Ot 10.10.15.244 .1.3.6.1.2.1.2.2.1.3'
Running 'snmpbulkwalk -Cr15 -v2c -c *** -m "" -M "" -t 15.00 -r 4 -Cc -OQ -OU -On -Ot 10.10.15.244 .1.3.6.1.2.1.2.2.1.5'
Running 'snmpbulkwalk -Cr15 -v2c -c *** -m "" -M "" -t 15.00 -r 4 -Cc -OQ -OU -On -Ot 10.10.15.244 .1.3.6.1.2.1.31.1.1.1.15'
Running 'snmpbulkwalk -Cr15 -v2c -c *** -m "" -M "" -t 15.00 -r 4 -Cc -OQ -OU -On -Ot 10.10.15.244 .1.3.6.1.2.1.2.2.1.8'
Running 'snmpbulkwalk -Cr15 -v2c -c *** -m "" -M "" -t 15.00 -r 4 -Cc -OQ -OU -On -Ot 10.10.15.244 .1.3.6.1.2.1.2.2.1.7'
Running 'snmpbulkwalk -Cr15 -v2c -c *** -m "" -M "" -t 15.00 -r 4 -Cc -OQ -OU -On -Ot 10.10.15.244 .1.3.6.1.2.1.2.2.1.6'
Running 'snmpbulkwalk -Cr15 -v2c -c *** -m "" -M "" -t 15.00 -r 4 -Cc -OQ -OU -On -Ot 10.10.15.244 .1.3.6.1.2.1.2.2.1.9'
snmp_extended_info: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Running 'snmpbulkwalk -Cr15 -v2c -c *** -m "" -M "" -t 15.00 -r 4 -Cc -OQ -OU -On -Ot 10.10.15.244 .1.3.6.1.2.1.47.1.1.1.1.2'
Running 'snmpbulkwalk -Cr15 -v2c -c *** -m "" -M "" -t 15.00 -r 4 -Cc -OQ -OU -On -Ot 10.10.15.244 .1.3.6.1.2.1.47.1.1.1.1.4'
Running 'snmpbulkwalk -Cr15 -v2c -c *** -m "" -M "" -t 15.00 -r 4 -Cc -OQ -OU -On -Ot 10.10.15.244 .1.3.6.1.2.1.47.1.1.1.1.5'
Running 'snmpbulkwalk -Cr15 -v2c -c *** -m "" -M "" -t 15.00 -r 4 -Cc -OQ -OU -On -Ot 10.10.15.244 .1.3.6.1.2.1.47.1.1.1.1.7'
Running 'snmpbulkwalk -Cr15 -v2c -c *** -m "" -M "" -t 15.00 -r 4 -Cc -OQ -OU -On -Ot 10.10.15.244 .1.3.6.1.2.1.47.1.1.1.1.10'
Running 'snmpbulkwalk -Cr15 -v2c -c *** -m "" -M "" -t 15.00 -r 4 -Cc -OQ -OU -On -Ot 10.10.15.244 .1.3.6.1.2.1.47.1.1.1.1.11'
Running 'snmpbulkwalk -Cr15 -v2c -c *** -m "" -M "" -t 15.00 -r 4 -Cc -OQ -OU -On -Ot 10.10.15.244 .1.3.6.1.2.1.47.1.1.1.1.12'
Running 'snmpbulkwalk -Cr15 -v2c -c *** -m "" -M "" -t 15.00 -r 4 -Cc -OQ -OU -On -Ot 10.10.15.244 .1.3.6.1.2.1.47.1.1.1.1.13'
snmp_os: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Running 'snmpbulkwalk -Cr15 -v2c -c *** -m "" -M "" -t 15.00 -r 4 -Cc -OQ -OU -On -Ot 10.10.15.244 .1.3.6.1.2.1.1.1.0'
Running 'snmpbulkwalk -Cr15 -v2c -c *** -m "" -M "" -t 15.00 -r 4 -Cc -OQ -OU -On -Ot 10.10.15.244 .1.3.6.1.2.1.1.2.0'
Running 'snmpbulkwalk -Cr15 -v2c -c *** -m "" -M "" -t 15.00 -r 4 -Cc -OQ -OU -On -Ot 10.10.15.244 .1.3.6.1.2.1.1.3.0'
Running 'snmpbulkwalk -Cr15 -v2c -c *** -m "" -M "" -t 15.00 -r 4 -Cc -OQ -OU -On -Ot 10.10.15.244 .1.3.6.1.2.1.1.5.0'
Write data to cache file /omd/sites/***/tmp/check_mk/data_source_cache/snmp/checking/accsw04.***.is
Trying to acquire lock on /omd/sites/***/tmp/check_mk/data_source_cache/snmp/checking/accsw04.***.is
Got lock on /omd/sites/***/tmp/check_mk/data_source_cache/snmp/checking/accsw04.***.is
Releasing lock on /omd/sites/***/tmp/check_mk/data_source_cache/snmp/checking/accsw04.***.is
