Here’s what I’m running into: Royal TSX-2021-06-04 at 10.26.55 · CleanShot Cloud
I upgraded from 1.5.0p25 RAW to CEE - then I plan on doing all the upgrades to 1.6 to 2.0, etc.
I made the following changes after upgrading to CEE
Maybe I missed a config somewhere? This is just in the All hosts view…when I drill into a host or service, I see the information as expected.
Last login: Fri Jun 4 08:58:21 2021 from 10.254.254.100
support@monitor:~$ sudo su -
[sudo] password for support:
root@monitor:~# omd version
OMD - Open Monitoring Distribution Version 1.5.0p25.cee
# EXAMINE CONFIG
root@monitor:~# omd config gsd show
ADMIN_MAIL:
APACHE_MODE: own
APACHE_TCP_ADDR: 127.0.0.1
APACHE_TCP_PORT: 5000
AUTOSTART: on
CORE: nagios
LIVEPROXYD: on
LIVESTATUS_TCP: off
MKEVENTD: off
MULTISITE_AUTHORISATION: off
MULTISITE_COOKIE_AUTH: off
NAGIOS_THEME: classicui
NSCA: off
PNP4NAGIOS: on
TMPFS: on
# STOP THE SITE
root@monitor:~# omd stop gsd
Removing Crontab...OK
Stopping apache...killing 1531....OK
Stopping nagios.....OK
Stopping npcd...OK
Stopping rrdcached...waiting for termination...OK
Stopping mknotifyd...killing 1377...
Stopping liveproxyd...killing 1341...OK
# SET CMC AS THE NEW CORE
root@monitor:~# omd config gsd set CORE cmc
# START SITE
root@monitor:~# omd start gsd
OK
Starting liveproxyd...OK
Starting mknotifyd...OK
Starting rrdcached...OK
Starting cmc...OK
Starting apache...OK
Initializing Crontab...OK
# CHECK CONFIG
ADMIN_MAIL:
APACHE_MODE: own
AUTOSTART: on
CORE: cmc
LIVEPROXYD: on
LIVESTATUS_TCP: off
MKEVENTD: off
NSCA: off
TMPFS: on
Change the graphs
sudo su -
su gsd
cd ~/var/pnp4nagios/perfdata/
tar -cvzf ~/tmp/backup.tar ~/var/pnp4nagios/perfdata/
Wait for the above operation to finish…
su gsd
cmk --convert-rrds -v
# SEE ALL NEW RRDs here
cd ~/var/check_mk/rrd
ls
Delete all old ones
su gsd
cmk --convert-rrds --delete-rrds -v
Move log files over per Migration to the CMC - Switching from Nagios to the Checkmk micro core
cp ~/var/nagios/nagios.log ~/var/check_mk/core/archive
cp ~/var/nagios/archive/* ~/var/check_mk/core/archive