Released lock on /omd/sites/***/tmp/check_mk/data_source_cache/snmp/checking/accsw04.***.is
[cpu_tracking] Stop [7ff92ca4e430 - Snapshot(process=posix.times_result(user=0.10999999999999988, system=0.13, children_user=0.04, children_system=0.17, elapsed=0.9699999997392297))]
[cpu_tracking] Start [7ff92ca4ea60]
[PiggybackFetcher] Fetch with cache settings: NoCache(accsw04.***.is, base_path=/omd/sites/***/tmp/check_mk/data_source_cache/piggyback, max_age=MaxAge(checking=0, discovery=120, inventory=120), disabled=True, use_outdated=False, simulation=False)
No piggyback files for 'accsw04.***.is'. Skip processing.
No piggyback files for '10.10.15.244'. Skip processing.
[cpu_tracking] Stop [7ff92ca4ea60 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
+ PARSE FETCHER RESULTS
Trying to acquire lock on /omd/sites/***/var/check_mk/persisted_sections/snmp/accsw04.***.is
Got lock on /omd/sites/***/var/check_mk/persisted_sections/snmp/accsw04.***.is
Releasing lock on /omd/sites/***/var/check_mk/persisted_sections/snmp/accsw04.***.is
Released lock on /omd/sites/***/var/check_mk/persisted_sections/snmp/accsw04.***.is
Stored persisted sections: cisco_cpu_multiitem, cisco_mem, cisco_power, cisco_secure, if64, snmp_info, snmp_uptime
Using persisted section SectionName('cisco_cpu_multiitem')
Using persisted section SectionName('cisco_mem')
Using persisted section SectionName('cisco_power')
Using persisted section SectionName('cisco_secure')
Using persisted section SectionName('if64')
Using persisted section SectionName('snmp_info')
Using persisted section SectionName('snmp_uptime')
-> Add sections: ['cisco_cpu_multiitem', 'cisco_mem', 'cisco_power', 'cisco_secure', 'hr_mem', 'if64', 'inv_cisco_vlans', 'inv_if', 'snmp_extended_info', 'snmp_info', 'snmp_os', 'snmp_uptime']
No persisted sections
-> Add sections: []
Received no piggyback data
[cpu_tracking] Start [7ff92c8d8400]
value store: synchronizing
Trying to acquire lock on /omd/sites/***/tmp/check_mk/counters/accsw04.***.is
Got lock on /omd/sites/***/tmp/check_mk/counters/accsw04.***.is
Releasing lock on /omd/sites/***/tmp/check_mk/counters/accsw04.***.is
Released lock on /omd/sites/***/tmp/check_mk/counters/accsw04.***.is
CPU utilization 1 Utilization in the last 5 minutes: 7.00%
Interface 00001 [Vlan1], (up), MAC: 00:17:E0:BA:D3:C0, Speed: 1 GBit/s, In: 0.00 B/s (0%), Out: 0.00 B/s (0%)
Interface 10101 [GigabitEthernet0/1], (up), MAC: 00:17:E0:BA:D3:81, Speed: 1 GBit/s, In: 0.00 B/s (0%), Out: 0.00 B/s (0%)
Interface 10102 [GigabitEthernet0/2], (down), MAC: 00:17:E0:BA:D3:82, Speed: 1 GBit/s
Interface 10103 [GigabitEthernet0/3], (down), MAC: 00:17:E0:BA:D3:83, Speed: 1 GBit/s
Interface 10104 [GigabitEthernet0/4], (down), MAC: 00:17:E0:BA:D3:84, Speed: 1 GBit/s
Interface 10105 [GigabitEthernet0/5], (up), MAC: 00:17:E0:BA:D3:85, Speed: 1 GBit/s, In: 0.00 B/s (0%), Out: 0.00 B/s (0%)
Interface 10106 [GigabitEthernet0/6], (up), MAC: 00:17:E0:BA:D3:86, Speed: 100 MBit/s, In: 0.00 B/s (0%), Out: 0.00 B/s (0%)
Interface 10107 [GigabitEthernet0/7], (up), MAC: 00:17:E0:BA:D3:87, Speed: 1 GBit/s, In: 0.00 B/s (0%), Out: 0.00 B/s (0%)
Interface 10108 [GigabitEthernet0/8], (down), MAC: 00:17:E0:BA:D3:88, Speed: 1 GBit/s
Interface 10109 [GigabitEthernet0/9], (up), MAC: 00:17:E0:BA:D3:89, Speed: 1 GBit/s, In: 0.00 B/s (0%), Out: 0.00 B/s (0%)
Interface 10110 [GigabitEthernet0/10], (down), MAC: 00:17:E0:BA:D3:8A, Speed: 1 GBit/s
Interface 10111 [GigabitEthernet0/11], (up), MAC: 00:17:E0:BA:D3:8B, Speed: 1 GBit/s, In: 0.00 B/s (0%), Out: 0.00 B/s (0%)
Interface 10112 [GigabitEthernet0/12], (up), MAC: 00:17:E0:BA:D3:8C, Speed: 1 GBit/s, In: 0.00 B/s (0%), Out: 0.00 B/s (0%)
Interface 10113 [GigabitEthernet0/13], (down), MAC: 00:17:E0:BA:D3:8D, Speed: 1 GBit/s
Interface 10114 [GigabitEthernet0/14], (up), MAC: 00:17:E0:BA:D3:8E, Speed: 1 GBit/s, In: 0.00 B/s (0%), Out: 0.00 B/s (0%)
Interface 10115 [GigabitEthernet0/15], (down), MAC: 00:17:E0:BA:D3:8F, Speed: 1 GBit/s
Interface 10116 [GigabitEthernet0/16], (up), MAC: 00:17:E0:BA:D3:90, Speed: 100 MBit/s, In: 0.00 B/s (0%), Out: 0.00 B/s (0%)
Interface 10117 [GigabitEthernet0/17], (down), MAC: 00:17:E0:BA:D3:91, Speed: 1 GBit/s
Interface 10118 [GigabitEthernet0/18], (up), MAC: 00:17:E0:BA:D3:92, Speed: 1 GBit/s, In: 0.00 B/s (0%), Out: 0.00 B/s (0%)
Interface 10119 [GigabitEthernet0/19], (up), MAC: 00:17:E0:BA:D3:93, Speed: 1 GBit/s, In: 0.00 B/s (0%), Out: 0.00 B/s (0%)
Interface 10120 [GigabitEthernet0/20], (up), MAC: 00:17:E0:BA:D3:94, Speed: 1 GBit/s, In: 0.00 B/s (0%), Out: 0.00 B/s (0%)
Interface 10121 [GigabitEthernet0/21], (up), MAC: 00:17:E0:BA:D3:95, Speed: 100 MBit/s, In: 0.00 B/s (0%), Out: 0.00 B/s (0%)
Interface 10122 [GigabitEthernet0/22], (down), MAC: 00:17:E0:BA:D3:96, Speed: 1 GBit/s
Interface 10123 [GigabitEthernet0/23], (down), MAC: 00:17:E0:BA:D3:97, Speed: 1 GBit/s
Interface 10124 [GigabitEthernet0/24], (down), MAC: 00:17:E0:BA:D3:98, Speed: 1 GBit/s
Interface 10125 [GigabitEthernet0/25], (down), MAC: 00:17:E0:BA:D3:99, Speed: 1 GBit/s
Interface 10126 [GigabitEthernet0/26], (down), MAC: 00:17:E0:BA:D3:9A, Speed: 1 GBit/s
Interface 10127 [GigabitEthernet0/27], (down), MAC: 00:17:E0:BA:D3:9B, Speed: 1 GBit/s
Interface 10128 [GigabitEthernet0/28], (down), MAC: 00:17:E0:BA:D3:9C, Speed: 1 GBit/s
Interface 10129 [GigabitEthernet0/29], (down), MAC: 00:17:E0:BA:D3:9D, Speed: 1 GBit/s
Interface 10130 [GigabitEthernet0/30], (down), MAC: 00:17:E0:BA:D3:9E, Speed: 1 GBit/s
Interface 10131 [GigabitEthernet0/31], (down), MAC: 00:17:E0:BA:D3:9F, Speed: 1 GBit/s
Interface 10132 [GigabitEthernet0/32], (down), MAC: 00:17:E0:BA:D3:A0, Speed: 1 GBit/s
Interface 10133 [GigabitEthernet0/33], (down), MAC: 00:17:E0:BA:D3:A1, Speed: 1 GBit/s
Interface 10134 [GigabitEthernet0/34], (down), MAC: 00:17:E0:BA:D3:A2, Speed: 1 GBit/s
Interface 10135 [GigabitEthernet0/35], (down), MAC: 00:17:E0:BA:D3:A3, Speed: 1 GBit/s
Interface 10136 [GigabitEthernet0/36], (down), MAC: 00:17:E0:BA:D3:A4, Speed: 1 GBit/s
Interface 10137 [GigabitEthernet0/37], (down), MAC: 00:17:E0:BA:D3:A5, Speed: 1 GBit/s
Interface 10138 [GigabitEthernet0/38], (down), MAC: 00:17:E0:BA:D3:A6, Speed: 1 GBit/s
Interface 10139 [GigabitEthernet0/39], (up), MAC: 00:17:E0:BA:D3:A7, Speed: 1 GBit/s, In: 0.00 B/s (0%), Out: 0.00 B/s (0%)
Interface 10140 [GigabitEthernet0/40], (down), MAC: 00:17:E0:BA:D3:A8, Speed: 1 GBit/s
Interface 10141 [GigabitEthernet0/41], (up), MAC: 00:17:E0:BA:D3:A9, Speed: 10 MBit/s, In: 0.00 B/s (0%), Out: 0.00 B/s (0%)
Interface 10142 [GigabitEthernet0/42], (up), MAC: 00:17:E0:BA:D3:AA, Speed: 100 MBit/s, In: 0.00 B/s (0%), Out: 0.00 B/s (0%)
Interface 10143 [GigabitEthernet0/43], (up), MAC: 00:17:E0:BA:D3:AB, Speed: 1 GBit/s, In: 0.00 B/s (0%), Out: 0.00 B/s (0%)
Interface 10144 [GigabitEthernet0/44], (up), MAC: 00:17:E0:BA:D3:AC, Speed: 100 MBit/s, In: 0.00 B/s (0%), Out: 0.00 B/s (0%)
Interface 10145 [GigabitEthernet0/45], (up), MAC: 00:17:E0:BA:D3:AD, Speed: 1 GBit/s, In: 0.00 B/s (0%), Out: 0.00 B/s (0%)
Interface 10146 [GigabitEthernet0/46], (up), MAC: 00:17:E0:BA:D3:AE, Speed: 10 MBit/s, In: 0.00 B/s (0%), Out: 0.00 B/s (0%)
Interface 10147 [GigabitEthernet0/47], (down), MAC: 00:17:E0:BA:D3:AF, Speed: 1 GBit/s
Interface 10148 [GigabitEthernet0/48], (down), MAC: 00:17:E0:BA:D3:B0, Speed: 1 GBit/s
Interface 10149 [GigabitEthernet0/49], (up), MAC: 00:17:E0:BA:D3:B1, Speed: 1 GBit/s, In: 0.00 B/s (0%), Out: 0.00 B/s (0%)
Interface 10150 [GigabitEthernet0/50], (down), MAC: 00:17:E0:BA:D3:B2, Speed: 1 GBit/s
Interface 10151 [GigabitEthernet0/51], (down), MAC: 00:17:E0:BA:D3:B3, Speed: 1 GBit/s
Interface 10152 [GigabitEthernet0/52], (down), MAC: 00:17:E0:BA:D3:B4, Speed: 1 GBit/s
Interface 14501 [Null0], (up), Speed: 10 GBit/s, In: 0.00 B/s (0%), Out: 0.00 B/s (0%)
Mem used I/O Usage: 77.73% - 9.32 MB of 11.99 MB
Mem used Processor Usage: 26.18% - 24.16 MB of 92.30 MB
Port Security No port security violation
Power Switch 1 PowerSupply 1 Status: normal, Source: AC
SNMP Info Cisco IOS Software, C3560 Software (C3560-IPBASE-M), Version 12.2(25)SEB4, RELEASE SOFTWARE (fc1) Copyright (c) 1986-2005 by Cisco Systems, Inc. Compiled Tue 30-Aug-05 14:19 by yenanh, accsw04.***
Uptime Up since Jun 21 2023 10:36:00, Uptime: 1 day 5 hours
+ EXECUTING INVENTORY PLUGINS
aruba_wlc_aps: skipped (no data)
check_mk: skipped (no data)
checkmk_agent_plugins: skipped (no data)
docker_node_info: skipped (no data)
fritz: skipped (no data)
hp_proliant_da_phydrv: skipped (no data)
hp_proliant_mem: skipped (no data)
ibm_mq_channels: skipped (no data)
ibm_mq_managers: skipped (no data)
ibm_mq_queues: skipped (no data)
ipmi_firmware: skipped (no data)
inv_cisco_vlans: ok
inv_cisco_vlans: skipped (no data)
inv_esx_vsphere_hostsystem: skipped (no data)
inv_if: ok
inv_if: skipped (no data)
aix_packages: skipped (no data)
aix_service_packs: skipped (no data)
inventory_checkmk: skipped (no data)
checkpoint_vpn_tunnels: skipped (no data)
dmidecode: skipped (no data)
docker_container_labels: skipped (no data)
docker_container_network: skipped (no data)
docker_node_images: skipped (no data)
docker_node_network: skipped (no data)
inventory_esx_vsphere_clusters: skipped (no data)
inventory_esx_vsphere_virtual_machines: skipped (no data)
fortiauthenticator_system: skipped (no data)
fortigate_ha: skipped (no data)
fortimail_system: skipped (no data)
fortisandbox_software: skipped (no data)
fortisandbox_system: skipped (no data)
k8s_assigned_pods: skipped (no data)
k8s_daemon_pod_containers: skipped (no data)
k8s_endpoint_info: skipped (no data)
k8s_ingress_infos: skipped (no data)
k8s_job_container: skipped (no data)
kube_cluster: skipped (no data)
kube_daemonset: skipped (no data)
kube_deployment: skipped (no data)
kube_namespace: skipped (no data)
kube_node: skipped (no data)
kube_pod: skipped (no data)
kube_statefulset: skipped (no data)
lnx_block_devices: skipped (no data)
lnx_ip_r: skipped (no data)
lnx_packages: skipped (no data)
lnx_sysctl: skipped (no data)
lnx_video: skipped (no data)
mobileiron_inventory: skipped (no data)
mssql_clusters: skipped (no data)
oracle_systemparameter: skipped (no data)
snmp_extended_info: ok
snmp_extended_info: skipped (no data)
solaris_addresses: skipped (no data)
solaris_pkginfo: skipped (no data)
solaris_psrinfo: skipped (no data)
solaris_cpus: skipped (no data)
solaris_prtpicl: skipped (no data)
solaris_routes: skipped (no data)
statgrab_net: skipped (no data)
win_disks: skipped (no data)
win_exefiles: skipped (no data)
win_ip_r: skipped (no data)
win_networkadapter: skipped (no data)
win_reg_uninstall: skipped (no data)
win_video: skipped (no data)
win_wmi_software: skipped (no data)
win_wmi_updates: skipped (no data)
juniper_info: skipped (no data)
k8s_nodes: skipped (no data)
k8s_pod_container: skipped (no data)
k8s_roles: skipped (no data)
lnx_if: skipped (no data)
mem_used: skipped (no data)
mssql_instance: skipped (no data)
netapp_api_disk: skipped (no data)
oracle_dataguard_stats: skipped (no data)
oracle_instance: skipped (no data)
oracle_performance: skipped (no data)
oracle_recovery_area: skipped (no data)
oracle_tablespaces: skipped (no data)
perle_chassis_slots: skipped (no data)
perle_psmu: skipped (no data)
snmp_info: ok
snmp_info: skipped (no data)
winperf_if: skipped (no data)
aix_baselevel: skipped (no data)
aix_lparstat_inventory: skipped (no data)
allnet_ip_sensoric: skipped (no data)
citrix_controller: skipped (no data)
citrix_state: skipped (no data)
couchbase_nodes_ports: skipped (no data)
dell_hw_info: skipped (no data)
docker_container_node_name: skipped (no data)
esx_systeminfo: skipped (no data)
fireeye_sys_status: skipped (no data)
hp_proliant_systeminfo: skipped (no data)
infoblox_osinfo: skipped (no data)
infoblox_systeminfo: skipped (no data)
k8s_pod_info: skipped (no data)
k8s_selector: skipped (no data)
k8s_service_info: skipped (no data)
lnx_cpuinfo: skipped (no data)
lnx_distro: skipped (no data)
lnx_uname: skipped (no data)
lparstat_aix: skipped (no data)
netapp_api_info: skipped (no data)
perle_chassis: skipped (no data)
prtconf: skipped (no data)
snmp_os: ok
snmp_os: skipped (no data)
snmp_quantum_storage_info: skipped (no data)
solaris_prtdiag: skipped (no data)
solaris_uname: skipped (no data)
suseconnect: skipped (no data)
win_bios: skipped (no data)
win_computersystem: skipped (no data)
win_cpuinfo: skipped (no data)
win_os: skipped (no data)
win_system: skipped (no data)
Trying to acquire lock on /omd/sites/***/tmp/check_mk/status_data/accsw04.***.is
Got lock on /omd/sites/***/tmp/check_mk/status_data/accsw04.***.is
Releasing lock on /omd/sites/***/tmp/check_mk/status_data/accsw04.***.is
Released lock on /omd/sites/***/tmp/check_mk/status_data/accsw04.***.is
Trying to acquire lock on /omd/sites/***/tmp/check_mk/status_data/accsw04.***.is.gz
Got lock on /omd/sites/***/tmp/check_mk/status_data/accsw04.***.is.gz
Releasing lock on /omd/sites/***/tmp/check_mk/status_data/accsw04.***.is.gz
Released lock on /omd/sites/***/tmp/check_mk/status_data/accsw04.***.is.gz
Trying to acquire lock on /omd/sites/***/tmp/check_mk/status_data/.last
Got lock on /omd/sites/***/tmp/check_mk/status_data/.last
Releasing lock on /omd/sites/***/tmp/check_mk/status_data/.last
Released lock on /omd/sites/***/tmp/check_mk/status_data/.last
[cpu_tracking] Stop [7ff92c8d8400 - Snapshot(process=posix.times_result(user=0.09999999999999964, system=0.010000000000000009, children_user=0.0, children_system=0.0, elapsed=0.10999999940395355))]
[snmp] Success, execution time 1.1 sec | execution_time=1.080 user_time=0.210 system_time=0.140 children_user_time=0.040 children_system_time=0.170 cmk_time_snmp=0.520 cmk_time_agent=0.000
I’m having issues with multiple switches in my environment and they regularly report absurd usage on the switches interfaces, 10’s of GBit/s on a 1GBit port and even up to TBit/s on some of them. Anyone have any clue what could be causing this?
Edit: I know Rocky 8 isn’t officially supported but I switched last week from Centos7 and it was the same problem there.
